Reading: Difference Between Overcurrent and Overload
Inst Tools > Blog > Electrical Basics > Difference Between Overcurrent and Overload
In this post, we will learn the difference between overcurrent and overload in an electrical circuit.
Last updated: September 28, 2022 3:44 pm
Electrical Basics
In this post, we will learn the difference between overcurrent and overload.
Difference Between Overcurrent and OverloadWhat is Overcurrent?What is Overload?Differences
There are so many concepts in an electrical circuit that one often gets confused with their names. Many terms have similar meanings.
One needs to just understand its basic meaning. When we are talking about this, two terms that are often co-related with each other are – overload and over-current.
Often, engineers get confused on both these terms. They consider both of them as equal. But, it is not like that.
Though they have many similarities, it is also true that they have some differences too. They are not exactly the same. In this post, we will see the difference between overload and over-current.
As the name suggests, it is a condition where the current flows in the circuit in excess quantity. Normally, when a fault occurs, a current is diverted to an undesired path because of failure of insulation or other abnormal conditions. The current drawn from such a line is also called an overcurrent. Every device has its rated current ratings. When this current is exceeded, it is called overcurrent.
Overcurrent is caused by numerous conditions. A short circuit is the common cause of overcurrent. When two phase wires or phase and neutral wires come in contact with each other, a short circuit occurs. A short circuit has a very low resistance path; so, a large amount of current flows through the device and damages it.
Another reason is the ground fault current. In a normal circuit, line and neutral currents will always be equal and balanced. But, whenever there is an earth leakage, as the leakage current flows through the earth, there will be an imbalance in both these currents as the line current will be higher than the neutral current. This difference in current is called residual current.
Also, ground fault can be defined when a ground wire comes in contact with the conducting wire. Both these conditions can create arc or spark; and can endanger the personnel or surrounding nearby.
What is Overload?
If you see the previous section where we discussed how overcurrent occurs, it must also be noted that overload too is a factor in causing overcurrent.
So, basically, overload is a sub-category of overcurrent. When you are connecting a load that takes the total load rating to a higher level than the rated total, then it will cause overload.
This means, that for a 12A MCB, if you are connecting devices that will draw a current of up to 16A, then it means you are overloading the MCB. This will cause a large amount of extra current (over current) to flow and will trip the MCB. So, overload is also a condition that causes overcurrent.
Differences
This is the difference between overload and overcurrent. Overcurrent can occur through any factor, and overload is one such factor. So, you can say that the overload category comes under the overcurrent category.
In this way, we understand the difference between overload and overcurrent.
Testing of Thermal Protection Relay for Motors
Effects of Long Distance Cables between VFD and Motor
Top 100 Electrical Machines Projects for Electrical Engineers
What is SMPS? – Types of SMPS
4-20mA Linear Conversion Calculation for VFD Drive (Formula)
Types of Stepper Motors
Why is IGBT used in VFD?
Working Principle of Overload Relay
Difference Between MCB and RCBO
Residual Current Circuit Breaker (RCCB)
Circuit Breaker Working Principle Animation
Difference between Soft Starter and VFD
Difference between Servo Motor and DC Motor
SCADA in Power System
Electrical Energy Management System and SCADA in Power System
Types of Circuit Breakers
Types of Circuit Breakers, Advantages, Disadvantages
Difference Between Emergency STOP and Emergency Power OFF
Motor Maintenance
Motor Maintenance, Troubles, Regular Checks, Performance
Why is HV Testing important in Electrical Panels?
Typical Switchyard Layout
Electrical Substation – Busbar Arrangements and Layouts
PLC and MCC Panel Interface Design
Ethernet IP Commissioning Tool software
How to Configure IP Address in Rockwell PLC?
Boiler Light-Up Sequence - Power Plant Operation
Boiler Light-Up Sequence – Power Plant Operation
Valve Standards
List of Valve Standards
how-to-select-a-fuse
How to Select a Fuse ?
Capacitance-Level-Transmitter
Capacitance Level Switch Calibration
Transistor Stabilisation
Standard Operating Procedure
IEC 61508
What is IEC 61508 ?
