  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Detection System of Gas Chromatography Questions and Answers
  • PLC Tutorials
  • Control Systems
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Multiple Choice Questions > Detection System of Gas Chromatography Questions and Answers
Last updated: November 27, 2021 5:37 pm
7 Min Read
1. Which of the following is not an ideal characteristic of a detector used in gas chromatography?
a) Linear response to the solutes
b) Short response time
c) High reliability
d) Sensitive to the changes in the flow rate of carrier gas
Answer: d
Explanation: The detector used in gas chromatography must be insensitive to the changes in flow rate of carrier gas. There are many detectors used in gas chromatography.
2. Which of the following is not a type of detector used in gas chromatography?
a) Argon ionisation detector
b) Thermal conductivity detector
c) UV visible spectrometric detector
d) Electron capture detector
Answer: c
Explanation: UV visible spectrometric detector is not used in gas chromatography. It is used in liquid chromatography.
3. Which of the following detectors have high sensitivity to all organic compounds?
a) Sulphur chemiluminescense detector
b) Thermionic emission detector
c) Flame ionization detector
d) Argon ionisation detector
Answer: c
Explanation: Flame ionization detector has high sensitivity to all organic compounds. It is the commonly used detector for gas chromatography.
4. Which of the following is not the advantage of thermal conductivity detector used in gas chromatography?
a) Simple in construction
b) High sensitivity
c) Large linear dynamic range
d) Non-destructive character
Answer: b
Explanation: Thermal conductivity detector has relatively low density when compared to other detectors used in gas chromatography. It is based on the principle that all gases conduct heat in varying degrees.
5. Which of the following detectors is widely used to detect environmental samples like chlorinated pesticides and polychlorinated biphenyls?
a) Flame ionization detector
c) Argon ionisation detector
Answer: d
Explanation: Electron capture detector is used to detect environmental samples like polychlorinated biphenyls and chlorinated pesticides. It is highly sensitive to molecules containing functional groups such as halogen and phosphorous.
6. In which of the following detector is the eluent mixed with hydrogen and burned and then mixed with ozone and its intensity is measured?
Answer: a
Explanation: In Sulphur chemiluminescense detector, the eluent is mixed with hydrogen and burned and then mixed with ozone and its intensity is measured. The resultant is a measure of sulphur compounds present.
7. Filter photometer detector is primarily responsive to which of the following compounds/elements?
a) Volatile sulphur or phosphorous compounds
b) Nitrogen
c) Halogen
d) Potassium
Answer: a
Explanation: Flame photometric detector is primarily responsive to volatile sulphur or phosphorous compounds. It is also responsive to tin and nitrogen.
8. Which of the following detector uses ultraviolet radiation from lamps to produce ionisation of solute molecules?
c) Photo ionization detector
Answer: c
Explanation: Photo ionization detector uses ultraviolet radiation from lamps to produce ionisation of solute molecules. The current produced is measured and recorded.
9. Flame ionisation detector is also known as Katharometer.
a) True
b) False
Answer: b
Explanation: Thermal conductivity detector is known as Katharometer. It uses heated filament as sensing element and it is placed in the emerging gas stream.
10. Thermionic emission detector used in gas chromatography is most sensitive to which of the following elements?
a) Nitrogen
b) Phosphorous
c) Halogen
d) Carbon
Answer: b
Explanation: Thermionic emission detector used in gas chromatography is most sensitive to phosphorous. It is 500 times more sensitive to phosphorous than Flame ionization detector.
11. Which of the following detectors has a non-volatile bead of rubidium silicate placed above the flame tip?
Answer: b
Explanation: Thermionic emission detector has a non-volatile bead of rubidium silicate placed above the flame tip. It is maintained at about 180V with respect to the collector.
12. In which of the following detectors, the carrier gas is excited by a radioactive source and the atoms of carrier gas are excited to metastable state?
Answer: a
Explanation: In Argon ionisation detector, the carrier gas is excited by a radioactive source and the atoms of carrier gas are excited to metastable state. It uses argon as carrier gas.
13. Which of the following is not used as a heating element in Thermal conductivity detector?
a) Platinum
b) Gold
c) Graphite
d) Tungsten wire
Answer: c
Explanation: Graphite is not used as heating element in Thermal conductivity detector. Platinum, gold and tungsten wire are used as heating elements.
14. Electron capture detector is much less susceptible to contamination when nickel is used instead of tritium.
a) True
b) False
Answer: a
Explanation: Electron capture detector is much less susceptible to contamination when nickel is used instead of tritium. The sensitivity of nickel is less than that of tritium.
15. Given below is a diagram of electron capture detector. Identify the unmarked component in the diagram.
a) Glass shield
b) Electrode
c) Quartz shield
d) Radioactive β- emitter
Answer: d
Explanation: The unmarked component is Radioactive β- emitter. Nitrogen and hydrogen are the best carrier gases for these detectors.
Nuclear Magnetic Resonance Spectrometer Questions & Answers
Infrared Spectrometers Questions & Answers
State Variables & Linear Discrete Time Systems
Analytical Measurement Multiple Choice Questions
Time Response of Second Order Systems – IV
Fourier Transform NMR Spectroscopy Questions & Answers
208kSubscribersSubscribe
Sensivity Enhancement for NMR Spectroscopy Questions & Answers
Level and Density Measurement Objective Questions
Process Pressure Measurement Objective Questions
Assessment of Relative Stability Using Nyquist Criterion
Stability Analysis
Instrumentation Diagrams Multiple Choice Questions
Pneumatic Systems Objective Questions
Total Reflection Spectrometer Questions & Answers
Transmission and Distribution Interview Questions
Measurement and Instrumentation Objective Questions – Part 3
Split-Range, Auto-Selector Ratio, And Cascade Systems
Split-Range, Auto-Selector, Ratio & Cascade Systems
Industrial safety Objective Questions and Answers
Top 10 Industrial safety Objective Questions
Time of Flight Mass Spectrometer
Time Response Analysis
State Variable Analysis – Part I
Control Systems Stability and Algebraic Criteria
Relative Stability Analysis
Advances in Control System
Fuzzy Logic Control
Stability in Frequency Domain
Mathematical Preliminaries
Discover More
Field Instruments Selection Aid
Bucket Steam Trap
Bucket Steam Trap
Valve Standards
List of Valve Standards
BJT Amplifiers Interview Questions & Answers
Capacitive Time Constant for Charging Capacitor
Bias in Proportional Controller
Why Bias used in Proportional Controller ?
Allen Bradley PLC communication is established
Procedure for Connecting Allen Bradley PLC and PC – RS Logix 500
What is electrical transformer
Basics of Electrical Transformer
