Reading: Infrared Gas Detectors Working Principle
Inst Tools > Blog > Fire & Gas System > Infrared Gas Detectors Working Principle
Last updated: November 7, 2018 5:28 pm
Fire & Gas System
3 Min Read
The Infrared (IR) detection method is based upon the absorption of infrared radiation at specific wavelengths as it passes through a volume of gas. Typically two infrared light sources and an infrared light detector measures the intensity of two different wavelengths, one at the absorption wavelength and one outside the absorption wavelength. If a gas intervenes between the source and the detector, the level of radiation falling on the detector is reduced. Gas concentration is determined by comparing the relative values between the two wavelengths. This is a dual beam infrared detector.
Infrared gas detection is based upon the ability of some gases to absorb IR radiation. Many hydrocarbons absorb IR at approximately 3.4 micrometers and in this region H2O and CO2 are relatively transparent. As mentioned earlier, there are some hydrocarbons and other flammable gases that have poor or no response on a general purpose IR sensor. In addition to aromatics and acetylene, hydrogen, ammonia and carbon monoxide also cannot be detected using IR technology with general purpose sensors of 3.4 micron specifications.
Advantages
The major advantages of IR gas detectors:
  • Immunity to contamination and poisoning.
  • Consumables (source and detector) tend to outlast catalytic sensors.
  • Can be calibrated less often than a catalytic detector.
  • Ability to operate in the absence of oxygen or in enriched oxygen.
  • Ability to operate in continuous presence of gas.
  • Can perform more reliably in varying flow conditions.
  • Even when flooded with gas, will continue to show high reading and sensor will not be damaged.
  • Able to detect at levels above 100 % LEL.
Disadvantages
The limiting factors in IR technology:
  • The initial higher cost per point. IR detectors typically are more expensive than catalytic detectors at initial purchase.
  • Higher spare parts cost.
  • Gases that do not absorb IR energy (such as hydrogen) are not detectable.
  • High humidity, dusty and/or corrosive field environments can increase IR detector maintenance costs.
  • Temperature range for detector use is limited compared to catalytic detectors.
  • May not perform well where multiple gases are present.
Portable Gas Detectors Calibration Procedure
What is a Fusible Plug? – Working, Advantages, Disadvantages
Standard Gas Detection Definitions
Fire Extinguishers Mock Test
Fire and Gas (F&G) Mapping: Methodology, Performance Targets, Acceptance Criteria
Fixed Temperature Heat Detector Working Principle
Basic Guidelines for Selection of Fire and Gas Detectors
Basics of Sprinkler System
Gas Detectors Practical Problems and Troubleshooting
What is Fire Alarm System?
Safety Gas Analyzers
Interview Questions on Gas detection System
Types of Fire Detectors
oxygen Safety Analyzer
Oxygen Safety Analyzer
LEL vs Percent By Volume vs Parts Per Million vs Parts per Billion
Diesel Engine Fire Hydrant Pump
Fire Fighting System
What are Fire Branches?
Chlorine Cylinders
Chlorine Gas Hazards
Gas Detector Types
Sensor Technologies in Gas Detectors
Industrial Flame Detectors
Carbon Monoxide Gas Hazards
Falling Ball Viscometer Principle
Pressure Gauge Water traps and pigtail siphons
Pressure Gauge Water Traps and Pigtail Siphons
Gas Detectors Location Installation
Gas Detectors Installation Techniques
How to Implement Ratio Control in this System
How to Implement Ratio Control in this System?
Gas Detector Types
Codesys function block example
Create a User-Defined Function Block in Codesys
Ball Valve Pictures
How Ball Valves Work ?
Direct digital control principle
Direct Digital Control (DDC) Systems
