Reading: Closed-Loop Frequency Response
Inst Tools > Blog > Multiple Choice Questions > Closed-Loop Frequency Response
1. Closed loop frequency response is very useful as :
a) It approximately predicts the time response of the systems
b) Time response are converted into time domain specifications
c) After design time domain specification is converted into frequency domain
d) All of the mentioned
Answer: d
Explanation: Closed loop frequency response is very useful as it enables to use second order correlations between frequency and transient response.
2. Maximum peak overshoot in time domain corresponds to :
a) Resonance peak
b) Resonant frequency
c) Bandwidth
d) Cut-off rate
Answer: a
Explanation: Resonance peak in frequency domain correspond to maximum peak overshoot in time domain.
3. Frequency of oscillation in time domain correspond to :
a) Resonance peak
c) Bandwidth
d) Cut-off rate
Answer: b
Explanation: Resonant frequency in frequency domain correspond to frequency of oscillation in time domain.
4. Bandwidth is :
a) Range of frequencies for which the system gain is more than-3dB
b) This is considered good range for transmission of signals
c) For better communication bandwidth of signal must be less
Answer: d
Explanation: Bandwidth of a signal must be less but channel must be more foe better transmission or communication.
5. Cut-off rate is the ability of the system to distinguish the signal from _____________
a) Bandwidth
b) Noise
c) Resonance peak
d) Magnitude
Answer: b
Explanation: Cut-off rate is the ability of the system to distinguish the signal from noise.
6. The important figures of merit to the system in frequency domain are :
a) Maximum value of resonant peak
b) Value of resonance frequency
c) Maximum value of resonant peak and Value of resonance frequency
d) Minimum value of resonance frequency
Answer: c
Explanation: The important figures of merit to the system in frequency domain are maximum value of resonance peak and frequency at which it occurs.
7. In q(s) plane Nyquist plot is symmetrical about the :
a) Imaginary axis
b) Real axis
c) Origin
d) None of the mentioned
Answer: b
Explanation: By definition, In q(s) plane Nyquist plot is symmetrical about the real axis.
8. A polar plot intersects the unit circle at a point making -45° to the negative real axis then the phase margin of the system is :
a) -45°
b) 45°
c) 180°-45°
d) 180°+45°
Answer: b
Explanation: As the angle is with the negative real axis hence the Phase margin will be 45°.
9. The parameter which is constant along the constant N circle :
a) Frequency
b) Phase angle
c) Magnitude
d) Open loop gain
Answer: b
Explanation: Phase angle remains constant in constant N-circle.
10. In second order system gain margin is :
a) Zero value
b) Finite value
c) Infinite value
Answer: c
Explanation: Gain margin is defined generally for systems with order greater than 3.
Paramagnetic Oxygen Analyzers Questions & Answers
Realization of Basic Compensators
Electron Probe Microanalyser Questions & Answers
Analytical Measurement Multiple Choice Questions
Process Pressure Measurement Objective Questions
Constructing Phase-Trajectories
Radiofrequency Mass Spectrometer
State Models for Linear Continuous Time Systems
Parameter Optimization : Servomechanims
Block diagram Algebra Objective Questions
The Design Problem
Measurement and Instrumentation Objective Questions – Part 1
State Variables & Linear Discrete Time Systems
Optimal Control Problems – Part 1
NO2 Analyzer Questions & Answers
Induction Motor Interview Questions Answers
Electrical Measurements and Instrumentation Objective Questions & Answers
Pulse Height Analyzer Questions & Answers
Ion Analyzers Questions and Answers
Ion Analyzer Questions & Answers
Time Response Analysis
Standard Test Signals Objective Questions
Differential Equations of Physical Systems & Dynamics of Robotic Mechanisms
PN Junction Questions & Answers
Measurement and Instrumentation Objective Questions – Part 5
Frequency Response MCQ
Experimentation of Transfer Function
Gas-Insulated Transmission Line
What is Gas-Insulated Transmission Line? Principle Advantages
Pneumatic Transmitter
Questions on Pneumatic Transmitter and Repeater
What is Travel Stop in Control Valve
What is Travel Stop in Control Valve?
Control Systems Questions & Answers
Control Systems Objective Questions & Answers – Set 1
Multiple Thermowell Installations Problems
Ultrasonic Level Transmitters Installation
Ultrasonic Level Transmitter Principle, Limitations, Calibration and configuration
Control Valve Selection Guide
PID Controller Types
PID Controllers : Parallel, Ideal & Series
