Reading: Conductivity Measurement
Inst Tools > Blog > Analyzers > Conductivity Measurement
Last updated: June 11, 2018 11:39 pm
Analyzers
3 Min Read
The electrical conductivity of liquids is an important analytical measurement in many industrial processes. This measurement is one of the more non-specific types of analytical technologies, because it does not discriminate between different conductive substances dissolved in the solution. For this reason, conductivity measurement is found in process applications where the type of conductive substance is irrelevant (e.g. ultra-pure water treatment for semiconductor “chip” manufacturing, where any conductive substance dissolved in the water is undesirable), or where the substance of interest is known to be the only conductive substance present in significant quantity (e.g. controlling the salinity of a brine solution, where large quantities of salt are added to water).
Electrical conductivity in metals is the result of free electrons drifting within a “lattice” of atomic nuclei comprising the metal object. When a voltage is applied across two points of a metal object, these free electrons immediately drift toward the positive pole (anode) and away from the negative pole (cathode).
Electrical conductivity in liquids is another matter entirely. Here, the charge carriers are ions: electrically imbalanced atoms or molecules that are free to drift because they are not “locked” into a lattice structure as is the case with solid substances. The degree of electrical conductivity of any liquid is therefore dependent on the ion density of the solution (how many ions freely exist per unit volume of liquid). When a voltage is applied across two points of a liquid solution, negative ions will drift toward the positive pole (anode) and positive ions will drift toward the negative pole (cathode). In honor of this directional drifting, negative ions are sometimes called anions (attracted to the anode), while positive ions are sometimes called cations (attracted to the cathode).
Electrical conductivity in gases is much the same: ions are the charge carriers. However, with gases at room temperature, ionic activity is virtually nonexistent. A gas must be superheated into a plasma state before substantial ions exist which can support an electric current.
Types of Conductivity Probes
  1. Electrodeless Conductivity Probes (Toroidal conductivity sensors )
  2. Two Electrode Conductivity Probes
  3. Four Electrode Conductivity Probes
pH Analyzer Calibration and Troubleshooting
Oxidation-Reduction Potential (ORP) Sensor Calibration Procedure
Free chlorine Analyzer Principle
pH Monitoring System Triggers an Alarm
Gas Analyzer Sampling System
Chromatograph Sample Valves
Ozone Analyzer Working Principle
TOC Analyzer Working Principle
Four Electrode Conductivity Probes Principle
Mass Spectrometer Working Principle
Kiln Inlet Gas Analyzer
Ammonia Gas Detector Working Principle and Calibration
Measuring Gases Concentration in Chromatograph
Questions and Answers on Gas
types-of-total-organic-carbon
Basics of Total Organic Carbon (TOC) Analyzers
SWAS Analyzer Questions
SWAS Analyzers Questions and Answers
what-is-gas-metering-system
What is Gas Metering System?
Technologies for Oxygen Gas Measurement
How to Calibrate Oxygen Analyzer? – O2 Sensor Testing Procedure
toroidal conductivity probe principle
Electrodeless Conductivity Probes Principle
TOC Analyzer Principle
Total Organic Carbon Analyzer Principle
Gas Filter Correlation (GFC) spectrometer
Gas Filter Correlation (GFC) Spectroscopy
Pulsed Fluorescence SO2-H2S-CS Analyzer Working Principle
Pulsed Fluorescence SO2, H2S, CS Analyzer Working Principle
Best Practices of PLC Wiring
Best Practices of PLC Wiring – Programmable Logic Controller
Garage Door Roller Shutter
Profibus DP Master
DP Master System Configuration in PLC
Siemens S7 300 and STEP 7 PLC program using SIMATIC Software
multi-variable transmitter
Mass Flow Meters
Multiplexing
Introduction to Digital Systems
Constant Torque Load of Electrical Motor
Types of Motor Loads – Constant & Variable Torque, Horsepower
Top 100 Power Plant Engineering Objective Questions & Answers
