Reading: What are Inverse Time and Instantaneous Trip Circuit Breakers?
Inst Tools > Blog > Electrical Basics > What are Inverse Time and Instantaneous Trip Circuit Breakers?
Learn the inverse time and instantaneous trip circuit breakers principle, operation, advantages, and disadvantages.
Last updated: September 28, 2022 2:36 pm
R Jagan Mohan Rao
Electrical Basics
Circuit breakers are available in two types.
Inverse Time Circuit BreakersInstantaneous Trip Circuit Breakers
  1. Inverse-time circuit breakers, also called Thermal-magnetic circuit breakers.
  2. Instantaneous circuit breakers are also known as magnetic-only circuit breakers.
The inverse time circuit breakers associates with a thermal characteristic. At lower over current levels, the circuit breaker must wait for some time to see if this temporary fault.
After letting the overcurrent flow for some time, if it is still experiencing some fault current then the interrupting circuit breaker must break the circuit. This is called the inverse time characteristic.
These breakers commonly use a bimetallic element that bends to hit a trip release when it is heated. With a low overcurrent, the heating is low and the element bends slowly. More overcurrent more heating and faster it bends. Hence, it is “inverse time”.
Inverse time circuit breakers have both thermal and instantaneous trip characteristics and are preset to trip at standard adjustable settings. Their characteristic inverse time-tripping under overload conditions is ideally suited for many applications ranging from residential to heavy industrial loads.
The thermal action of the inverse circuit breaker responds to heat. If a motor’s ventilation inlets and outlets are not sufficient to removing heat from the windings of the motor, the heat will be detected by the thermal action of the circuit breaker.
In the case of a short circuit, the magnetic action of the circuit breaker will detect the instantaneous values of current and trip the circuit breaker.
The National Electrical Code (NEC 430.52) requires inverse time circuit breakers to be sized to a maximum of 250% of the motor full-load amperes (FLA).
The instantaneous breakers, also known as magnetic-only circuit breakers. They look like thermal-magnetic circuit breakers.
They don’t have a thermal trip function and will not protect from an overcurrent, not even for themselves.
They react only to instantaneous currents such as short circuits. Instantaneous-trip circuit breakers are designed for one very specific purpose, that being to provide branch-circuit short-circuit protection for motor circuits. As per the NEC standard, their use only in listed combination motor controllers.
The most widespread use of these breakers is in combination with motor starters. A motor starter comprises a contactor and overload relay.
The contactor has a different function and provides no protection for the motor, the motor’s circuit nor itself. The overload relay provides motor overload protection as well as cable overload protection so long as the cable is sized properly.
Reference: F. A. Scheda, “Transient inrush current in high-efficiency and standard motors”, IEEE Trans.
  • What is a Megger?
  • Types of Electrical Wiring
  • Motor Speed Control using VFD
  • AC Motor Speed Control
  • What is a Protective Relay?
Difference Between Power Cable and Instrument Cable
Motor Forward and Reverse Direction Control using Limit Switches
Difference Between Trunking and Conduit
Differences between Watts and Volt Amps
Difference Between Short Circuit and Ground Fault
Difference Between UL489 and UL1077
Variable Motor Speed Control
What is an Armoured Cable? Classification of Cables
Partial Discharge in Power Lines and its Detection through Sensors
What is a Semiconductor Fuse?
Transformer Testing – Routine Tests of Transformers
Electrical Drawings
What is SMPS
What is SMPS? – Types of SMPS
Types of MCB
Types of MCB
What is Power Cable
What is Power Cable? Types of Power Cables
Lithium-ion Battery Charging System
Lithium-ion Battery Charging Systems
Difference Between AA and AAA Batteries
Worldwide Voltage & Frequency Values
Dahlander Motor Control Circuit
Dahlander Motor Control Circuit and Power Circuit
Intelligent MCC
What is Smart or Intelligent MCC?
Schematic Diagram
Schematic Diagram
Tilting Disk Check Valve Principle
What is Tilting Disk Check Valve ?
Float level gauge Principle
Float Type Level Indicator Principle
Detection System of Gas Chromatography Questions and Answers
Evolution of Air Compressors
Studio 5000 Define Program or Operator Control in Functional Block Diagram
Studio 5000: Define Program or Operator Control in Functional Block Diagram
Add On Instructions Programming – Analog Input Devices in Studio 5000
Manual Call Point Operating Principle
What is Manual Call Point (MCP) ?
