Reading: Encoder MCQ – Electrical Drives Technology
Inst Tools > Blog > Electrical MCQ > Encoder MCQ – Electrical Drives Technology
Test your knowledge of encoders with this MCQ which covers types, working principles, and applications in electrical drives technology.
Last updated: July 24, 2024 4:50 pm
Electrical MCQ
7 Min Read
Encoder MCQWhat is the primary function of an encoder?Which type of encoder is commonly used in robotics for position feedback?What does a Gray code encoder help minimize?How does an incremental encoder differ from an absolute encoder?In a rotary encoder, what component is typically used to detect the position?What is a common application of linear encoders?What coding scheme is often used in encoders to reduce the possibility of errors?Which of the following is NOT a type of encoder?In an incremental encoder, what indicates the direction of rotation?What is the main advantage of using an absolute encoder over an incremental encoder?Which technology is commonly used in optical encoders?What is the purpose of a quadrature encoder?How do magnetic encoders detect position?Which output signal type is often used by encoders for digital systems?What does the term “resolution” in an encoder refer to?Why is a reference signal (index) used in incremental encoders?Which of these applications would most likely use an absolute encoder?How does a capacitive encoder work?What is a typical feature of a multiturn absolute encoder?Which type of encoder provides the highest accuracy in harsh environments?What is the primary disadvantage of an optical encoder?Which part of an incremental encoder generates the pulses?How is the resolution of a rotary encoder commonly expressed?What does an encoder’s “linearity” refer to?Which of the following is a benefit of using a digital encoder over an analog encoder?
Encoder MCQ
We recommend viewing the below video to learn the explanations for the encoder questions.
Encoder Questions and Answers - Electrical Basics
Question 1
A. Decode a signal
B. Store data
C. Convert input to coded output
D. Amplify a signal
Show the Answer
Question 2
A. Optical encoder
B. Magnetic encoder
C. Linear encoder
D. Rotary encoder
Show the Answer
Rotary encoder
Question 3
A. Signal strength
B. Wiring complexity
C. Power consumption
D. Error due to signal change
Show the Answer
Question 4
A. Measures speed only
B. Provides position on power-up
C. Uses binary code
D. Measures linear motion
Show the Answer
Question 5
A. Capacitor
B. Photodetector
C. Resistor
D. Inductor
Show the Answer
Photodetector
Question 6
A. Audio signal processing
B. Digital communication
C. CNC machine tools
D. Wireless networking
Show the Answer
CNC machine tools
Question 7
A. ASCII code
B. Binary code
C. Gray code
D. Morse code
Show the Answer
Gray code
Question 8
A. Optical encoder
B. Digital encoder
C. Magnetic encoder
D. Analog encoder
Show the Answer
Analog encoder
Question 9
A. Pulse width
B. Pulse count
C. Dual-channel signals
D. Signal amplitude
Show the Answer
Question 10
A. Higher resolution
B. Lower cost
C. Immediate position on power-up
D. Simpler design
Show the Answer
Question 11
A. Reflective tape
B. Hall effect sensors
C. Photodiodes and slits
D. Capacitive plates
Show the Answer
Question 12
A. To measure temperature
B. To track angular position and direction
C. To convert digital signals to analog
D. To amplify signals
Show the Answer
Question 13
A. Using light sensors
B. By detecting changes in magnetic fields
C. Using resistive elements
D. By measuring voltage
Show the Answer
Question 14
A. Analog voltage
B. Current loop
C. PWM signal
D. Binary code
Show the Answer
Binary code
Question 15
A. Size of the encoder
B. Number of positions it can measure
C. Speed of rotation
D. Power consumption
Show the Answer
Question 16
A. To reduce noise
B. To reset the position counter
C. To increase resolution
D. To decrease power usage
Show the Answer
Question 17
A. Audio recording
B. Wind turbine positioning
C. Data storage
D. Internet routing
Show the Answer
Question 18
A. By detecting changes in light
B. By measuring magnetic fields
C. By sensing changes in capacitance
D. By amplifying signals
Show the Answer
Question 19
A. Measures only one rotation
B. Tracks multiple rotations
C. Uses only binary code
D. Limited to short distances
Show the Answer
Question 20
A. Optical encoder
B. Magnetic encoder
C. Capacitive encoder
D. Resistive encoder
Show the Answer
Magnetic encoder
Question 21
A. High cost
B. Limited accuracy
C. Susceptibility to dirt and dust
D. Complex signal processing
Show the Answer
Question 22
A. Index marker
B. LED
C. Disk with patterns
D. Capacitor
Show the Answer
Disk with patterns
Question 23
A. Degrees per second
B. Pulses per revolution (PPR)
C. Volts per degree
D. Amperes per second
Show the Answer
Question 24
B. Signal amplitude variation
C. Power usage efficiency
D. Consistency of output with input
Show the Answer
Question 25
A. Higher noise sensitivity
B. Easier signal degradation
C. Simplified signal processing
D. Higher power consumption
Show the Answer
  • How to Select the Right Encoder?
  • VFD Interview Questions and Answers
  • Top 100 Power Systems Projects
  • Electrical Components Overheating & Causes
  • Electrical Drives and Controls Interview Questions
DC Machines MMF & Flux Density Waveforms Quiz
Power Systems MCQ Series 21
Synchronous Machines Efficiency Questions
100+ Quiz on Electrical Circuits and Control
264 Quiz on Electrical Drawings and Symbols
Electric Circuits Objective Questions – Set 18
Electric Circuits Objective Questions – Set 14
Power Flow Through an Inductive Impedance Questions
Top 300 Electrical Circuits Objective Questions and Answers
MCB Nameplate Questions and Answers
DC Machines Excitation Quiz
125+ Single-Phase Induction Motors Multiple Choice Questions (MCQ)
Synchronous Motor Phasor Diagram Questions
Parallel Operation of Single Phase Transformers
illumination Multiple Choice Questions and Answers
illumination Multiple Choice Questions and Answers (MCQ)
Transformer Open Circuit and Short Circuit Test
Motor Losses and Efficiency Quiz
Open Loop and Closed Loop System Questions
Electric Circuits Objective Questions – Set 13
Illumination Objective Questions
Power Systems MCQ Series 10
Electric Circuits Objective Questions – Set 17
Best Software to Use to Improve Your Business
Best Software to Use in 2023 to Help Improve the Effectiveness of Your Business
4-Wire, Three-Phase Delta Wiring System
fire alarm system operation
What is Fire Alarm System?
Difference between Power Cables and Signal Cables
WirelessHART Device Terminals
WirelessHART Network Gateway Device
Pressure Sensor Temperature Effects
Temperature Compensation for Pressure Measurement
Difference between Calibration and Ranging
Avoid Process Downtime With Five Device Protection Considerations
How to Avoid Process Downtime ?
