Reading: HVAC Water Chillers Principle
Inst Tools > Blog > Common > HVAC Water Chillers Principle
Last updated: February 5, 2019 3:10 pm
Common
Water chillers are backbone of HVAC cooling systems.Water chiller is a refrigeration machine which produces chilled water ( Approx 7 Degree C ~ 12 Degree C).
The primary function of a chiller is to lower the temperature of water to such value such that it can be used for producing cooling effect in integration with other HVAC components.
A water chiller is just like a other refrigerator machine but instead of keeping your food cool or making ice,it produces chilled water.The output of chiller is a water at lower temperature usually around about 10 degC depending upon the Chiller design.
HVAC water chillers play vital role in any HVAC systems along with other basic components. Chillers have got much attention in recent years for its new designs and performance improvement in existing designs.
New designs have resulted inhvac chiller with better efficiency and less operation and maintenance costs. Another desirable features is energy saving and precise load or capacity control  for new chillers.
We see the chillers with above features in market but as engineering professionals we hope to see more with design improvements with less O & M cost. It is essential part of HVAC system to have a chiller. Chiller manufacturers have also expanded their production as well design capabilities to cater to the diversified demands of  HVAC chillers.
HVAC Chiller
Working Principle of Vapor Compression Chiller
An HVAC chiller works on vapor compression or vapor absorption cycle.In vapor compression cycle, refrigerant circulates in evaporator ,compressor, condenser and expansion valve of a chiller.
A thermodynamic process occurs in each of above chillers.Theoretical working of Vapor compression or compression chillers is explained below.
Working Principle of Water Chillers
Heat addition to refrigerant in evaporator ( 1-2) :
Refrigerant gets vaporized by taking heat from chilled water in evaporator thus serving its prime purpose. Refrigerant comes out of evaporator as vapors but on other side chilled water is produced.
Thus heat is added to refrigerant at constant pressure but is extracted from chilled water. Both refrigerant and chilled water don’t get mixed and are separated by some solid wall in between them in evaporator like shell and tube design.
Compression of refrigerant vapors in compressor (2 – 3 ) :
Refrigerant vapors come out of evaporator and then compressed by chiller compressor to high pressure and temperature. Compressor requires energy input for its working and hence electric energy is supplied to it.
Heat rejection by refrigerant in condenser ( 3 – 4 ) :
Similar to evaporator ,but reverse is happening here. Refrigerant rejects its heat to outside cooling liquid or air .In this way, refrigerant gets condensed and outside media is heated. outside media e.g. cooling water may be cooled by cooling tower and recycled again into condenser.
Expansion of refrigerant in expansion valve ( 4 -1 ) :
Refrigerant in condensed form coming out of condenser is expanded in expansion valve and its pressure and temperature is reduced to level of evaporator so that above cycle is repeated again.
In above four components of HVAC chiller, evaporator is the part where we get chilled water after exchanging heat with refrigerant.
Compressor Shutdown Job – Instrumentation Engineer Duties
Why is a Rupture Disc Required? – Functions & Selections
4-wire Transmitters Current Loops
Solar Photovoltaic Cells – Parts of the Solar Panel
How to Achieve Sustainability in UX Design and Make a Difference?
Difference Between Adhesion and Cohesion
  • Samarjit Debnath says:
    July 3, 2021 at 12:51 pm
    *is it safe if we apply chilled water at 10 degC instead of cooling water for cooling the refrigerant in chiller?
Job and Career Opportunities in Instrumentation Engineering
Understanding the Difference between HOP Test and OTDR
Types of Tachometers – Mechanical and Electrical Tachometers
What are Oil Burners? Types, Advantages, Applications
Difference Between Belt Conveyor and Roller Conveyor
Advancements in Lime Slaking Technology: What’s New And What’s Next
Top 100 Microcontrollers Project Ideas
Various Types of Engineering Courses
Automation in Agriculture
Automation in Farming & Agriculture
Instrumentation in Industries
Why is Instrumentation used in Industries?
International Standards - Types and their Details
International Standards – Types and Their Details
Career Opportunities and Scope in Industrial Automation
Thin Film Deposition Systems
What is a Thin Film Deposition System? How do they work?
Satellites Application in Agriculture
The Most Significant Developments in Satellite Technology
Critical Factors to Consider for Engineering Students to Ensure a Smooth Path
Plant Engineering Drawings
Piping and Instrumentation Drawing (P&ID) Tutorials – Part 1
Thyristor Family Quiz
number-systems-questions-answers
Measurement and Instrumentation Objective Questions – Part 4
Siemens CP Module
Communication Processor Module in Siemens PLC
Calculate Power in Series RCL Circuit
Impulse Line Problems
What are Impulse Lines? – Impulse Line Problems & Solutions
Communication Protocols in PLC
Various Communication Protocols in PLC
Why Baud Rate is Important in Modbus Network
Learn PLC in Hindi
Learn PLC in Hindi
