Reading: Concepts of State, State Variables & State Model
Inst Tools > Blog > Multiple Choice Questions > Concepts of State, State Variables & State Model
1. The transfer function for the state representation of the continuous time LTI system: dq(t)/dt=Aq(t)+Bx(t) Y(t)=Cq(t)+Dx(t) is given by:
a) C(sI-A)-1B+D
b) B(sI-A)-1B+D
c) C(sI-A)-1B+A
d) D(sI-A)-1B+C
Answer: a
Explanation: Transfer function which is ratio of Laplace output to the Laplace input when the initial conditions are zero and is calculated by using both the equations.
2. System transformation on function H(z) for a discrete time LTI system expressed in state variable form with zero initial condition
a) C(zI-A)-1B+D
b) C(zI-A)-1
c) (zI-A)-1z
d) (zI-A)-1
Answer: a
Explanation: Transfer function which is ratio of Laplace output to the Laplace input when the initial conditions are zero in discrete is same as continuous but in the z-domain.
3. State space analysis is applicable for non-linear systems and for multiple input and output systems.
a) True
b) False
Answer: a
Explanation: State space analysis is the technique that used state variables and state model for the analysis and is applicable for non-linear systems and for multiple input and output systems.
4. Assertion (A): Transfer function approach has limitation that it reveals only the system output for a input and provides no information regarding the internal state of the system.
Reason (R): There may be situations where the output of a system is stable and yet some of the system elements may have a tendency to exceed their specified ratings.
a) Both A and R are true and R is correct explanation of A
b) Both A and R are true but R is not correct explanation of A
c) A is true but R is False
d) A is False but R is True
Answer: a
Explanation: Transfer function approach has limitation over state variable analysis and for that it reveals only the system output for a input and provides no information regarding the internal state of the system.
5. When human being tries to approach an object, his brain acts as,
a) An error measuring device
b) A controller
c) An actuator
d) An amplifier
Answer: b
Explanation: Brain of human being acts as a controller in the human body system as human body is the control system and when human tries to approach an object the brain of the human acts as controller.
6. For two-phase AC servomotor, if the rotor’s resistance and reactance are respectively R and X, its length and diameter are respectively L and D then,
a) X/R and L/D are both small
b) X/R is large but L/D is small
c) X/R is small but L/D is large
d) X/R and L/D are both large
Answer: c
Explanation: Small X/R gives linear speed torque characteristic. Large L/D gives less inertia and good acceleration characteristic.
7. Consider the following statements relating to synchro’s:
1. The rotor of the control transformer is either disc shaped
2. The rotor of the transmitter is so constructed as to have a low magnetic reluctance
3. Transmitter and control transformer pair is used as an error detector
Which of these statements are correct?
a) 1,2 and3
b) 1 and 2
c) 2 and3
d) 1 and 3
Answer: c
Explanation: Rotor of control transformer is rotatory part of the transformer and is made cylindrical in shape so that air gap is practically uniform.
8. Error detector:
a) Armature controlled FHP DC motor
b) A pair of synchronous transmitter and control transformer
c) Tach generator
d) Amplidyne
Answer: a
Explanation: Error detector is the part in the armature controlled FHP DC motor where error detector is the first element that compares the final output with desired output and gives the accurate results.
9. Servomotor:
c) Tach generator
d) Amplidyne
Answer: b
Explanation: Servomotor is a rotary actuator or linear actuator that allows for precise control of angular or linear position, velocity and acceleration a pair of synchronous transmitter and control transformer.
10. Amplifier:
c) Tach generator
d) Amplidyne
Answer: d
Explanation: Amplifier is an amplidyne which is an amplidyne is an electromechanical amplifier invented during World War II by Ernst Alexanderson. It consists of an electric motor driving a DC generator.
Output Regulator & the Tracking Problem
Logic Families Questions and Answers
Dissolved Oxygen Analyzer Questions and Answers
Sodium Analyzer Questions & Answers
Experimentation of Transfer Function
Transfer Functions Objective Questions
Components of Mass Spectrometer Questions & Answers
Combination Electrode Questions & Answers
Stability Analysis
Actuators Questions and Answers
Biosensors Questions & Answers
High Pressure Liquid Chromatography Questions & Answers
Closed-Loop Frequency Response
Optimal Control Systems
The Infinite Time Regulator Problem
number-systems-questions-answers
Measurement and Instrumentation Objective Questions – Part 4
Digital Circuits Questions & Answers
Gamma Camera Questions & Answers
Digital Control Systems
Z-transform Analysis of Sampled-Data Control Systems
Stability in Frequency Domain
Assessment of Relative Stability Using Nyquist Criterion
Ion Analyzers Questions and Answers
Ion Analyzer Questions & Answers
What is a Lightning Arrester? How does it work?
Counters Objective Questions
Electric Motors Noises
Electric Motors Noises – Types, Possible Sources, Reasons
Electrical Machines MCQ Series 4
PLC-Complete-Training-Package
Free PLC Training Software Download
Ozone analyzer principle
Ozone Analyzer Working Principle
PLC Sequence Programming Ladder Logic
Constant Torque Load of Electrical Motor
Types of Motor Loads – Constant & Variable Torque, Horsepower
