Reading: Assessment of Relative Stability Using Nyquist Criterion
Inst Tools > Blog > Multiple Choice Questions > Assessment of Relative Stability Using Nyquist Criterion
1. The phase margin (in degrees) of a system having the loop transfer function G(s) H(s)=2√3/s(s+1) is:
a) 45°
b) -30°
c) 60°
d) 30°
Answer: d
Explanation: Phase margin is calculated at gain cross over frequency where magnitude of the transfer function is 1.
2. The system with the open loop transfer function G(s) H(s) =1/s(s^2+s+1) has the gain margin of :
a) -6 dB
b) 0 dB
c) 3.5 dB
d) 6 dB
Answer: b
Explanation: Gain margin is calculated at phase cross over frequency where the phase is 180°.
3. The phase angle of the system, G(s) =s+5/s<sup>2</sup>+4s+9, varies between :
a) 0° and 90°
b) 0° and -90°
c) 0° and -180°
d) -90° and -180°
Answer: a
Explanation: As it is the type 0 system so the phase angle can be 0° and 90°.
4. The polar plot of the transfer function G(s) = 10(s+1)/s+10 will be in the :
a) First quadrant
b) Second quadrant
c) Third quadrant
d) Fourth quadrant
Answer: d
Explanation: Polar plot of the given transfer function lies in the fourth quadrant.
5. As the polar plot moves toward the point (-1, 0) then the system becomes :
a) Stable
b) Marginally stable
c) Conditionally stable
d) Unstable
Answer: d
Explanation: As the polar plot moves toward the point (-1, 0) then the system becomes unstable.
6. Polar plots moving toward the imaginary axis makes the system:
a) Stable
d) Unstable
Answer: d
Explanation: Polar plots moving toward the imaginary axis makes the system unstable.
7. The concepts used to measure relative stability are:
a) Phase margin
b) Gain margin
c) Phase and Gain margin
d) Stable
Answer: c
Explanation: The concepts used to measure relative stability are phase margin and gain margin.
8. Phase and gain margin are applicable to open and closed loop systems both.
a) True
b) False
Answer: b
Explanation: Phase and gain margin are applicable only to open loop systems.
9. Gain margin is:
a) It is a factor by which the system gain can be increased to drive it to the verge of instability
b) It is calculated at gain cross over frequency
c) It is calculated at phase cross over frequency
d) Both a and c
Answer: d
Explanation: Gain margin is a factor by which the system gain can be increased to drive it to the verge of instability and is calculated at phase cross over frequency.
10. Phase margin is:
a) It is amount of additional phase lag at the gain cross over frequency required to bring the system to the verge of instability
b) It is always positive for stable feedback systems
c) It is calculated at gain cross over frequency
d) All of the mentioned
Answer: d
Explanation: Phase margin is the measure of relative stability which is always positive for stable systems.
Bode Plots MCQ
Z & S Domain Relationship
Surface Spectroscopic Techniques
Online Analyzers Questions & Answers
Total Reflection Spectrometer Questions & Answers
Digital Circuits Questions & Answers
Special Designs of Ion Selective Electrodes Questions & Answers
MCQ on Flow Measurement
Electron Spectroscopy for Chemical Analysis
Combination Electrode Questions & Answers
Ionization of Gases Questions and Answers
Optimal Control Systems
The Infinite Time Regulator Problem
Time Response Analysis
Robotic Control System – Part II
Logic Families Questions and Answers
Signal Flow Graphs Objective Questions
Magnetic Wind Instruments Questions & Answers
Atomic Absorption Spectroscopy Questions & Answers
Instrumentation Diagrams Multiple Choice Questions
Solid State Relay Working Principle
What is a Solid State Relay? – Working Principle, Types of Control
Chemiluminescent Analyzer
Chemiluminescence
Parts of PLC
Parts of PLC
Limit Switch Working
Limit Switch Animation
Electric Motor Animation
Electric Motor Working Animation
fieldbus cables layout
H1 FF Data Link layer
DP-Level-Transmitter-Open-tank-calibration
Timer STL Programming
Timers using Statement List (STL) PLC Programming
