Reading: Hydrogen and Glass Electrodes Questions & Answers
Inst Tools > Blog > Multiple Choice Questions > Hydrogen and Glass Electrodes Questions & Answers
Last updated: November 27, 2021 5:37 pm
7 Min Read
1. Which of the following is not the characteristic of a reference electrode?
a) It must have a known output potential
b) It must have a constant output potential
c) Its output potential is dependent on the composition of the solution
d) It is employed in conjunction with the indicator or working electrode
Answer: c
Explanation: The output potential of a reference electrode must be insensitive to the composition of the solution.
2. Why is Standard hydrogen electrode called as the primary reference electrode?
a) It has a known output potential
b) It has a constant output potential
c) Its output potential is independent of the composition of the solution
d) Its output potential is zero volts
Answer: d
Explanation: Standard hydrogen electrode is called the primary reference electrode as its output potential is zero volts. It is employed in conjunction with the indicator or working electrode.
3. Which of the following is the simple and most convenient hydrogen electrode?
a) Pascal Hydrogen electrode
b) Bourne Hydrogen electrode
c) Hilderbant Hydrogen electrode
d) West Hydrogen electrode
Answer: c
Explanation: The hydrogen electrode given by Hilderbant is the simple and most convenient hydrogen electrode. A number of hydrogen electrodes are available.
4. Which of the following is not the disadvantage of hydrogen electrode?
a) Platinum can be easily poisoned
b) Presence of oxidising agents alters the potential
c) It gives salt error
d) H2 gas at 1 atmospheric pressure is difficult to set up and transport
Answer: c
Explanation: Hydrogen electrode does not give salt error. A number of hydrogen electrodes are available.
5. In Hydrogen electrode, the electrode is placed in a solution of ____ M Hcl. Fill in the blank.
a) 0.5
b) 1
c) 2
d) 3
Answer: b
Explanation: In Hydrogen electrode, the electrode is placed in a solution of 1M Hcl. H2 gas at 1 atm pressure is passed through the side arm in such a way that the platinum is half immersed in Hcl.
6. Hydrogen electrode which is the reference electrode can be used as which of the following?
a) Anode only
b) Cathode only
c) Anode or Cathode
d) Salt bridge
Answer: c
Explanation: Hydrogen electrode which is the reference electrode can be used as the anode or the cathode. It depends on the half-cell to which it is coupled.
7. If hydrogen electrode acts as cathode, hydrogen is reduced.
a) True
b) False
Answer: a
Explanation: If hydrogen electrode acts as cathode, hydrogen is reduced. If hydrogen electrode acts as anode, hydrogen is oxidised.
8. Given below is a diagram of hydrogen electrode. Identify the unmarked component.
a) Hydrogen at 1 atm
b) Hydrogen at 10 atm
c) Helium at 1 atm
d) Helium at 10 atm
Answer: a
Explanation: Hydrogen at 1 atm is sent through the side tube. The electrode is placed in a solution of 1M Hcl.
9. The composition of glass membrane in glass electrode cannot have which of the following?
a) Sodium silicate
b) Calcium silicate
c) Lithium silicate
d) Barium silicate
Answer: d
Explanation: Glass electrode consists of either sodium or calcium silicate or lithium silicates containing glass membrane. It has lanthanum and barium ions added to the membrane.
10. Which of the following is the purpose of added membranes in the glass membrane of the glass electrode?
a) They act as tightners
b) They act as filters
c) They act as conditioners
d) They act as collectors
Answer: a
Explanation: The ions in the added membranes act as tightners. They reduce the mobility of sodium ion.
11. Which of the following cannot form the inner reference electrode in glass electrodes?
a) Silver electrode
b) Copper electrode
c) Calomel electrode
d) Silver chloride electrode
Answer: b
Explanation: Copper electrode cannot form the inner reference electrode in glass electrodes. Inner reference electrode is immersed in a buffer solution.
12. The pH response of glass electrode is limited entirely to the area of the special glass membrane bulb.
a) True
b) False
Answer: a
Explanation: The pH response of glass electrode is limited entirely to the area of the special glass membrane bulb. The response of the electrode is independent of the depth of immersion.
13. Which of the following is not the advantage of glass electrodes?
a) It gives accurate results for high as well as low pH values
b) It is simple to operate
c) It has no salt error
d) Modern electrodes can withstand severe treatment
Answer: a
Explanation: It gives accurate results for low pH values only ie. from 0 to 9. For high pH values, the glass becomes responsive to sodium and other cations.
14. Which of the following is not the disadvantage of glass electrodes?
a) Poor readings are obtained in buffered or unbuffered solutions
b) The electrode must be washed thoroughly with distilled water to obtain proper results
c) Materials suspended on glass should be wiped out neatly to obtain proper results
d) It is affected by oxidation reduction potentials in the solution
Answer: d
Explanation: It is affected by oxidation reduction potentials in the solution. It is an advantage of the glass electrode.
15. Given below is the diagram of glass electrode. Identify the unmarked component.
a) Platinum leads
b) Silver wire coated with silver chloride
c) Copper wire
d) Platinum reference electrode
Answer: b
Explanation: The unmarked component is silver wire coated with silver chloride. It forms the inner reference electrode.
Analytical Measurement Multiple Choice Questions
Pole Placement by State Feedback
Level and Density Measurement Objective Questions
Top 1000 Analytical Instrumentation Questions & Answers
Assessment of Relative Stability Using Nyquist Criterion
Magnetic Wind Instruments Questions & Answers
Encoder Multiple Choice Questions
Liapunov’s Stability Criterion – Part II
Parameter Optimization : Servomechanims
MCQ on Measurement and Instrumentation
X-Ray Fluorescence Spectrometry Questions and Answers
Feedback Control Questions & Answers
Feedback Control Loop Questions & Answers
Digital Control Systems
Spectrum Analysis of Sampling Process
Stability in Frequency Domain
Cascade Compensation in Frequency Domain
Pressure Measurement Multiple Choice Questions
Control Systems Stability and Algebraic Criteria
Concept of Stability in Control Systems
Gas Solid Chromatography Questions & Answers
Nitrogen Oxides Questions & Answers
Radiofrequency Mass Spectrometer
Difference between RCCB and RCBO
How-to do Security of SCADA Systems
How-to do Security of SCADA Systems?
Calibration of Weight
Calibration of Weight using the ABBA Method
electric valve actuator
Electrical Actuators
Siemens CPU MP Port
Siemens S7-300 CPU Suffix Explanation
Temperature Switch Working
Basics of Temperature Switch
Differential Pressure Flow Meters
Short Notes on Differential Pressure Flow Meters
Seismic Transducers Objective Questions
