Reading: Impulse Line Purging and Close Coupling of Instruments
Inst Tools > Blog > Pressure Measurement > Impulse Line Purging and Close Coupling of Instruments
Impulse lines have high installation and maintenance costs, leaks and it is possible to eliminate these problems by using close coupling.
Last updated: September 28, 2022 2:33 pm
R Jagan Mohan Rao
By measuring the differential pressure across the flow elements like orifice, annubar, pitot tube, venturi, or other primary sensing devices, process flow measurements can be carried out.
What Causes Impulse Pipe Lines to get Plugged?Close CouplingAdvantages of Close CouplingLimitations in using Close Coupling
After contamination of fluid, if the flow sensor element clogs up or if it crystallizes, what happens to the impulse lines or sensor lines?
In the above two instances, causes large errors in the measurement of differential pressure.
In one solution, a flow of fluid can be introduced down the sensing lines and into the process flow. Purging of impulse pipeline eliminates stagnant fluid, which is a common source of the problem. The fluid can be liquid or gas that is inert to the process. Otherwise, it can be a small amount of actual process fluid.
Isolation of transmitters and flushing of the impulse lines is a common solution to solve the problem.
  • In case preventive maintenance routines are reduced, the chances of impulse line plugging happens. For example – Schedule four PM activities per year in a peculiar process plant, if it is reduced to two, the possibility of plugging in impulse lines can not be ruled out.
  • Process upsets – Differential temperatures, and other outs accomplishing process phase change are very rare cases in process industries, particularly in chemical plants. It may prove to be catastrophic.
  • Differential temperatures or other outputs accomplish process phase change.
Close Coupling
The compact mount manifold is an option that allows us to further simplify the design. If any application permits it, then this is a magnificent and simple solution.
Impulse lines can have high installation and maintenance costs, as well as challenges such as blockages, leak points, temperature control, and corrosion. It is possible to eliminate these problems by using a method called close coupling or close mounting, which eliminates lengthy impulse lines.
The process interface valve (PIV) and manifold become one unit, and the transmitter mounts directly on it. The whole integrated assembly is connected to the process line.
The solution is to opt for direct mount installations, but they have certain limitations. In certain installations, process interface valves and manifold blocks are separate but mounted very close to the process lines.
One of the limitations is the temperature. Traditionally, the impulse lines were used to protect the transmitter from the high temperatures of the process lines. A compact installation may not be able to perform if the process line is too hot due to its close proximity to the process lines.
Access is the second limitation. This is because it would not be practical to install a compact system 15 meters high, preventing access to the transmitter for calibration.
The last hurdle is the initial cost. Although a compact installation requires an initial investment, it may prove to be less expensive in the long run.
  • Prevents problems with freezing.
  • Short impulse lines are required to avoid pulsations in impulse lines. The shortest impulse lines are provided by close coupling.
  • Close coupling installation arrangement has remarkable benefits, piping gets greatly simplified.
  • The number of joints is reduced when the close coupling is used. As a result, leak routes at threaded connections and compression fittings are reduced.
  • A remarkable speed of response can be achieved with close coupling.
  • There is no need for heating tracing lines, or it is reduced to a minimum.
  • Close coupling eliminates errors caused by different densities of fluid in the separate lines.
  • Impulse lines may be required when the line temperature is too high or too low for the pressure transmitter.
  • As can be seen in the figure, between the length of pipe and differential pressure transmitter, there is still a length of tapping.
  • Although there is still a length of tapping between the impulse pipe and DP transmitter, it eliminates the requirement for impulse lines in the conventional sense.
Difference between Axial and Radial Diaphragm Seal Connection?
Information on the Pressure Gauge Dial
Well Manometer Principle
Scaling Sensor Output to Engineering Units
Differential Pressure Sensors Calibration Procedure
Pressure Gauge Water Traps and Pigtail Siphons
Differential Pressure Switch Principle
Pressure Measurement using Manometer
Diaphragm Pressure Sensors
What are Impulse Lines? – Impulse Line Problems & Solutions
What is a Barometer?
Pressure Measurement Objective Questions
Pressure Sensor Temperature Effects
Temperature Compensation for Pressure Measurement
Diaphragm Seal Transmitters Errors
Differential Pressure Transmitter Question
Differential Pressure Transmitter Questions
Pressure Transmitter Troubleshooting Tips
DP transmitter with Manifold
Pressure Transmitter Manifolds
Asymmetric capillary for Level Measurement
Effects of Symmetric and Asymmetric Capillary Tube Pressure Measurement
Direct Mounting of Diaphragm Seals Level Transmitter
What are the Mounting Techniques of Diaphragm Seals?
Pressure Gauge Calibration Procedure
Strain Gauge Bridge Circuit
Something is Wrong with Strain Gauge Bridge Circuit
PLC Digital Inputs
PLC Digital Input and Digital Output Modules
Free chlorine Analyzer Principle
Top 100 Power Electronics Questions & Answers
SCR Class B Resonant-Pulse Commutation
Thyristor Commutation Techniques – Types, Working Principles
WinCC data logging
How to Export Data from WinCC Runtime Advanced into Excel using VB Script
Auto Recloser Circuit Breaker in Power System
Dissolved oxygen measurement using Optical Fiber Communication
Fiber Optic Sensors
