Reading: Calculate PSV Lift Pressure
Inst Tools > Blog > Practical Questions > Calculate PSV Lift Pressure
Calculate the total upward force exerted on the circular roof of this cylindrical storage tank at the PSV lift pressure.
Last updated: October 27, 2020 2:06 pm
Practical Questions
1 Min Read
A safety device commonly installed on process vessels containing pressurized gases is a Pressure Safety Valve or PSV.
PSV Lift Pressure
In this example, a PSV protects a storage tank against rupture from excessive internal gas pressure, with the PSV set to open (“lift”) and vent the tank if the internal pressure exceeds 2 inches water column:
PSV lift pressure
Calculate the total upward force exerted on the circular roof of this cylindrical storage tank at the PSV lift pressure, expressed in the unit of tons. F = ______ tons.
  • Rupture disk
  • Pressure Relief Valve
  • Impulse Line Testing
  • Relief and Safety Valve
  • Over Pressure Protection
Credits: Tony R. Kuphaldt
Questions on Pneumatic Control Loop
How Nuclear Radiation is used to Measure Coke Dust Level?
Determine Resistance value of Resistors
Solenoid-controlled Valve Problem
Air Pressure Regulator Questions
Motor Trip Logic using PLC Programming
  • Vijay SankaraSubramanian V says:
    May 13, 2023 at 9:27 am
    For the question attached in https://instrumentationtools.com/calculate-psv-lift-pressure/ this URL the answer is
    area 13430.31 ft
    1247.71609 m2
    12477160.9 cm2
    pressure 2 mmWC
    0.0002 ksc
    Force pressure x area
    2495.43218 kgs
    2.49543218 ton
Find Thermocouple Ouput Voltage
Draw the appropriate Pressure Switch Symbol ?
Identify the Problem in the PLC Program
10 Questions on Reforming Furnace Control System
Upgrading the Electrical System in an Automobile
Questions on Dip Tube Type Level System
Level Measuring Instruments Velocities of Propagation
Determine the Status of Lamps and Relays in the Circuit ?
Identify Problem with Oily Water Filter Instrumentation
Sump Tank Level Transmitter
Problem with Sump Tank Level Transmitter
Programmable Logic Controller (PLC) Questions and Answers – 3
Inclined Water Manometer
How much Pressure is applied to Inclined Water Manometer?
two chemical streams are mixed together
Dry Leg
Calculate 0%, 50%, and 100% Calibration Points for ΔP transmitter
liquid flow control loop
Liquid Flow Control Loop Controller Action
Problem on Tachogenerator
What is a Feedback Control System
What is a Feedback Control System? Types & Advantages
What is a Photoelectric Sensor
What is a Photoelectric Sensor?
peak of a chromatogram
Measuring Gases Concentration in Chromatograph
Basic Transistor Amplifier Circuit Principle
Industrial Automation Architecture reference model
Industrial Automation System Architecture Reference Model
Count the Number of Bottles
Count the Number of Bottles in Packaging Carton PLC Logic
Interposing Relay Panel (IRP)
