Reading: What happens when Fluid Flow Reversed through Control Valve?
Inst Tools > Blog > Control Valves > What happens when Fluid Flow Reversed through Control Valve?
What would happen if we sent fluid flow through this control valve in reverse direction i.e. from right to left instead?
Last updated: February 4, 2022 12:35 am
Control Valves
2 Min Read
Explain why the direction of flow shown in the below image goes from left to right. What would happen if we sent fluid flow through this control valve in reverse direction i.e. from right to left instead?
fluid flow reversed through a Control Valve
If we were to use this valve “backwards,” the pressure drop across the plug would tend to “slam” it closed whenever it approached the closed position. In other words, the process fluid’s differential pressure drop would make it very difficult to maintain any plug position near full-closed.
This is actually an example of a mechanical feedback system. As the valve closes, the pressure drop across it (in most processes) usually rises because other pressure losses in the piping system decrease with decreased flow, leaving the valve to drop all the fluid pressure.
Since plug position has an effect on pressure drop, and pressure drop exerts a mechanical force on the plug, there is a system of feedback at work here.
In the proper flow direction, the feedback is negative: closing the valve results in greater pressure drop, which in turn tries to keep the valve open. In true negative feedback form, the feedback works against the initial action. The more the valve is closed, the more the process pressure tries to keep it open.
In the backwards flow direction, the feedback is positive: closing the valve results in greater pressure drop, which in turn tries to close the valve even more.
The result is a tendency for the system to saturate, staying open or slamming shut, but avoiding any in-between conditions. This makes it very difficult to position the valve mechanism near full-closed, and would result in erratic control near the lower end of the valve’s working range.
Why Restriction Orifice is some distance from Blowdown valve ?
What is Cavitation? What are the Causes?
Control Valve Parts Questions and Answers
Pneumatic Piping Design and Specification
5 Port 2 Position Valve Working Principle
Inspection and Test Requirement of Control Valves
Difference between Globe Valve and Gate Valve ?
What is Travel Stop in Control Valve?
What is Directional Control Valve (DCV)?
JT Valve Working Principle
Difference between Pneumatic, Electrical & Hydraulic Actuators
What is a Hydraulic Valve? and their Types
Bellows Seal Valve Working Principle
Difference Between Solenoid Valve and Motorized Valve
30% Feed Control Valve
Purpose of 100% and 30% Feed Control Valves in a Power Plant
cavitation-control valve trim
What is Control Valve Cavitation ?
Direct Acting Actuators
Effect of Differential Pressure on Control Valve Lift
CONTROL VALVE CHARACTERISTICS
Difference between Quick Opening, Linear & Equal Percentage Control Valve characteristics
How is pressure drop calculated through a valve?
How is Pressure Drop Calculated through a Valve ?
Incident Investigation: Motor Operated Valve Lesson
Valve stem travel
Control Valves Mechanical Friction Problems
Chocked flow
Control Valve Cavitation and Flashing
Turbidity Analyzer Working Principle
Solenoid Valve Terminology
Solenoid Valves Terminology
Measurement of Carbon Dioxide in Flue Gas
Car Parking System PLC Program Example
Schneider Electric: Car Parking System with Calculations in PLC
What is PID Controller
What is PID Controller?
Instrumentation Design Engineer
Role of an Instrumentation Design Engineer for Beginners
Difference between BDV and PSV
