Reading: Magnetic Wind Instruments Questions & Answers
Inst Tools > Blog > Multiple Choice Questions > Magnetic Wind Instruments Questions & Answers
Last updated: November 27, 2021 5:37 pm
1. Which of the following does not occur in Hartman and Braun oxygen analyzer based on magnetic wind?
a) Oxygen is attracted to magnetic field
b) Oxygen becomes less paramagnetic due to rise in temperature
c) Resistance change in a resistance connected to the Wheatstone bridge occur
d) Wheatstone Bridge becomes balanced due to temperature change
Answer: d
Explanation: In Hartman and Braun oxygen analyzer, the magnetic wind cools the heated winding. As a result, the bridge becomes unbalanced.
2. Which of the following is not a cause of error that could occur in Hartman and Braun oxygen analyzer based on magnetic wind?
a) The filament temperature could be affected by changes in thermal conductivity of the carrier gas
b) Hydrocarbons in sample stream may react on the heated filaments
c) Gravitation chimney flow effect lead to errors when cross tube is horizontal
d) Combustible gases may react on the heated filaments
Answer: c
Explanation: Error occurs when cross tube is vertical. When cross tube is horizontal, errors due to gravitation chimney flow effect is avoided.
3. Hydrocarbons need to be removed from the sample gas to avoid errors in Hartman and Braun oxygen analyzer.
a) True
b) False
Answer: a
Explanation: Hydrocarbons need to be removed from the sample gas to avoid errors. This is because they may react on the heated filaments and lead to change in temperature and resistance.
4. Magnetic wind analyzers are also known as which of the following?
a) Thermo-magnetic analyzers
b) Electro-magnetic analyzers
c) Thermo-analytical analyzers
d) Hot wire analyzers
Answer: a
Explanation: Magnetic wind analyzers are also known as Thermo-magnetic analyzers. In Europe, it is known as Magnetic wind analyzers. In United States, it is known as Thermo-magnetic analyzers.
5. In OXYMAT-M oxygen analyser which of the following is usually used as reference gas?
a) Hydrogen
b) Nitrogen
c) Helium
d) Ambient air
Answer: d
Explanation: In OXYMAT-M oxygen analyser, ambient air is usually used as reference gas. Its measuring procedure is based on pressure difference which develops between two gases having different oxygen concentration in the magnetic field.
6. Which of the following is used in magnetic wind instruments to determine the amount of oxygen?
a) Change in resistance
b) Change in capacitance
c) Change in inductance
d) Change in concentration
Answer: a
Explanation: In magnetic wind instruments to determine the amount of oxygen, change in temperature leads to a change in resistance. This change in resistance is measured to determine the amount of oxygen.
7. Which of the following concepts are not used in magnetic wind instruments?
a) Change in resistance due to cooling by magnetic wind
b) Displacement of membrane by magnetised oxygen
c) Difference in pressure difference between two gases having varying concentration of oxygen
d) By measuring temperature using thermometer
Answer: d
Explanation: Temperature is not measured in magnetic wind instruments. The cooling effect of magnetic wind causes a change in resistance which is measured.
8. How are the hydrocarbons in the samples removed in magnetic wind instruments?
a) By using a cold trap
b) By using a filter
c) By using a semipermeable membrane
d) By using magnetic effect
Answer: a
Explanation: The hydrocarbons in the samples are removed in magnetic wind instruments by using a cold trap. It is removed to avoid combustion.
9. Which of the following bridges are used in magnetic wind instruments?
a) Wheatstone bridge
b) Kelvin’s bridge
c) Anderson’s bridge
d) Schering’s bridge
Answer: a
Explanation: Wheatstone bridge is generally used in magnetic wind instruments. The change in resistance due to cooling effect is measured using Wheatstone bridge.
10. The extremely high inertia of the thin membrane in the oxygen sensor allows it to rapidly attain equilibrium.
a) True
b) False
Answer: b
Explanation: The extremely low inertia of the thin membrane in the oxygen sensor allows it to attain equilibrium. It reaches equilibrium state in 0.25 to 0.5 seconds.
PID Controller Multiple Choice Questions
Ion Transducers Questions & Answers
Stability of Nonlinear System
Robotic Control System – Part II
Tandem Mass Spectroscopy
Detection System of Gas Chromatography Questions and Answers
Liquid Chromatography Questions & Answers
Fourier Transform NMR Spectroscopy Questions & Answers
Performance Indices
Instrumentation of Ion Spectroscopy
Ionization of Gases Questions and Answers
Mass Spectrometer Questions & Answers
Approximation of Higher-Order Systems by Lower Order
Digital Control Systems
Stability Analysis
Chromatographic Behaviour of Solutes Questions & Answers
number-systems-questions-answers
Measurement and Instrumentation Objective Questions – Part 4
Components of Mass Spectrometer Questions & Answers
Auger Electron Spectroscopy
Time Response Analysis
Effect of Adding a Zero to a System
Digital Circuits Questions & Answers
Logic Families Questions and Answers
Control Systems Stability and Algebraic Criteria
Necessary Conditions for Stability & Non-Linear Systems
Why Are Charcoal and Salt Added to an Earthing Pit
Why Are Charcoal and Salt Added to an Earthing Pit?
Raspberry Pi Projects
200 Raspberry Pi Projects
What is OTDR Testing
Understanding the Difference between HOP Test and OTDR
Induced EMF
Magnetic Circuits
Remote Factory Acceptance Test
5 Tips to Pass CFSE Exam
Fire Hydrant System
Basics of Fire Fighting Hydrant Systems
Robot Anatomy
Robot – Anatomy, Configuration, Reference Frame, Characteristics
