Reading: How to Create Project in Wonderware Intouch?
Inst Tools > Blog > PLC Tutorials > How to Create Project in Wonderware Intouch?
Last updated: March 4, 2021 12:31 pm
3 Min Read
Wonderware InTouch is famous SCADA software used to visualize and control the processes by using an animated design like a plant layout.
In this article, we will learn to create a new project with an example in Wonderware InTouch SCADA software. Let’s follow the below steps.
Step 1:
Open InTouch. Click on “file” and select “new”. Following window will pop-up. Click “next” to proceed.
Step 2:
Clicking next will pop-up another window. Here, give a name and click “next”.
Creating Project in Wonderware Intouch
Step 3:
Again another pop-up will open. Give name here too and click “finish”.
Step 4:
The created project name will be added as shown in the below window.
Double click on it. If it asks for the license the click on ignore to proceed.
Wonderware Intouch Project
Step 5:
The following window will appear as shown below.
Step 6:
Click on “new” and select “new window” will pop-up a new window.
Again Give a name to this window and hit “ok”.
Wonderware Intouch Properties
Step 7:
A new window will open as shown in the below figure.
intouch HMI Tutorial
Step 8:
Let’s create a simple program to turn on/off bulb using a logic gate.
To add switch and light click on the “wizard” icon as shown in the below window.
intouch Basics
Step 9:
To make AND logic, I have chosen two switches and one light to know the status.
InTouch Graphics Design
Step 10:
To give tag name, double click on switch and give the name “S1”, same way for the second switch give name “S2”.
Learn Wonderware
Step 11:
Now When you hit “ok” new pop-up will open as shown in the below window. Select type “memory discrete” and hit “save” to proceed.
We select “memory discrete” because we have a switch (digital) in use.
We are just animating it, we have to select the memory to store the value.
Wonderware InTouch Tutorial
Step 12:
Here, Double click on LAMP, then the pop-up window will open. We are creating AND gate here, so simply we have to write “S1 AND S2” as we have selected name S1, S2 for the switches.
Wonderware tutor
Step 13:
To test the logic, click on “runtime” located on the top right corner as shown in the below window.
Wonderware SCADA programs
Step 14:
For AND gate, LAMP will only turn “ON” when both switches are “ON”. If you Switch OFF any one input then the output will go OFF.
Wonderware Example Logic
Author: Suhel Patel
  • Troubleshoot PLC Program
  • Protect PLC using Password
  • Download PLC software
  • Siemens PLC Backup
  • SCADA Communication
PLC Practice Questions
PLC Project Examples for EcoStruxure Machine Expert
T Flip Flop PLC Ladder Diagram
MOVE Instruction in PLC – What You Need to Know?
Schneider PLC Programming Example for Beginners
Commissioning Checklists for Industrial Automation Systems
  • Inder says:
    September 9, 2022 at 9:46 am
    Ver nice content. It’s a helpful topic understanding scada software.
Conveyor Sorting System with Color Detection PLC Logic
Free SCADA Training Course
How to Program a Star-Delta System using 1 Button in PLC?
SCADA Hardware and Software
Speed Control of Pneumatic Cylinder (Explanation with PLC)
PLC Logic Example on Multiple Switches and Motors
How to Create DFB in Schneider PLC? – Derived Function Block
Auto Sugar Bag Filling Station
PLC Counter Example for Bank
Basic PLC Exercise on Heater and Cooler for Students
SFC Language in PLC Programming
Sequencer Output in PLC
PLC Sequencer Instruction with Example
Marking Machine
PLC SCL Program for Marking Machine
High-Speed and Fast Counters in PLC
What are High-Speed Counters and Fast Counters in PLC?
Read Temperature in PLC
PLC Program to Read Temperature in PLC
Ball Valve Pictures
How Ball Valves Work ?
PLC and MCC Panel Interface Design
Microprocessors Objective Questions – Set 2
Electronic Devices & Circuits Quiz – Set 4
Capacitor Bank
Poor Power Factor Boosted – Industrial Electrical Problems
Difference between Feedback, Feedforward, and Cascade Control
Difference between Feedback, Feedforward, and Cascade Control?
Analog to Digital Converters Objective Questions
Electrical Conduit Seal
