Reading: How to Connect Proximity Switch (Sink Type) to Make LED ON ?
Inst Tools > Blog > Practical Questions > How to Connect Proximity Switch (Sink Type) to Make LED ON ?
Last updated: June 6, 2018 9:56 am
Practical Questions
1 Min Read
An improvement over direct-contact limit switches for many applications is the inductive proximity switch. This type of switch actuates simply when an object gets near it – no direct physical contact necessary!
Explain how these devices work, and what kinds of material they are able to detect ?
Inductive proximity switches are powered devices by necessity. They usually require a DC voltage for power, and their output is usually not a dry switch contact. Instead, it is usually a transistor, with the output signal being standard TTL logic (0 to 5 volts). Inductive proximity switches are often manufactured as three-wire devices:
Reference : How to Connect Proximity Switch (Source Type) to Make LED ON ?
Show how you would connect the switch in the above illustration so that it makes the LED turn on when actuated, assuming the switch’s internal transistor is configured to sink current through the output lead.
Answer :
Share Your Answer / Comments
Credits : by Tony R. Kuphaldt – under CC BY 1.0
Calculate LRV and URV for 4-20 mA Loop-powered DP Transmitter
Calculate the Height of Glycerine
Draw Limit Switch Symbol ?
Problem on Weigh feeder
Practical Process Control System Questions & Answers – 2
Something is Wrong with Strain Gauge Bridge Circuit
PLC Programming Question & Answer
Pressure Level Transmitter Problems
A Question on Density Gauge
Programmable Logic Controller (PLC) Questions and Answers – 1
Pressure Transmitter using Potentiometer and Diaphragm
Questions on DP Transmitter Wet Leg Compensating Impulse Line
Identify the Pressure Gauge Error
Flow Transmitter Readings mismatch with DCS
Level Transmitter trend
Identify Level Control Loop Tuning Problems
Relay ladder diagram example
How to Draw a Schematic Diagram ?
Pneumatic Relay
Pneumatic Relay Questions
pressure transmitter calibration setup
Questions on Pressure Transmitter Calibration Setup
Which instrument is faulty
Which Instrument is Faulty? Transmitter, Recorder, or Controller
Baffle Nozzle Question
Analytical Control System of Heat Exchanger Questions
Landline Telemetry Objective Questions
Integral Wind-Up Limitation
What is Integral Wind Up ?
Two pressure switches
Identify Two Pressure Switches Logic
What is a Dosing Pump? - Types, Advantages, Applications
What is a Dosing Pump? – Types, Advantages, Applications
Advantages of HVDC transmission
Adaptive Controller Overview
What is Adaptive Control?
Unbalanced 3 Phase Loads
