Reading: How Engineers Effectively do Problem-solve and Troubleshoot?
Inst Tools > Blog > PLC Tutorials > How Engineers Effectively do Problem-solve and Troubleshoot?
Last updated: March 4, 2021 1:12 pm
PLC Tutorials Control Systems
The basic fundamentals and practical problem-solving skills required for the engineers to effectively troubleshoot the issue in the industries.
Engineers Problem-solve and TroubleshootGeneral follow-up challenges for assigned problems
Rely on principles, not procedures.
Don’t be satisfied with memorizing steps – learn why those steps work. Each step should make logical sense and have real-world meaning to you.
Sketch a diagram
Sketch a diagram to help visualize the problem. Sketch a graph showing how variables relate. When building a real system, always prototype it on paper and analyze its function before constructing it.
Identify
Identify what it is you need to solve, identify all relevant data, identify all units of measurement, identify any general principles or formulae linking the given information to the solution, and then identify any “missing pieces” to a solution. Annotate all diagrams with this data.
Perform “thought experiments”
Perform “thought experiments” to explore the effects of different conditions for theoretical problems. When troubleshooting, perform diagnostic tests rather than just visually inspect for faults.
Simplify the Problem
Simplify the problem and solve that simplified problem to identify strategies applicable to the original problem (e.g. change quantitative to qualitative, or visa-versa; substitute easier numerical values; eliminate confusing details; add details to eliminate unknowns; consider simple limiting cases; apply an analogy). Remove components from a malfunctioning system to simplify it and better identify the nature and location of the problem.
Check for Exceptions
Check for exceptions – does your solution work for all conditions and criteria?
Work backward
Work “backward” from a hypothetical solution to a new set of given conditions.
Identify where any fundamental laws or principles apply to the solution of the problem.
Analyze the details in your own strategy for solving the problem. How did you identify and organized the given information? Did you sketch any diagrams to help frame the problem?
Is there more than one way to solve the problem? Which method seems best to you?
Analyze the work you did in solving the problem, even if the solution is incomplete or incorrect.
What would you say was the most challenging part of the problem, and why was it so?
Was any important information missing from the problem which you had to research or recall?
Was there any extraneous information presented within the problem? If so, what was it and why did it not matter?
Examine someone else’s solution (previous or similar) to identify where they applied fundamental laws or principles.
Simplify the problem from its given form and show how to solve this simpler version of it. Examples include eliminating certain variables or conditions, altering values to simpler (usually whole) numbers, applying a limiting case (i.e. altering a variable to some extreme or ultimate value).
For quantitative problems, identify the real-world meaning of all intermediate calculations: their units of measurement, where they fit into the scenario at hand.
For quantitative problems, try approaching it qualitatively instead, thinking in terms of “increase” and “decrease” rather than definite values.
For qualitative problems, try approaching it quantitatively instead, proposing simple numerical values for the variables.
Were there any assumptions you made while solving this problem? Would your solution change if one of those assumptions were altered?
Identify where it would be easy for someone to go astray in attempting to solve the problem.
Formulate your own problem based on what you learned solving this one.
Share Your Experiences, Principles, Problem-solving skills with us through comments.
Zener Diode Barrier Principle
Light ON OFF Control using PLC
Functional Design Specifications for DCS and SIS Projects – FDS Document
XG5000 Example of Simple Conveyor Control PLC Program
STL Programming – SET, RESET, ASSIGN
PLC Program for Password Management using Structured Text
PLC Instruction List for Motor Reverse and Forward Direction
Remote Factory Acceptance Test
PLC Count values higher than 999
Determine Voltage Drops at Respective Flow Rates in Loop Diagram
Ladder Logic Vs. Other Programming Languages – PLC Basics
SFC Language in PLC Programming
Problem on PLC, HMI, VFD, and Motor Circuit
PLC Program for Conveyor Motor
PLC Conveyor Motor Ladder Logic
ESG in Industrial PLC Automation Systems
PLC Program
Example PLC Program
Conveyor Sorting Omron PLC Programming
CX-Programmer Products Sorting & Counting – Omron PLC
PLC Program
PLC Program to Heat and Bend Glass Tubes
Interview Questions on Transmission & Distribution
Solar Energy
Types of Renewable Energy Sources
R R-C Firing Circuits Disadvantages
What is a K Factor
Flow Meter K-factor and Calculations
Bubbler Level Measurement Animation
Timer-based vacuum cleaner in Schneider PLC
Schneider Electric PLC Timer Problem: Vacuum Cleaner
Radar Level Transmitter in Briddle level Measurement
