Reading: Instrumentation for Electron Spectroscopy
Inst Tools > Blog > Multiple Choice Questions > Instrumentation for Electron Spectroscopy
Last updated: November 27, 2021 5:37 pm
1. A basic X-ray source includes which of the following components?
a) Large target anode
b) Large target cathode
c) Small target anode
d) Small target cathode
Answer: a
Explanation: A basic X-ray source includes a large target anode. It also has a heating element.
2. The anode is held at __________ positive potential and the filament is held at ____________ potential.
a) High, ground
b) Ground, high
c) Low, high
d) High, low
Answer: a
Explanation: The anode is held at high potential and the filament is held at ground potential. Electrons are accelerated from the filament.
3. Which of the following is one of the most commonly used anode material?
a) Carbon
b) Tungsten
c) Magnesium
d) Cesium
Answer: c
Explanation: Magnesium is one of the most commonly used anode material. Aluminium is also commonly used.
4. Which is the most intense line in the X-ray spectrum?
a) Kα1
b) Kα2
c) Kα12
d) Kα22
Answer: c
Explanation: Kα12 is the most intense line in the X-ray spectrum. Different lines have specific energies.
5. Which of the following must be used with the X-ray source to have high energy resolution?
a) Chopper
b) Vacuum chamber
c) Accelerator
d) Monochromator
Answer: d
Explanation: Monochromator must be used with the X-ray source to have high energy resolution. It will also remove the satellite lines.
6. Magnetic deflection energy analysers are effective than electrostatic types.
a) True
b) False
Answer: a
Explanation: Magnetic deflection energy analysers are effective than electrostatic types. It is less convenient to design and use.
7. Double-pass cylindrical mirror energy analyser has how many mirrors?
a) One
b) Two
b) Three
d) Four
Answer: b
Explanation: Double-pass cylindrical mirror energy analyser has two mirrors. It is commonly used in electron spectroscopy.
8. In spherical sector analyser, __________ is detected and plotted as a function of energy.
a) Mass
b) Charge
c) Number of electrons striking the detector
d) Mass to charge ratio
Answer: c
Explanation: In spherical sector analyser, number of electrons striking the detector is detected and plotted as a function of energy. It is detected for a constant potential.
9. Which of the following is the most commonly used detector in ESCA and AES?
a) Electron multiplier
b) Dynodes
c) Photovoltaic cell
d) Photomultiplier
Answer: a
Explanation: Electron multiplier is the most commonly used detectors in ESCA and AES. It is similar to photomultiplier.
10. Electron detector has a _______ doped glass tube with a secondary semiconducting coating.
a) Quartz
b) Silica
c) Lead
d) Cesium
Answer: c
Explanation: Electron detector has a lead doped glass tube with a secondary semiconducting coating. It has a high secondary electron shield.
11. The output of the multiplier is fed to which of the following immediately?
a) Pulse amplifier discriminator
b) DAC
c) ADC
d) Multichannel analyser
Answer: a
Explanation: The output of the multiplier is fed to pulse amplifier discriminator. It is then fed to a multichannel analyser.
12. Which of the following is the ideal vacuum for electron spectrometers?
a) 10-6 torr
b) 10-7 torr
c) 10-8 torr
d) 10-9 torr
Answer: a
Explanation: 10-6 torr is the ideal vacuum for electron spectrometers. Vacuum below 10-6torr can also be used.
13. Which of the following is the most commonly used magnetic shielding?
a) Helmholtz coils
b) Ferro-magnetic shielding
c) Faraday shield
d) Magnetometer probe
Answer: b
Explanation: Ferro-magnetic shielding is the most commonly used magnetic shielding. Helmholtz coil can be used as alternative.
14. Charging effect can be suppressed by supplying flood of electrons having which of the following?
a) Uniform low energy
b) Uniform low mass
c) Uniform high energy
d) Uniform high mass
Answer: a
Explanation: Charging effect can be suppressed by supplying flood of electrons having uniform low energy. It also results in attainment of additional useful information.
15. Synchroton radiation has several advantages over conventional radiation.
a) True
b) False
Answer: a
Explanation: Synchroton radiation has several advantages over conventional radiation. The resolution is very high.
Spectral Method of Analysis Questions & Answers
Direct Method & Constructing of Liapunov for the Linear & Non-Linear System
Digital Circuits Questions & Answers
Standard Test Signals Objective Questions
Robotic Control System – Part I
Electrical Measurements and Instrumentation Objective Questions & Answers
Feedback Control Loop Questions & Answers
Time Response of Second Order Systems – II
State Variable Analysis – Part II
Hydrocarbons Questions & Answers
Linearizing Effect & Regenerative Feedback MCQ
Block diagram Algebra Objective Questions
Gas Solid Chromatography Questions & Answers
Time Response Analysis
Time Response of Second Order Systems – IV
Pulse Height Analyzer Questions & Answers
Construction of Root Loci
Liapunov’s Stability Analysis
Liapunov’s Stability Criterion – Part I
Stability in Frequency Domain
Assessment of Relative Stability Using Nyquist Criterion
Objective Questions of Building Fire and Gas Detectors
Nonlinear Control Systems
Stability of Nonlinear System
Inductive proximity switches
How to Connect Proximity Switch (Sink Type) to Make LED ON ?
Programmable Logic Controller (PLC) PLC Maintenance Check Points
Programmable Logic Controller Maintenance Check Points
Signal Flow Graphs Objective Questions
Fieldbus Segment Design
Foundation Fieldbus Segment Design
Keyphasor Principle
What is Keyphasor ? How does Keyphasor works ?
ESP8266 WiFi Module Projects
ESP8266 WiFi Module Projects for Engineering Students
Ball Valve Material Selection
Components of a Water Treatment Plant
Components of Water Treatment Plant
