Reading: Concept of Stability in Control Systems
Inst Tools > Blog > Multiple Choice Questions > Concept of Stability in Control Systems
Last updated: November 27, 2021 5:41 pm
6 Min Read
Concept of Stability in Control Systems MCQ
1. Stability of a system implies that :
a) Small changes in the system input does not result in large change in system output
b) Small changes in the system parameters does not result in large change in system output
c) Small changes in the initial conditions does not result in large change in system output
d) All of the above mentioned
Answer: d
Explanation: Stability of the system implies that small changes in the system input, initial conditions, and system parameters does not result in large change in system output.
2. A linear time invariant system is stable if :
a) System in excited by the bounded input, the output is also bounded
b) In the absence of input output tends zero
c) Both a and b
d) System in excited by the bounded input, the output is not bounded
Answer: c
Explanation: A system is stable only if it is BIBO stable and asymptotic stable.
3. Asymptotic stability is concerned with:
a) A system under influence of input
b) A system not under influence of input
c) A system under influence of output
d) A system not under influence of output
Answer: b
Explanation: Asymptotic stability concerns a free system relative to its transient behavior.
4. Bounded input and Bounded output stability notion concerns with :
Answer: a
Explanation: BIBO stability concerns with the system that has input present.
5. If a system is given unbounded input then the system is:
a) Stable
b) Unstable
c) Not defined
d) Linear
Answer: c
Explanation: If the system is given with the unbounded input then nothing can be clarified for the stability of the system.
6. Linear mathematical model applies to :
a) Linear systems
b) Stable systems
c) Unstable systems
d) Non-linear systems
Answer: b
Explanation: As the output exceeds certain magnitude then the linear mathematical model no longer applies.
7. For non-linear systems stability cannot be determined due to:
a) Possible existence of multiple equilibrium states
b) No correspondence between bounded input and bounded output stability and asymptotic stability
c) Output may be bounded for the particular bounded input but may not be bounded for the bounded inputs
d) All of the mentioned
Answer: d
Explanation: For non-linear systems stability cannot be determined as asymptotic stability and BIBO stability concepts cannot be applied, existence of multiple states and unbounded output for many bounded inputs.
8. If the impulse response in absolutely integrable then the system is :
a) Absolutely stable
b) Unstable
c) Linear
d) Stable
Answer: a
Explanation: The impulse response must be absolutely integrable for the system to absolutely stable.
9. The roots of the transfer function do not have any effect on the stability of the system.
a) True
b) False
Answer: b
Explanation: The roots of transfer function also determine the stability of system as they may be real, complex and may have multiplicity of various order.
10. Roots with higher multiplicity on the imaginary axis makes the system :
b) Unstable
c) Linear
d) Stable
Answer: b
Explanation: Repetitive roots on the imaginary axis makes the system unstable.
11. Roots on the imaginary axis makes the system :
a) Stable
b) Unstable
c) Marginally stable
d) Linear
Answer: c
Explanation: Roots on the imaginary axis makes the system marginally stable.
12. If the roots of the have negative real parts then the response is ____________
a) Stable
b) Unstable
d) Bounded
Answer: d
Explanation: If the roots of the have negative real parts then the response is bounded and eventually decreases to zero.
13. If root of the characteristic equation has positive real part the system is :
a) Stable
b) Unstable
d) Linear
Answer: b
Explanation: The impulse response of the system is infinite when the roots of the characteristic equation has positive real part.
14. A linear system can be classified as :
b) Conditionally stable
c) Unstable
Answer: d
Explanation: A system can be stable, unstable and conditionally stable also.
15. ___________ is a quantitative measure of how fast the transients die out in the system.
c) Unstable
d) Relative Stability
Answer: d
Explanation: Relative Stability may be measured by relative settling times of each root or pair of roots.
Fundamentals of Radiochemical Methods Questions
Constructing Phase-Trajectories
Liquid Chromatograph- Mass Spectrometer
Biosensors Questions & Answers
Time Response of Second Order Systems – I
Mathematical Preliminaries
Root Locus in Control Systems
Stepper Motor MCQ
Column Efficiency and Column Resolution Questions and Answers
Ion Analyzer Questions & Answers
Sulphur Di-oxide Monitoring Questions & Answers
Block diagram Algebra Objective Questions
Permit to Work System Online Test
State Models for Linear Continuous Time Systems
Quadrupole Mass Spectrometer
Signal Flow Graphs Objective Questions
Chromatographic Behaviour of Solutes Questions & Answers
State Variables & Linear Discrete Time Systems
Argonite/CO2 Flooding System Master & Slave Cylinder Operation
Field Transmitter Damping
What is Field Transmitter Damping ?
Control Valves Classification
Classification of Control Valves
Controlled Inverter Objective Questions
What is Partial Stroke Test
What is Partial Stroke Test?
GATE Instrumentation Questions and Answers
Coil Type Timers in Siemens PLC Programming
Microprocessors Objective Questions – Set 7
