Reading: What is Floating Neutral? – Electrical Engineering Basics
Inst Tools > Blog > Electrical Basics > What is Floating Neutral? – Electrical Engineering Basics
Floating neutral means the value of load keeps changing because there is no connection to neutral and there is no path for return current.
Last updated: July 11, 2023 12:41 pm
Electrical Basics
An electrical signal, as everyone knows, has three connections in it – phase, neutral, and earth. Every wire connection plays an important role in the safe passage of electrical signals through the load.
What is Floating Neutral?Effects of Floating Neutral
To summarize quickly, a phase wire is used to carry the main load current for the load; a neutral wire is used to carry the return current (very minimum or even negligible) back to the source and an earthing wire is used to carry the leakage current to the ground.
As our topic is related to the neutral wire, we will see it more deeply. In neutral wire, a common issue exists and if not corrected, it will damage the electrical circuit quickly. The issue is floating neutral.
A single-phase connection has one live wire whereas a three-phase connection has three live wires. They carry the required current for the load connected.
In an ideal condition, when the load connected is balanced, the sum of all the return currents from each phase to the load and back will be zero. This is because the load is consuming an equal amount of current from each of the phases. And as the neutral wire carries the return current, the current flowing through it will be zero.
Floating Neutral - Electrical Engineering Basics
But, this condition is only theoretical; it is difficult to execute it practically. The load takes different amounts of power from each of the phases (in a three-phase connection). A load can never take the same amount of power from each of the phases.
Because it is possible that one load may take 10W from one phase and the other may take 8W. In that case, the differential current will start to flow in the return line. So, a neutral wire will carry this return current back to the source and nullify the circuit. Thus, it helps in maintaining the return current of an unbalanced load.
Now, let us assume that the neutral wire is broken or not connected to the load. As for an unbalanced load, due to some return differential current that was flowing through the neutral wire, this condition will not happen now. In that case, the return current needs some path to flow and it will either flow through the load body or go in some other phase.
So, if a load is designed to carry only a rated amount of current and it suddenly gets this extra spike of current, then it will get damaged. Or else, if it flows through the load body, a person touching it can expose himself to electric shock.
So, a neutral wire is very important in carrying the load return differential current back to the source. Any improper connection of neutral means floating neutral, meaning the value of load keeps changing or floating because there is no connection to neutral and there is no path for return current.
  1. The first and foremost threat as discussed earlier is an increase or decrease in the voltage of any phase. A load connected in the corresponding phase may experience an abnormal out-of-range voltage, causing it to damage. It may even catch fire or result in permanent damage to the device.
  2. The second issue of floating neutral is the leakage through the device body. As the return current finds no path to escape, it will eventually flow through the device body, causing electric shocks for any accidental touch.
  3. A high abnormal spike through a circuit can trip a circuit breaker constantly and not allow the circuit to conduct the current.
Floating neutral is a very hazardous condition for an electrical system. It must be fixed by checking the neutral wire connection frequently and inspecting whether there is some leakage or breakage in the wire or not. Rust or corrosion after prolonged use can also result in damage to the wire, which must be prevented.
  • What is SMPS? – Types
  • What is a Buchholz Relay?
  • VFD Installation Engineer Roles
  • Cables between VFD & Motor
  • Drives Application Handbook
Motor Maintenance, Troubles, Regular Checks, Performance
Difference between KW and KVA
Residual Current Circuit Breaker (RCCB)
Difference Between Emergency STOP and Emergency Power OFF
Why Are Neutral and Earth Separated?
What is an Instrument Transformer? – Types, Principle, Advantages
Dahlander Motors – Principle, Advantages, Disadvantages
Electrical Voltage and current Signals
Automatic Transfer Switch – Electrical Circuit, Operation, Video
Electrical Switches Principle & Types
Difference Between Flame Resistant and Flame Retardant Cables
Electrical Engineering Documents – Engineers Questions
Variable Motor Speed Control
Difference Between Overcurrent and Overload
What is a Soft Starter
Difference between Analog Signal and Digital Signal
Types of Tripping Protection in MCCB
Group of Induction Motors
How to Operate a Group of Induction Motors using PLC Logic?
Difference Between Permittivity and Permeability
Bus Riser in Switchgear
Control Methods in Servo Motor Drives
Various Control Methods in Servo Motor Drives
Synchronous Motors Quiz
level gauge
Basics of Sight Glass Level Gauge
Loop Diagram
15 Loop Diagram Questions
Use of Temperature Transmitters instead of Direct Wiring
Power Systems MCQ Series 7
Servo Level Transmitter Principle
How Does Starlink Work
How Does Starlink Work?
P&ID Legend
What is a Legend? – Piping and Instrumentation Diagram
