  • Ask
  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Example PLC Program
  • PLC Tutorials
  • Control Systems
  • Ask
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > PLC Tutorials > Example PLC Program
Example PLC Program
A PLC has been programming to control the starting and stopping of a three-phase electric motor.
Last updated: March 4, 2021 10:59 am
PLC Tutorials Practical Questions
2 Min Read
Example PLC ProgramAnswer:
Shown here is a partial wiring diagram and offline PLC program display for the system:
Example PLC Program
Example PLC Program
Identify the problem(s) in this PLC program, and modify it so that it will work as it should.
Answer:
The PB_stop and OL_switch instructions in the second rung of the PLC program need to be connected in parallel with each other rather than in series.
Being NC real-world switches and NC contact instructions, each one will “color” when the motor is supposed to stop (i.e. the PB_stop instruction colors when anyone presses the Stop pushbutton, and the OL_switch instruction colors when the motor overheats).
Right now, programming in series with each other, both conditions would have to take place in order to stop the motor!
To make the motor stop if either condition occurs, we need these two instructions to be programmed in a logical “OR” fashion, and that necessitates a parallel connection between the two contact instructions.
More PLC Questions :
PLC Programming Questions & Answers – 1
PLC Programming Questions & Answers – 2
PLC Programming Questions & Answers – 3
PLC Programming Questions & Answers – 4
PLC Programming Questions & Answers – 5
PLC Programming Questions & Answers – 6
PLC Programming Questions & Answers – 7
OPC in Old PLC Systems
Question on Remote Seal with Capillary Tubing Transmitter
Automatic Empty Bottle detection using PLC Logic
PLC Program to Read Temperature in PLC
  • Paul Nguyen says:
    September 27, 2021 at 2:52 am
    It seems to be wrong for this answer.
208kSubscribersSubscribe
Recent Comments
Related Articles
Using Clock Memory Bits in TIA Portal - Siemens PLC
Control Panel
Door Lock with Delay PLC Exercise Problems
Simulator in S7-1200 and S7-1500 PLC
How to Work With Simulator in S7-1200 and S7-1500 PLC?
PLC Logic for Water Pumping and Chemical Addition
Developing PLC Logic for Water Pumping and Chemical Addition
VFD Braking
DC Injection Braking in VFD
More Articles
dispersive gas analyzer
Dispersive Spectroscopy
DO Analyzer Working Principle
Dissolved Oxygen Analyzer Working Principle
Analog Input Card Resolution Effects on Accuracy
PLC Analog Input Card Resolution Effects on Accuracy
pi filter Operation
pi filter Operation
PLC Commissioning and Testing
PLC Commissioning and Testing Procedure (Programmable Logic Controller)
100 Instrumentation Questions
100 Instrumentation Basics Questions
What is Loop Checking
What is Loop Checking?
ungrounded-or-isolated-neutral-system-disadvantages
Ungrounded or Isolated Neutral System Disadvantages
