Reading: Difference between Force and Power
Inst Tools > Blog > Common > Difference between Force and Power
In this article we will have a detailed discussion on both the force and the power. We will see the difference between force and power.
Last updated: May 3, 2023 9:53 am
vicky
Common
One of the most confusing topics for many of us is the difference between force and power. The difference between force and power is very simple, but many times we face difficulties in justifying the difference.
ForcePowerDifference between Force and Power
Today in this article we will have a detailed discussion on both the force and the power. We will learn the difference between force and power.
Force
Force acts upon two bodies when they interact with each other. The force can be a push-type force or a pull-type force experienced by a body.
The external force acting on any given body is responsible for that body having motion or that body in the state of rest. One of the most famous laws describes force. Newton’s first law describes the force in a very simple way.
Newton’s first law states that a body will continue its motion if it is in motion or remains in rest if it is in rest unless and until an external force is applied to that body.
Force is basically of two types. One is contact type force and the other is non-contact type force. Examples of contact type force are frictional force, spring force, tensile force, etc. Examples of non-contact type force are gravitational force, magnetic force, etc.
Newton’s second law defines the force in a quantitative way. Newton’s second law states that the force acting on a body is dependent on both the mass and the acceleration action upon that body.
Force = Mass * Acceleration
F = m * a
The SI unit of the force is Newton denoted by N. Another unit of the force is (kg*m / s2)
Power
Power gives the amount of energy consumed to do work in a given unit of time. In other words, we can also say that the rate at which the work is done is power.
Power = Work Done / Time Consumed
P = W / T
Now work done is the product of the force applied on that body and displacement of that body.
Hence,
Power = Force * Displacement / Time
The SI unit of the power is Watt.
Now let us see the differences between the force and the power
ForcePower
A push or pull experienced by anybody is termed as forceThe rate at which work is done is termed as power
The SI unit of the force is NewtonThe SI unit of the power is Watt
Force is denoted by ‘F’Power is denoted by ‘P’
The formula used for calculating force is
Force = mass * acceleration
The formula used for calculating power is Power = Word Done / Time Taken
Force is dependent on the mass of the body and acceleration acting upon a bodyPower is dependent on the force acting on a body, the displacement of the body, and the time taken for it. (Here, work is the product of the force and displacement)
For a given body at rest, some force may be acting on it depending on the position of the body (For example a body hanging vertically needs some force against the gravitational pull force to remain hanging)For a given body a rest, no power can be acting upon that body as the displacement is 0.
Strip Chart Recorder Working Principle
Thread Sealant Types and Selection for Instrumentation Applications
Advancements in Lime Slaking Technology: What’s New And What’s Next
Pirani Gauge Working Principle
Capacity Control of Absorption Chillers
Laser Doppler Anemometer
Static and Dynamic Characteristics of an Instrument
What is PPE? – Types – Personal Protection Equipment
What is Fuzzy Logic? Advantages, Disadvantages, Applications
4 Tips For Shipping Large Construction Equipment
Custom CNC Machining – A Complete Guide You Cannot Miss
Top 10 Podcasts about Electronics
What is a Viscometer? – Types, Applications, Advantages
What is Eddy Current and Eddy Current Loss?
Instruments Troubleshooting - Problems, Causes, Corrective Actions
Instruments Troubleshooting – Problems, Causes, Corrective Actions
Tube Fitting Parts
Procedure for Crimping the Connector
Moving Coil Type Velocity Transducer
Bracelet Scanner
How to Use Bracelet Scanner? – Ultrasonic Thickness Gauge
Pneumatic Level Control Valve
2 wire transmitter current loops
Metric Prefixes and Unit Conversions
Encoder Principle
Encoder Working Principle
Motor Control Center Purpose
Motor Control Center – Purpose, Classification, and Advantages
Determine the Problems with the Level Transmitter and Gauge
Determine the Problems with Level Transmitter and Gauge
PLC Program three-phase electric motor
Identify the Problem in the PLC Program
Ultrasonic-Level-Transmitter-Animation
Ion Analyzers Questions and Answers
Ion Selective Electrodes Questions and Answers
Twisted Pair Cable Noise Supression
Why We use Shielded Cable and Twisted Pair Cables ?
V Cone Flow Meter Working Principle
V Cone Flow Meter – Principle, Advantages, Disadvantages
circuit-breaker-working-principle-animation
Circuit Breaker Working Principle Animation
