Reading: Fluorescent Spectrometer Questions & Answers
Inst Tools > Blog > Multiple Choice Questions > Fluorescent Spectrometer Questions & Answers
1. Which of the following components of the X-ray fluorescent spectrometer induces fluorescent radiation?
a) Excitation source
b) Energy analyser
c) X-ray spectrometer
d) Detection System
Answer: a
Explanation: Excitation source induces fluorescent radiation in X-ray fluorescent spectrometer. A mono-energetic source is required for this purpose.
2. Why is a mono-energetic radiation source required in X-ray fluorescent spectrometer?
a) To provide good sensitivity
b) To provide high accuracy
c) To provide a proper range
d) To reduce unwanted background
Answer: d
Explanation: Mono-energetic radiation source is required in X-ray fluorescent spectrometer to reduce unwanted background. This occurs due to the scattering occurring over a broad range of wavelengths.
3. Which of the following does not make the X-ray tube nearly monochromatic?
a) Transmission-anode X-ray tube
b) Secondary fluorescence target
c) Slit
d) Filters
Answer: c
Explanation: Slits do not make the X-ray tube nearly monochromatic. The most commonly used source is X-ray tubes.
4. Which of the following components make use of a thin metal foil to isolate a nearly mono-energetic excitation beam?
c) Slit
d) Filters
Answer: d
Explanation: Filters make use of a thin metal foil to isolate a nearly mono-energetic excitation beam. Nickel is one of the metals that is used in filters.
5. Energy dispersive system uses which of the following detectors?
a) Optical detector
b) Semiconductor detector
c) Thermistor
d) Bolometer
Answer: b
Explanation: Energy dispersive system uses semiconductor detectors. It consists of an excitation source and a sample.
6. In Energy dispersive system, the energy level and the number of pulses is related to which of the following?
a) Amount of sample, element involved
b) Element involved, concentration of the element
c) Concentration of the element, element involved
d) Number of atoms, amount of sample
Answer: b
Explanation: In Energy dispersive system, the energy level is related to the element involved. The number of pulses is related to the concentration of the element involved.
7. The analysis of X-ray beam by diffraction is similar to spectrum analysis carried out with a diffraction grating.
a) True
b) False
Answer: a
Explanation: The analysis of X-ray beam by diffraction is similar to spectrum analysis carried out with a diffraction grating. Wavelength dispersive type of meter derives its name from this fact.
8. The crystal used as X-ray grating has _______ dimensional lattice arrays?
a) One
b) Two
c) Three
d) Four
Answer: c
Explanation: The crystal used as X-ray grating has three dimensional lattice arrays. Photons can be coherently scattered using the crystals.
9. Which of the following can be done to avoid loss of intensities of X-rays due to absorption of long wavelength X-rays?
a) Apparatus must be contained in a chamber
b) Air in the chamber must be replaced by helium
c) Inert gas atmosphere must be provided
d) Proper slits must be used
Answer: b
Explanation: Air in the chamber must be replaced by helium to avoid loss of intensities of X-rays due to absorption of long wavelength X-rays. Vacuum chambers can also be used.
10. In curved crystal arrangement, angular velocity of the crystal is twice that of the detector.
a) True
b) False
Answer: b
Explanation: In curved crystal arrangement, angular velocity of the detector is twice that of the crystal. This arrangement is suitable for the analysis of small specimens.
11. Which of the following is the disadvantage of silicon semiconductor detector?
a) Low stable
b) Can be operated only at low temperatures
c) Have low count-rate
d) Low resolution
Answer: b
Explanation: The disadvantage of silicon semiconductor detector is that they can be operated only at low temperatures. They have high stability, high count-rate and adequate resolution.
12. Given below is the diagram of energy dispersive system. Identify the unmarked component.
a) Lens
b) Specimen
c) Sample holder
d) Energy analyser
Answer: b
Explanation: The unmarked component is specimen. This system consists of source, sample and detector.
Concepts of State, State Variables & State Model
Measurement and Instrumentation Objective Questions – Part 4
Standard Test Signals Objective Questions
Actuators Questions and Answers
Instrumentation of ESR Spectrometer
Electrical Measurements and Instrumentation Objective Questions & Answers
Bode Plots MCQ
Design Considerations for Higher Order Systems
Pulse Height Analyzer Questions & Answers
X-Ray Fluorescence Spectrometry Questions and Answers
Analytical Measurement Multiple Choice Questions
Linearizing Effect & Regenerative Feedback MCQ
Ion Transducers Questions & Answers
Control Loops Multiple Choice Questions
Control Loop Multiple Choice Questions
Digital Circuits Questions & Answers
Logic Families Questions and Answers
Stepper Motor Parts
Stepper Motor MCQ
Programmable Logic Controllers Multiple Choice Questions
Differential Equations of Physical Systems & Dynamics of Robotic Mechanisms
Differences between No-load Supply Current and Load Current
Centrifugal Machine Field
Batch Type Centrifugal Automation in Sugar Industries
Process flow diagram examples
What is Process Flow Diagram (PFD) ?
Difference between ON-OFF Controller and PID Controller
Pneumatic Valves and Cylinders Sizing
Pneumatic Valves and Cylinders Sizing – Part 1
Testing of Pneumatic Systems
Panel and Field Pneumatic Controller’ Bumpless Transfer Issues
