Reading: Control Loop Multiple Choice Questions
Inst Tools > Blog > Instrumentation MCQ > Control Loop Multiple Choice Questions
Last updated: June 21, 2025 10:09 am
Instrumentation MCQ Multiple Choice Questions
Study the basic control loop multiple choice questions (MCQ) and test your technical knowledge on industrial instrumentation concepts.
Control Loops Multiple Choice QuestionsA basic control loop will consist of:In order for a control loop to work well under a wide range of conditions, it must possess:Which of the following is not a “final control element”?The purpose of a “shield” wire on an instrument signal cable is to:The most common analog signal standard for industrial process instruments is:In a process controller, “output” refers to:Identify which of the following is an example of a “primary sensing element”:Identify the controller’s proper action in the event that the thermocouple suddenly detects a drop in process temperature:In a home heating system, room temperature is the:When a process controller is in the “automatic” mode,
Question 1
(A) signal converter, resistor, knob, and control valve
(B) transducer, valve packing, hex-head wrench, and tubing
(C) transmitter, controller, I/P transducer, and control valve
(D) resistor, capacitor, terminal block, and battery
(E) control valve, microprocessor, terminal block, and cables
Answer : C
Question 2
(A) Calibration drift
(B) Hysteresis
(C) A very expensive transmitter
(D) Proper documentation
(E) Negative feedback
Answer : E
Question 3
(A) A pressure transmitter
(B) An electric motor
(C) A heating element
(D) A control valve
(E) A servo
Answer : A
Question 4
(A) Hold a steadier setpoint value
(B) Ensure technician safety
(C) Minimize the possibility of sparking
(D) Protect the cable from corrosion
(E) Minimize electrical noise
Answer : E
Question 5
(A) 10 to 50 milliamps DC
(B) 0 to 5 amps AC
(C) 0 to 10 volts
(D) 0 to 20 milliamps
(E) 4 to 20 milliamps DC
Answer : E
Question 6
(A) The target value for the measured variable
(B) The DC supply power to the transmitter
(C) The maximum value for the low-alarm point
(D) The command signal to the control valve
(E) The production quota for each work day
Answer : D
Question 7
(A) I/P transducer
(B) Instrument signal cable
(C) Control valve
(D) Diaphragm
(E) Digital controller
Answer : D
Question 8
temperature control loop
(A) Re-calibrate the temperature transmitter
(B) Move the control valve further open
(C) Completely open the control valve
(D) Move the control valve further closed
(E) Hold the control valve’s position steady
Answer : D
Question 9
(A) Process variable
(B) Setpoint
(C) Inferred variable
(D) Manipulated variable
(E) Error variable
Answer : A
Question 10
(A) The output responds to changes in the process variable
(B) The control valve will fail closed
(C) The process variable cannot deviate from setpoint
(D) The controller will automatically generate alarms
(E) The control valve will fail open
Answer : A
Credits : by Tony R. Kuphaldt
Share your feedback on the questions.
Control Valves Multiple Choice Questions
Tuning of PID Controllers
Parameter Optimization : Servomechanims
UV Visible Spectrometers Questions and Answers
Process Control & Instrumentation Objective Questions – Set 6
Safety Instrumented Systems Online Exam
Flame Emission Photometers Questions & Answers
Design Considerations for Higher Order Systems
Fundamentals of Radiochemical Methods Questions
NO2 Analyzer Questions & Answers
Concepts of State, State Variables & State Model
Absorption Instrumentation Questions & Answers
Types of Pressure
Types of Pressure – Instrument Questions and Answers
Time Response Analysis
Approximation of Higher-Order Systems by Lower Order
Basic Digital Building Blocks Objective Questions
Oscillators and Signal Generators Objective Questions
Digital Control Systems
The Z-Transform
Sensors and Transducers Objective Questions
Measurements & Instrumentation Quiz – Set 3
Process Control Instrumentation Quiz
Why counter-current heat exchangers are better than co-currents?
Why Counter-current Heat Exchangers are better than Co-current?
Types of Electrical Loads
Temperature Measurement Objective Questions
Dual Converters Quiz
Transmission Lines Protection Questions Answers
Functional Safety Engineering
SIS Safety Requirements
Compressor Coolers
Difference Between PLC and RTU
Difference Between PLC and RTU?
