| 1 | Electrical Machines | What is HFSR & FCMA Starters? |
| 2 | Electrical Machines | Electrical Glossary |
| 3 | Electrical Machines | Electrical Trouble Shooting Self Test |
| 4 | Electrical Machines | Voltage Drops in Control Circuits |
| 5 | Electrical Machines | Crisscross Voltmeter Method |
| 6 | Electrical Machines | Check for Incoming Power |
| 7 | Electrical Machines | Using Meters for Troubleshooting |
| 8 | Electrical Machines | Electrical Trouble Shooting Common Issues |
| 9 | Electrical Machines | SELF TEST ON CIRCUITS |
| 10 | Electrical Machines | Anti-Plugging with Timers |
| 11 | Electrical Machines | Sequence Control: Off-Delay |
| 12 | Electrical Machines | Sequence Control: On-Delay |
| 13 | Electrical Machines | Timer Circuits Overview |
| 14 | Electrical Machines | Anti-Plugging With Zero-Speed Switch |
| 15 | Electrical Machines | Plugging with a Zero-Speed Switch |
| 16 | Electrical Machines | Forward/Reverse Control Circuits |
| 17 | Electrical Machines | Jog Circuits |
| 18 | Electrical Machines | Pressure Circuit |
| 19 | Electrical Machines | Three-Wire Circuit With Pilot Lights |
| 20 | Electrical Machines | Three-Wire Circuit with Multiple Push Buttons |
| 21 | Electrical Machines | Manual Circuits |
| 22 | Electrical Machines | Reservoir Circuit |
| 23 | Electrical Machines | Sump-Pump Circuit |
| 24 | Electrical Machines | Automatic Control Circuits |
| 25 | Electrical Machines | Control Circuit’s Source of Supply |
| 26 | Electrical Machines | Power Circuit |
| 27 | Electrical Machines | Circuits Overview |
| 28 | Electrical Machines | Self Test on Electrical Diagrams |
| 29 | Electrical Machines | Motor-Lead Connections |
| 30 | Electrical Machines | Transferring From Schematic to Wiring Diagram for Connection Purposes |
| 31 | Electrical Machines | Conduit Fill |
| 32 | Electrical Machines | Numbering System |
| 33 | Electrical Machines | Schematic vs. Wiring Diagrams |
| 34 | Electrical Machines | Self Test on Motor Starters and Contactors |
| 35 | Electrical Machines | Timers |
| 36 | Electrical Machines | Control Relays |
| 37 | Electrical Machines | Forward/Reverse Starters |
| 38 | Electrical Machines | Magnetic-Motor Starters |
| 39 | Electrical Machines | Manual Motor Starters |
| 40 | Electrical Machines | Overload Relays |
| 41 | Electrical Machines | Motor Starters and Contractors |
| 42 | Electrical Machines | Test on Electrical Pilot Devices |
| 43 | Electrical Machines | Zero-Speed Switch |
| 44 | Electrical Machines | Common Pilot Devices |
| 45 | Electrical Machines | Switches and Pushbuttons |
| 46 | Electrical Machines | Test on basics |
| 47 | Electrical Machines | Plugging vs. Anti-Plugging |
| 48 | Electrical Machines | Single-Phase Systems vs. Three-Phase Systems |
| 49 | Electrical Machines | Overload and Overcurrent Protection |
| 50 | Electrical Machines | Low-Voltage Release vs. Low-Voltage Protection |
| 51 | Electrical Machines | Ohm’s Law and Watt’s Law |
| 52 | Electrical Machines | Motor Control Functional Testing |
| 53 | Electrical Machines | Active Suppression Drive Circuits |
| 54 | Electrical Machines | Capacitor Suppression Drive Circuits |
| 55 | Electrical Machines | Current Reversal Bifilar winding Drive Circuits |
| 56 | Electrical Machines | High Voltage Recovery Drive Circuits |
| 57 | Electrical Machines | Dual Voltage Devices Drive Circuits |
| 58 | Electrical Machines | Voltage Multiplying Drive Circuits |
| 59 | Electrical Machines | RC Drive Circuits |
| 60 | Electrical Machines | R/L Drive Circuits |
| 61 | Electrical Machines | Secondary breakdown+ Zener diode Drive Circuits |
| 62 | Electrical Machines | Diode+ Zener diode Drive Circuits |
| 63 | Electrical Machines | Diode+ Resistive Drive circuits |
| 64 | Electrical Machines | Diode Type Drive Circuits |
| 65 | Electrical Machines | Automatic Transfer Switch Working Principle |
| 66 | Electrical Machines | Transformer Multiple Choice Questions |
| 67 | Electrical Machines | Reason for Generation of Alternator Voltage is 22KV |
| 68 | Electrical Machines | Brushless Excitation System of Synchronous Generators or Alternators |
| 69 | Electrical Machines | Synchronous Generators or Alternators Static Excitation System |
| 70 | Electrical Machines | Automatic Voltage Regulator of Alternator |
| 71 | Electrical Machines | Difference between capacity and generation ratings of an alternator? |
| 72 | Electrical Machines | What is KVA KVAR And KW? |
| 73 | Electrical Machines | What is Inrush current in a transformer? |
| 74 | Electrical Machines | Insulating materials used in machines like Transformers, Generators and Motors |
| 75 | Electrical Machines | What is Transformer Oil? |
| 76 | Electrical Machines | Induction motor Speed Torque Characteristics |
| 77 | Electrical Machines | Transformer Tap Changing Methods-How it Works? |
| 78 | Electrical Machines | Phasor groups for 3-phase transformers |
| 79 | Electrical Machines | Parallel Operation of 3-phase Transformers-Conditions to Satisfy |
| 80 | Electrical Machines | Why Motor rated in kW instead of kVA? |
| 81 | Electrical Machines | Differences between Transformer and Induction Motor |
| 82 | Electrical Machines | Difference between Neutral and Ground potential |
| 83 | Electrical Machines | Polarity Test of Three Phase Induction Motor |
| 84 | Electrical Machines | Why Capacitor banks are connected across Induction motors? |
| 85 | Electrical Machines | Single Phasing of Three Phase Induction Motor |
| 86 | Electrical Machines | Prospects of Electrical Engineers in Power Plants |
| 87 | Electrical Machines | Size of DC motor is larger compared to the AC motor for same capacity |
| 88 | Electrical Machines | Purpose of using transformer in electric circuits? |
| 89 | Electrical Machines | What is Oil Surge Relay of Transformer? |
| 90 | Electrical Machines | HT and LT Cables Construction Code Specification |
| 91 | Electrical Machines | PS-Class Current Transformers |
| 92 | Electrical Machines | DC Earth Fault Using Multimeter |
| 93 | Electrical Machines | Working Principle of Undervoltage (27) and Overvoltage (59) Relays |
| 94 | Electrical Machines | Difference between Measured Earth Fault and Derived Earth Fault |
| 95 | Electrical Machines | Working Principle of Vacuum Circuit Breaker |
| 96 | Electrical Machines | Capacitive Voltage Indicator |
| 97 | Electrical Machines | Working Principle of Trivector Meter |
| 98 | Electrical Machines | Vector Groups of Transformer |
| 99 | Electrical Machines | What is scott connection in Transformer? |
| 100 | Electrical Machines | Single Phase Transformer-Operation, Advantages, Disadvantages |
| 101 | Electrical Machines | Advantages of Stationary Armature Winding in Alternator |
| 102 | Electrical Machines | Generator Stator Cooling System |
| 103 | Electrical Machines | Brushed DC electric motor Working Animation |
| 104 | Electrical Machines | Three Point Starter Working Principle |
| 105 | Electrical Machines | Star Delta Starter Working Principle |
| 106 | Electrical Machines | DC Machines Lecture Notes Download |
| 107 | Electrical Machines | What is shape of holding torque of stepper motor? |
| 108 | Electrical Machines | What is pullin & pullout torque? |
| 109 | Electrical Machines | Main parts of Transformer |
| 110 | Electrical Machines | DC Motor Basic Parts |
| 111 | Electrical Machines | AC Motor Basic Parts |
| 112 | Electrical Machines | Motor Overheating Problems |
| 113 | Electrical Machines | Split-Phase Motor Working Principle |
| 114 | Electrical Machines | Shaded-Pole Motor Working Principle |
| 115 | Electrical Machines | Direct Current (DC) Motor Working Principle |
| 116 | Electrical Machines | AC-DC Universal Motor Working Principle |
| 117 | Electrical Machines | Internal Faults in Transformer |
| 118 | Electrical Machines | Why Delta winding prefer? |
| 119 | Electrical Machines | Hydroelectricity |
| 120 | Electrical Machines | Hydro Generator Turbine Parts |
| 121 | Electrical Machines | Electric Generator |
| 122 | Electrical Machines | Rotor |
| 123 | Electrical Machines | Stator |
| 124 | Electrical Machines | Dry ice blasting on the stator |
| 125 | Electrical Machines | Electric Motor |
| 126 | Electrical Machines | Load Rejection Tests |
| 127 | Electrical Machines | CCCW stand for Closed Circuit Cooling Water |
| 128 | Electrical Machines | Earthing system |
| 129 | Electrical Machines | Commutator Electric |
| 130 | Electrical Machines | What is over fluxing relay? |
| 131 | Electrical Machines | What is generator synchronizer? |
| 132 | Electrical Machines | What is plugging of an Induction motor? |
| 133 | Electrical Machines | What are Brushless Alternators? |
| 134 | Electrical Machines | What is equalizer ring used for? |
| 135 | Electrical Machines | What is a Ground line? |
| 136 | Electrical Machines | How may the number of parallel paths in an armature be increased? |
| 137 | Electrical Machines | How are brushes connected in DC generator? |
| 138 | Electrical Machines | How can field distortion be remedied? |
| 139 | Electrical Machines | What is meant by Normal Neutral Plane? |
| 140 | Electrical Machines | What is the best way of minimizing eddy currents in an armature? |
| 141 | Electrical Machines | Should the brushes of a loaded generator be placed in the neutral plane? |
| 142 | Electrical Machines | What causes sparking at the brushes? |
| 143 | Electrical Machines | What is the standard direction of rotation of the DC generators? |
| 144 | Electrical Machines | What is meant by voltage build up of a generator? |
| 145 | Electrical Machines | How should a generator be started? |
| 146 | Electrical Machines | What is the procedure for shunting down the generator? |
| 147 | Electrical Machines | Can a generator be reversed by reversing the connections between armature and field coils? |
| 148 | Electrical Machines | How do you start an Induction motor? |
| 149 | Electrical Machines | What are Damper Winding? |
| 150 | Electrical Machines | What are Interpoles used for? |
| 151 | Electrical Machines | What are Dummy coils? |
| 152 | Electrical Machines | What is the purpose of compensating windings? |
| 153 | Electrical Machines | What is Cogging and Crawling? |
| 154 | Electrical Machines | What is Phase Swinging? |
| 155 | Electrical Machines | Will there be any harm if the rotor of a hybrid stepper motor is pulled out of its stator? |
| 156 | Electrical Machines | Disadvantage of having more phases |
| 157 | Electrical Machines | What is a synchronous capacitor? |
| 158 | Electrical Machines | Applications of synchronous motors |
| 159 | Electrical Machines | What is the difference between direct-connected and direct-coupled units? |
| 160 | Electrical Machines | What is direct-connected alternator? |
| 161 | Electrical Machines | Possible reasons if a 3-phase motor fails to start |
| 162 | Electrical Machines | How does the slip vary with load? |
| 163 | Electrical Machines | Why induction motors are called asynchronous? |
| 164 | Electrical Machines | How do changes in supply voltage and frequency affect the performance of an induction motor? |
| 165 | Electrical Machines | How is magnetic leakage reduced to a minimum in commercial transformers? |
| 166 | Electrical Machines | What causes are responsible for over-heating of Commutator in a DC motor? |
| 167 | Electrical Machines | Why does a DC motor sometime run too fast when under load? |
| 168 | Electrical Machines | A DC motor fails to start when switched on. What could be the possible reasons and remedies? |
| 169 | Electrical Machines | What will happen if a shunt motor is directly connected to the supply line? |
| 170 | Electrical Machines | What happens if the direction of current at the terminals of a series motor is reversed? |
| 171 | Electrical Machines | How may the direction of rotation of a DC motor be reversed? |
| 172 | Electrical Machines | What causes heating of armature? |
| 173 | Electrical Machines | What are causes of hot bearings? |
| 174 | Electrical Machines | Distribution factor or winding factor |
| 175 | Electrical Machines | What are the functions of yoke? What is the choice of material for the yoke? |
| 176 | Electrical Machines | What is meant by reactance voltage? |
| 177 | Electrical Machines | Parts of the DC generators |
| 178 | Electrical Machines | What are the conditions to be satisfied for parallel operation of DC generators? |
| 179 | Electrical Machines | The series field winding has low resistance while the stunt field winding has high resistance. Why? |
| 180 | Electrical Machines | Why does curving the pole faces in a DC machines contributes to a smoother DC output voltage from it? |
| 181 | Electrical Machines | Why the air gap between the pole pieces and the armature is kept very small? |
| 182 | Electrical Machines | In DC generators, the series field winding has low resistance while the shunt field winding has high resistance. Why? |
| 183 | Electrical Machines | Equivalent circuit of a single phase transformer |
| 184 | Electrical Machines | What material is used in the transformer core? |
| 185 | Electrical Machines | Advantages of three phase motor over single phase motor |
| 186 | Electrical Machines | Advantages of stationary armature and rotating field system |
| 187 | Electrical Machines | Will the alternators have rotating armature system or stationary armature system? |
| 188 | Electrical Machines | What is the general system requirements of alternator? |
| 189 | Electrical Machines | Various methods for predetermining the voltage regulation of 3-phase Alternator |
| 190 | Electrical Machines | Define the term voltage regulation of Alternator |
| 191 | Electrical Machines | An Alternator is found to have its terminal voltage on load condition more than that on no load. What is the nature of the load connected? |
| 192 | Electrical Machines | What factors does the load angle depend? |
| 193 | Electrical Machines | What is meant by load angle of an Alternator? |
| 194 | Electrical Machines | What is meant by synchronous impedance of an Alternator? |
| 195 | Electrical Machines | What do you mean by synchronous reactance? |
| 196 | Electrical Machines | What is meant by armature reaction in Alternators? |
| 197 | Electrical Machines | What are the causes of changes in voltage in Alternators when loaded? |
| 198 | Electrical Machines | Why are Alternators rated in kVA and not in kW? |
| 199 | Electrical Machines | Define winding factor |
| 200 | Electrical Machines | Why is short pitch winding preferred over full-pitch winding? |
| 201 | Electrical Machines | What is distributed winding? |
| 202 | Electrical Machines | What is the relation between electrical degree and mechanical degree? |
| 203 | Electrical Machines | How does electrical degree differ from mechanical degree? |
| 204 | Electrical Machines | Why is the stator core of Alternator laminated? |
| 205 | Electrical Machines | Advantages of salient pole type construction used for Synchronous machines? |
| 206 | Electrical Machines | Which type of Synchronous generators are used in Hydro-electric plants and why? |
| 207 | Electrical Machines | Why do cylindrical Alternators operate with steam turbines? |
| 208 | Electrical Machines | Types of Alternator based on their rotor construction |
| 209 | Electrical Machines | How are alternators classified? |
| 210 | Electrical Machines | How is the speed of a squirrel cage induction motor changed? |
| 211 | Electrical Machines | Advantage of a double squirrel cage induction motor? |
| 212 | Electrical Machines | Differences between 3-phase induction motor and a transformer? |
| 213 | Electrical Machines | Explain the statement that induction motor is fundamentally a transformer? |
| 214 | Electrical Machines | Why is the sum of rotor core loss and friction and windage losses of a 3-phase induction motor nearly constant at all loads? |
| 215 | Electrical Machines | When will rotor resistance dominate rotor reactance and vice-versa? |
| 216 | Electrical Machines | Why is the maximum torque of a squirrel cage induction motor called pull-out torque? |
| 217 | Electrical Machines | How will you design the rotor of a squirrel cage motor to have high starting torque? |
| 218 | Electrical Machines | Advantages of skewed slots in the rotor of a squirrel cage motor? |
| 219 | Electrical Machines | Why is the power factor of a fully loaded 3-phase induction motor not very high? |
| 220 | Electrical Machines | Why is the power factor of a 3-phase induction motor low at no-toad? |
| 221 | Electrical Machines | What is the origin of the name squirrel cage rotor? |
| 222 | Electrical Machines | Disadvantages of wound rotor motors compared to squirrel cage motors? |
| 223 | Electrical Machines | Advantages of wound rotor motors over squirrel cage motors? |
| 224 | Electrical Machines | Difference between squirrel cage rotor and wound rotor? |
| 225 | Electrical Machines | What is the importance of slip in a 3-phase induction motor? |
| 226 | Electrical Machines | How is magnetizing current kept small in a 3-phase induction motor? |
| 227 | Electrical Machines | Why is the air gap between the rotor and stator of a 3-phase induction motor kept as short as possible? |
| 228 | Electrical Machines | Why cannot 3-phase induction motor run at synchronous ‘speed? |
| 229 | Electrical Machines | Why does the rotor of a 3-phase induction motor rotate in the same direction as the rotating field? |
| 230 | Electrical Machines | Why is the field producing winding of a 3-phase induction motor made stationary? |
| 231 | Electrical Machines | What do you mean by synchronous speed of a 3-phase induction motor? |
| 232 | Electrical Machines | What is the function of inner winding of double cage construction? |
| 233 | Electrical Machines | What is the function of outer winding of double cage construction? |
| 234 | Electrical Machines | Why double-cage construction is used in Motors? |
| 235 | Electrical Machines | What do you mean by horsepower rating and does it shows motor synchronous speed? |
| 236 | Electrical Machines | What are the different Ratings used for Induction Motor? |
| 237 | Electrical Machines | Disadvantage of slip-ring motors |
| 238 | Electrical Machines | What are the advantages of slip-ring induction motors over the squirrel cage motors? |
| 239 | Electrical Machines | What are the advantages of Autotransformer starting? |
| 240 | Electrical Machines | What is Autotransformer starting method? |
| 241 | Electrical Machines | Why Stator resistance starting is not recommended? |
| 242 | Electrical Machines | What is Stator resistance starting method? |
| 243 | Electrical Machines | Does starting torque is higher than full load torque? |
| 244 | Electrical Machines | What is Direct-on-line starting of induction motor? |
| 245 | Electrical Machines | How slip ring motors are started? |
| 246 | Electrical Machines | Methods of Starting 3-Phase Induction Motors |
| 247 | Electrical Machines | What is the effect of staring of induction motor on connected line? |
| 248 | Electrical Machines | Why it is required to start 3-Phase Induction Motors? |
| 249 | Electrical Machines | How transformation ratio of induction motor is different as compared to power transformer? |
| 250 | Electrical Machines | Why the exciting current of induction motor is so high as compared to the power transformer? |
| 251 | Electrical Machines | Magnetic flux is said to rotate at synchronous speed why? |
| 252 | Electrical Machines | What is Synchronous speed? |
| 253 | Electrical Machines | How Rotating Magnetic Field is produced in three phase induction motor? |
| 254 | Electrical Machines | Why the starting torque of Squirrel cage induction motor is LOW? |
| 255 | Electrical Machines | What do you mean by squirrel cage induction motors? |
| 256 | Electrical Machines | How rotor windings are connected to supply and why wound rotor type is preferred to squirrel cage type induction motor? |
| 257 | Electrical Machines | Differentiate between Squirrel cage type rotor and Wound type rotor? |
| 258 | Electrical Machines | What are the major types of Rotor Winding placed in 3 phase induction motor? |
| 259 | Electrical Machines | In which motor both stator and rotor winding are connected to voltage source? |
| 260 | Electrical Machines | With what material the rotor of 3 phase motor is made? |
| 261 | Electrical Machines | What is the effect of no. of poles on speed of motor? |
| 262 | Electrical Machines | With what material the Stator of three phase induction motor is made? |
| 263 | Electrical Machines | Describe the construction of a three phase motor? |
| 264 | Electrical Machines | What are the advantages and disadvantages of three phase induction motor? |
| 265 | Electrical Machines | What is the Three Phase induction motor Working Principle? |
| 266 | Electrical Machines | Usually where split phase induction motors are used? |
| 267 | Electrical Machines | What is speed variation of split phase induction motor from no load to full load? |
| 268 | Electrical Machines | Why built-in-thermal relay is necessary in split phase induction motor and what is its purpose? |
| 269 | Electrical Machines | Why split-phase induction motors are most popular single- phase motors in the market? |
| 270 | Electrical Machines | What is starting torque and starting current of split phase induction motor? |
| 271 | Electrical Machines | Describe the principal of operation of Split-Phase Induction Motor? |
| 272 | Electrical Machines | What is the major cause of noisy operation of the single phase induction motor? |
| 273 | Electrical Machines | How to produce Rotating Magnetic Field From 2-Phase Supply? |
| 274 | Electrical Machines | Name the types of single phase motors with respect to the method employed to make them self-starting? |
| 275 | Electrical Machines | How to make Single-Phase Induction Motor Self-Starting? |
| 276 | Electrical Machines | Explain motor action from standstill to running condition? |
| 277 | Electrical Machines | What is the value of slip at standstill? |
| 278 | Electrical Machines | What is the position of rotor at standstill? |
| 279 | Electrical Machines | Explain why single phase induction motor does not start in the light of Double-Field Revolving Theory? |
| 280 | Electrical Machines | What is basic method to start single phase induction motor and why it is not preferred? |
| 281 | Electrical Machines | Why single phase induction motor does not self starts? |
| 282 | Electrical Machines | What is major difference between a 3-phase induction motor and a single-phase induction motor? |
| 283 | Electrical Machines | How a single phase motor is similar to 3 phase motor? |
| 284 | Electrical Machines | Types of single phase Synchronous motors |
| 285 | Electrical Machines | Types of Repulsion motors |
| 286 | Electrical Machines | Name some Single-phase induction motors |
| 287 | Electrical Machines | What are the different methods of speed control of induction motors? |
| 288 | Electrical Machines | What is Single Phasing and problems associated with it in Induction Motor? |
| 289 | Electrical Machines | What is Stalling in Induction motor and how to protect motor during Stalling? |
| 290 | Electrical Machines | Why Negative sequence current protection is provided for Induction Motor? |
| 291 | Electrical Machines | Why prolonged overloading protection is required for Induction motor? |
| 292 | Electrical Machines | What are the type of faults that are likely to occur in operation of 3 phase induction motor? |
| 293 | Electrical Machines | Why it not necessary to provide over-voltage protection in turbo-alternator? |
| 294 | Electrical Machines | Why it is necessary to suppress field immediately after disconnection of faulty alternator from the system? |
| 295 | Electrical Machines | Why it is not necessary to provide protection for turn to turn fault in alternator? |
| 296 | Electrical Machines | Why large alternator is grounded with large resistance? |
| 297 | Electrical Machines | Explain Differential Protection? |
| 298 | Electrical Machines | What is advantage of using percentage differential relay protection? |
| 299 | Electrical Machines | What is the disadvantage of ordinary differential protection? |
| 300 | Electrical Machines | For what type of faults does differential protection is provided? |
| 301 | Electrical Machines | What are the common types of generator faults? |
| 302 | Electrical Machines | Transformer Testing methods |
| 303 | Electrical Machines | What is Transformer Breathing? |
| 304 | Electrical Machines | What are the different insulation materials used in power transformers? |
| 305 | Electrical Machines | Why Low Voltage (LV) winding is placed near to the transformer core? |
| 306 | Electrical Machines | Induction Motor Rotating Transformer Relation |
| 307 | Electrical Machines | All Day Efficiency of Transformer |
| 308 | Electrical Machines | Low Voltage winding near core of the Transformer |
| 309 | Electrical Machines | Why Transformer rating is in KVA not kW |
| 310 | Electrical Machines | How Transformer Impedance is designed |
| 311 | Electrical Machines | Why Silica gel is used in transformer |
| 312 | Electrical Machines | Where Star (wye) Delta transformer is used in Power system |
| 313 | Electrical Machines | What is the relation between applied voltage and emf induced with respect to flux wave? |
| 314 | Electrical Machines | Why power factor of the transformer under no load is very low? |
| 315 | Electrical Machines | What is excitation current or magnetising current in Transformer? |
| 316 | Electrical Machines | Voltage Regulation of Transformer |
| 317 | Electrical Machines | Different Tests conducted on Transformers |
| 318 | Electrical Machines | Insulation Materials used in Transformers and Induction Motors |
| 319 | Electrical Machines | Power and Distribution Transformer |
| 320 | Electrical Machines | What is the Ideal transformer? |
| 321 | Electrical Machines | What is the emf equation of transformer? |
| 322 | Electrical Machines | Why efficiency of transformer is high? |
| 323 | Electrical Machines | Transformer works on which principle? |
| 324 | Electrical Machines | If supply frequency transformer is made double keeping voltage unchanged what happens? |
| 325 | Electrical Machines | Types of dry type transformers |
| 326 | Electrical Machines | Advantages of Dry Type Transformers |
| 327 | Electrical Machines | Disadvantages of Auto-transformer |
| 328 | Electrical Machines | Advantages of Auto-transformer |
| 329 | Electrical Machines | When DC supply given to Transformer what happens? |
| 330 | Electrical Machines | Transformer Parallel operation conditions |
| 331 | Electrical Machines | Different Transformer Internal Faults |
| 332 | Electrical Machines | Methods to reduce Transformer noise |
| 333 | Electrical Machines | Magnetostriction: Noise In Transformer: |
| 334 | Electrical Machines | Why Delta winding prefer |
| 335 | Electrical Machines | Advantages of Three Winding Transformers |
| 336 | Electrical Machines | Factors Significantly Impact Inrush Currents in Transformer: |
| 337 | Electrical Machines | Inrush Currents in Transformers-Causes |
| 338 | Electrical Machines | Explain the operation of induction motor in simple words? |
| 339 | Electrical Machines | Why Speed Control of Induction Motor is difficult compared to DC shunt motor? |
| 340 | Electrical Machines | Why the efficiency of the Induction motor is less compared to transformer? |
| 341 | Electrical Machines | What is the relation between between Induction motor and Transformer? |
| 342 | Electrical Machines | Why Induction motors are widely used in Industries? |
| 343 | Electrical Machines | What happens when Induction motor is loaded? |
| 344 | Electrical Machines | What is the relative speed between the fields set up by the stator and rotor? |
| 345 | Electrical Machines | What is the speed of the rotor magnetic field with respect to rotor? |
| 346 | Electrical Machines | What is the direction of rotation of rotor with respect to the rotating magnetic field? |
| 347 | Electrical Machines | What is the relation between torque and supply voltage in 3 phase induction motor? |
| 348 | Electrical Machines | What are the different losses in 3 phase induction motor? |
| 349 | Electrical Machines | When we can get Maximum Torque in Induction Motor while starting? |
| 350 | Electrical Machines | Different starting methods of 3 phase induction motor |
| 351 | Electrical Machines | How direction of 3 phase Induction Motor can be changed |
| 352 | Electrical Machines | Why Induction Machine always runs below synchronous speed? |
| 353 | Electrical Machines | Define Slip in Induction Machine? |
| 354 | Electrical Machines | Drawbacks of Brake test? |
| 355 | Electrical Machines | What are the different losses in dc machine? |
| 356 | Electrical Machines | Factor that has to be considered while choosing the resistor? |
| 357 | Electrical Machines | Why do we use starter for dc machine? |
| 358 | Electrical Machines | What is field flashing? |
| 359 | Electrical Machines | When DC Generator fails to build up the voltage, what are the reasons? |
| 360 | Electrical Machines | Advantages Disadvantages of DC Series Motor |
| 361 | Electrical Machines | What is the speed variation of the induction motor from no load to full load? |
| 362 | Electrical Machines | What is the advantage of Squirrel Cage Induction Motor? |
| 363 | Electrical Machines | What is the advantage of Slip Ring Induction Motor? |
| 364 | Electrical Machines | What are different types of Induction Motors available? |
| 365 | Electrical Machines | What happen when Induction motor run at synchronous speed? |
| 366 | Electrical Machines | Why Induction Motor name has come? |
| 367 | Electrical Machines | Disadvantages of Star-Delta Starting of Induction motor? |
| 368 | Electrical Machines | Torque-Slip Characteristics vary when adding resistance to rotor circuit? |
| 369 | Electrical Machines | Methods to control speed of Wound Rotor Motors? |
| 370 | Electrical Machines | Advantages and disadvantages of Slip ring induction motor |
| 371 | Electrical Machines | What is the condition for maximum torque in induction motor? |
| 372 | Electrical Machines | Advantages and disadvantages of Induction Motors |
| 373 | Electrical Machines | A dc series motor should not be switched on without a load on its shaft |
| 374 | Electrical Machines | In the open circuit test of transformer, the instruments are placed on the LV side, while in the short circuit test, these are placed on the HV side |
| 375 | Electrical Machines | The primary of a transformer draws more current when the load on the transformer increases |
| 376 | Electrical Machines | A 3 point starter often trips when the speed control of the dc motor is carried out by shunt field control |
| 377 | Electrical Machines | The condition prevailing in the blocked rotor test of three phase induction motors resemble those of a transformer whose secondary is short circuited |
| 378 | Electrical Machines | The rotor of a three phase induction motor rotates in the same direction as the rotating field produced by the stator flux |
| 379 | Electrical Machines | Reactance of the rotor varies widely between starting and running conditions |
| 380 | Electrical Machines | Transformer and other electrical machines in per unit system |
| 381 | Electrical Machines | DC motor adjusts its input automatically to match the load on the shaft |
| 382 | Electrical Machines | Two shunt generators operating in parallel tend to remain in stable equilibrium |
| 383 | Electrical Machines | Terminal voltage of a dc generator can be kept constant by compounding the generator |
| 384 | Electrical Machines | Lap winding is suitable for high current and low voltage generators? |
| 385 | Electrical Machines | Shunt motors are considered constant speed motors |
| 386 | Electrical Machines | A self excited generator fails to excite if driven at too low a speed |
| 387 | Electrical Machines | A variable reluctance stepper motor is constructed of _______ material with salient poles |
| 388 | Electrical Machines | About the Electrical Machines category |
| 389 | Power Electronics | VDF analog comunication problem |
| 390 | Power Electronics | Weidmuller RSM Interface usage |
| 391 | Power Electronics | Advantages of Variable Frequency Drives (VFD) |
| 392 | Power Electronics | Types of Variable Frequency Drives (VFD) |
| 393 | Power Electronics | Electronic Crowbar Protection |
| 394 | Power Electronics | SCR Over Current Protection |
| 395 | Power Electronics | SCR di/dt Protection |
| 396 | Power Electronics | Types of Thyristor Protection |
| 397 | Power Electronics | Why is pulse triggering preferred over RC triggering? |
| 398 | Power Electronics | Distinguish between holding current and latching current of SCR |
| 399 | Power Electronics | What is fast recovery diode? |
| 400 | Power Electronics | Disadvantages of Frequency Modulation (FM) scheme used in choppers |
| 401 | Power Electronics | What is PWM? List its various techniques |
| 402 | Power Electronics | Advantages of GTO over BJT |
| 403 | Power Electronics | Types of AC voltage controllers |
| 404 | Power Electronics | Merits and demerits of AC voltage controller |
| 405 | Power Electronics | Function of free wheeling diode in semiconverter |
| 406 | Power Electronics | Advantages and disadvantages of buck/boost regulator |
| 407 | Power Electronics | What is full converter? What is dual converter? |
| 408 | Power Electronics | What are the control strategies of chopper? |
| 409 | Power Electronics | For Selecting MOSFET, what are the major parameters we have to consider in the datasheet? |
| 410 | Power Electronics | What are the various parameters we have to consider, while selecting IGBT? |
| 411 | Power Electronics | For High frequency applications will you prefer MOSFET or IGBT? Why? |
| 412 | Power Electronics | For High voltage applications will you prefer MOSFET or IGBT? |
| 413 | Power Electronics | Name some of the current controlled (current driven) devices |
| 414 | Power Electronics | What is meant by SOA? |
| 415 | Power Electronics | What is firing angle? |
| 416 | Power Electronics | What is hard switching of the thyristor? |
| 417 | Power Electronics | What are the different turn on methods of SCR? |
| 418 | Power Electronics | What is latching current in SCR? |
| 419 | Power Electronics | What is holding current in SCR? |
| 420 | Power Electronics | What are the advantages in operation of choppers at high frequency? |
| 421 | Power Electronics | What are the various control strategies for varying duty cycle of the chopper |
| 422 | Power Electronics | Advantages of three-phase drives over single phase drives |
| 423 | Power Electronics | What causes poor input power factor in phase controlled DC drives? |
| 424 | Power Electronics | Why thyristors are not preferred now a days for chopper fed DC drives? |
| 425 | Power Electronics | What is negative converter group in a cycloconverter? |
| 426 | Power Electronics | What is positive converter group in a cycloconverter? |
| 427 | Power Electronics | Applications of cyclo-converter |
| 428 | Power Electronics | What is step-down cyclo-converters? |
| 429 | Power Electronics | What is step-up cyclo-converters? |
| 430 | Power Electronics | Types of cyclo-converters |
| 431 | Power Electronics | What is cyclo-converter? |
| 432 | Power Electronics | Advantages of sequence control of ac voltage regulators |
| 433 | Power Electronics | What is meant by sequence control of ac voltage regulators? |
| 434 | Power Electronics | Disadvantages of continuous gating signal |
| 435 | Power Electronics | What type of gating signal is used in single phase ac voltage controller with RL load? |
| 436 | Power Electronics | What is meant by bidirectional or half-wave ac voltage controller? |
| 437 | Power Electronics | Disadvantages of unidirectional or half-wave ac voltage controller |
| 438 | Power Electronics | Disadvantage of ON-OFF control |
| 439 | Power Electronics | Advantage of ON-OFF control |
| 440 | Power Electronics | Difference between ON-OFF control and phase control |
| 441 | Power Electronics | What are the two methods of control in ac voltage controllers? |
| 442 | Power Electronics | Disadvantages of AC voltage controllers |
| 443 | Power Electronics | Advantages of ac voltage controllers |
| 444 | Power Electronics | Applications of ac voltage controllers |
| 445 | Power Electronics | What does ac voltage controller mean? |
| 446 | Power Electronics | Disadvantages of PWM control |
| 447 | Power Electronics | What are the methods of reduction of harmonic content? |
| 448 | Power Electronics | Disadvantages of the harmonics present in the inverter system |
| 449 | Power Electronics | Advantages of PWM control |
| 450 | Power Electronics | What is PWM control? |
| 451 | Power Electronics | Applications of a CSI |
| 452 | Power Electronics | What is McMurray inverter? |
| 453 | Power Electronics | How is the inverter circuit classified based on commutation circuitry? |
| 454 | Power Electronics | Applications of a series inverter |
| 455 | Power Electronics | What is meant a parallel inverter? |
| 456 | Power Electronics | What is meant a series inverter? |
| 457 | Power Electronics | What types of inverters require feedback diodes? |
| 458 | Power Electronics | Why diodes should be connected in antiparallel with the thyristors in inverter circuits? |
| 459 | Power Electronics | What is the main drawback of a single phase half bridge inverter? |
| 460 | Power Electronics | How output frequency is varied in case of a thyristor? |
| 461 | Power Electronics | Why thyristors are not preferred for inverters? |
| 462 | Power Electronics | Classification of inverters |
| 463 | Power Electronics | Applications of an inverter |
| 464 | Power Electronics | What is meant by inverter? |
| 465 | Power Electronics | Disadvantages of load commutated chopper |
| 466 | Power Electronics | Advantages of load commutated chopper |
| 467 | Power Electronics | Advantages of current commutated chopper |
| 468 | Power Electronics | What is meant by load commutation? |
| 469 | Power Electronics | What is meant by current commutation? |
| 470 | Power Electronics | What is meant by voltage commutation? |
| 471 | Power Electronics | Types of chopper with respect to commutation process |
| 472 | Power Electronics | What is meant by PWM control in dc chopper? |
| 473 | Power Electronics | What is duty-cycle? |
| 474 | Power Electronics | What is step-up and step-down chopper? |
| 475 | Power Electronics | Advantages of DC chopper |
| 476 | Power Electronics | Applications of DC chopper |
| 477 | Power Electronics | What is meant by DC chopper? |
| 478 | Power Electronics | What is meant by forced commutation? |
| 479 | Power Electronics | What is meant by natural commutation? |
| 480 | Power Electronics | What are the types of commutation? |
| 481 | Power Electronics | What is commutation? |
| 482 | Power Electronics | Advantages of six pulse converter |
| 483 | Power Electronics | Different methods of firing circuits for line commutated converter |
| 484 | Power Electronics | What is commutation angle or overlap angle? |
| 485 | Power Electronics | Advantages of single phase bridge converter over single phase mid-point converter |
| 486 | Power Electronics | What is meant by delay angle? |
| 487 | Power Electronics | Advantages of freewheeling diodes |
| 488 | Power Electronics | Function of freewheeling diodes in controlled rectifier? |
| 489 | Power Electronics | Applications of controlled rectifier |
| 490 | Power Electronics | What is meant by phase controlled rectifier? |
| 491 | Power Electronics | What are the advantages of GTO over SCR? |
| 492 | Power Electronics | What is the turn-off time for converter grade SCRs and inverter grade SCRs? |
| 493 | Power Electronics | Why circuit turn off time should be greater than the thyristor turn-off time? |
| 494 | Power Electronics | Define circuit turn off time |
| 495 | Power Electronics | Define hard-driving or over-driving |
| 496 | Power Electronics | What losses occur in a thyristor during working conditions? |
| 497 | Power Electronics | What is a snubber circuit? |
| 498 | Power Electronics | Define holding current? |
| 499 | Power Electronics | Define latching current? |
| 500 | Power Electronics | How can a thyristor turned OFF? |
| 501 | Power Electronics | What are the different types of power MOSFET? |
| 502 | Power Electronics | Power BJT is a current controlled device. Why? |
| 503 | Power Electronics | Power MOSFET is a voltage controlled device. Why? |
| 504 | Power Electronics | IGBT is a voltage controlled device. Why? |
| 505 | Power Electronics | Different methods to Turn ON the thyristor? |
| 506 | Power Electronics | Advantages of IGBT |
| 507 | Power Electronics | About the Power Electronics category |
| 508 | SwitchGear & Protection | Difference between metering and protection current transformers |
| 509 | SwitchGear & Protection | Working Principle of Antipumping Relay |
| 510 | SwitchGear & Protection | Why Doesn’t Electrical Tester Glow for DC? |
| 511 | SwitchGear & Protection | Functional Testing of MCB |
| 512 | SwitchGear & Protection | What is difference between MCB and ELCB? |
| 513 | SwitchGear & Protection | Where to use 4 Pole MCB instead of TPN MCB |
| 514 | SwitchGear & Protection | Where to use 4 Pole or TPN MCB instead of 3 Pole (TP) MCB |
| 515 | SwitchGear & Protection | Where to Use TP, TPN and 4P in Distribution panel |
| 516 | SwitchGear & Protection | Difference between TPN and 4P (or SPN and DP) |
| 517 | SwitchGear & Protection | Difference between 1 pole mcb and 3 pole MCB? |
| 518 | SwitchGear & Protection | Protection Relays |
| 519 | SwitchGear & Protection | Overcurrent Relay |
| 520 | SwitchGear & Protection | How definite time lag is achieved in attraction armature relays? |
| 521 | SwitchGear & Protection | For what type of fault does Buchholz relay is employed? |
| 522 | SwitchGear & Protection | Where is directional relay used? |
| 523 | SwitchGear & Protection | Define Plug Setting Multiplier? |
| 524 | SwitchGear & Protection | What is meant by “Relay Settings”? |
| 525 | SwitchGear & Protection | Functions of Differential Relays |
| 526 | SwitchGear & Protection | What is percentage differential relay? |
| 527 | SwitchGear & Protection | Where Impedance relay, Reactance relay and Mho relays are employed? |
| 528 | SwitchGear & Protection | Why biased differential protection is preferred over simple differential protection? |
| 529 | SwitchGear & Protection | Why distance protection is preferred as primary protection compared to over current protection for transmission lines? |
| 530 | SwitchGear & Protection | What is the operation principle of differential relay? |
| 531 | SwitchGear & Protection | Where does Negative phase sequence relay is employed? |
| 532 | SwitchGear & Protection | What is dielectric test of a circuit breaker? |
| 533 | SwitchGear & Protection | How direct tests are conducted in circuit breakers? |
| 534 | SwitchGear & Protection | Differentiate between a fuse and a circuit breaker |
| 535 | SwitchGear & Protection | Different types of circuit breakers |
| 536 | SwitchGear & Protection | State the significance of single line to ground fault |
| 537 | SwitchGear & Protection | What is arc suppression coil? |
| 538 | SwitchGear & Protection | What are arcing grounds? |
| 539 | SwitchGear & Protection | State the various types of earthing |
| 540 | SwitchGear & Protection | Define composite testing of a circuit breaker |
| 541 | SwitchGear & Protection | Define an under current relay? |
| 542 | SwitchGear & Protection | Define a over current relay |
| 543 | SwitchGear & Protection | What is pick up value? |
| 544 | SwitchGear & Protection | How does the over voltage surge affect the power system? |
| 545 | SwitchGear & Protection | What are the advantages of synthetic testing methods? |
| 546 | SwitchGear & Protection | What are the indirect methods of circuit breaker testing? |
| 547 | SwitchGear & Protection | Classifications of test conducted on circuit breakers |
| 548 | SwitchGear & Protection | What are the characteristic of SF6 gas? |
| 549 | SwitchGear & Protection | What is meant by electronegativity of SF6 gas? |
| 550 | SwitchGear & Protection | What are the demerits of using oil as an arc quenching medium? |
| 551 | SwitchGear & Protection | What are the advantages of air blast circuit breaker over oil circuit breaker? |
| 552 | SwitchGear & Protection | What are the types of air blast circuit breaker? |
| 553 | SwitchGear & Protection | What are the disadvantages of MOCB over a bulk oil circuit breaker? |
| 554 | SwitchGear & Protection | What are the advantages of MOCB over a bulk oil circuit breaker? |
| 555 | SwitchGear & Protection | What are the advantages of oil as arc quenching medium? |
| 556 | SwitchGear & Protection | What are demerits of MOCB? |
| 557 | SwitchGear & Protection | Main problem of the circuit breaker |
| 558 | SwitchGear & Protection | Classification of circuit breakers based on the medium used for arc extinction |
| 559 | SwitchGear & Protection | What is circuit breaker? |
| 560 | SwitchGear & Protection | What is RRRV? |
| 561 | SwitchGear & Protection | What is meant by recovery voltage? |
| 562 | SwitchGear & Protection | What is restriking voltage? |
| 563 | SwitchGear & Protection | Methods of arc interruption |
| 564 | SwitchGear & Protection | What is an arc? |
| 565 | SwitchGear & Protection | What are the methods of capacitive switching? |
| 566 | SwitchGear & Protection | What is resistance switching? |
| 567 | SwitchGear & Protection | Advantages of static relay over electromagnetic relay? |
| 568 | SwitchGear & Protection | What is CPMC? |
| 569 | SwitchGear & Protection | What is a programmable relay? |
| 570 | SwitchGear & Protection | What is power swing? |
| 571 | SwitchGear & Protection | What is static relay? |
| 572 | SwitchGear & Protection | What are the problems in bus zone differential protection? |
| 573 | SwitchGear & Protection | What are the causes of bus zone faults? |
| 574 | SwitchGear & Protection | What is field suppression? |
| 575 | SwitchGear & Protection | What are the errors in CT? |
| 576 | SwitchGear & Protection | What are the merits of carrier current protection? |
| 577 | SwitchGear & Protection | Why busbar protection is needed? |
| 578 | SwitchGear & Protection | What is over fluxing protection in transformer? |
| 579 | SwitchGear & Protection | What is REF relay? |
| 580 | SwitchGear & Protection | What are the problems arising in differential protection in power transformer and how are they overcome? |
| 581 | SwitchGear & Protection | Limitations of Buchholz relay |
| 582 | SwitchGear & Protection | What are the main safety devices available with transformer? |
| 583 | SwitchGear & Protection | What are faults associated with an alternator? |
| 584 | SwitchGear & Protection | What is the backup protection available for an alternator? |
| 585 | SwitchGear & Protection | Why neutral resistor is added between neutral and earth of an alternator? |
| 586 | SwitchGear & Protection | What are the various faults that would affect an alternator? |
| 587 | SwitchGear & Protection | Types of graded used in line of radial relay feeder? |
| 588 | SwitchGear & Protection | Uses of Buchholz’s relay |
| 589 | SwitchGear & Protection | Limitations of Merz Price protection |
| 590 | SwitchGear & Protection | What are the main types of stator winding faults? |
| 591 | SwitchGear & Protection | What are the causes of over speed and how alternators are protected from it? |
| 592 | SwitchGear & Protection | What are the features of directional relay? |
| 593 | SwitchGear & Protection | Disadvantage of carrier current scheme for transmission line only |
| 594 | SwitchGear & Protection | Define the term pilot with reference to power line protection |
| 595 | SwitchGear & Protection | What is an under frequency relay? |
| 596 | SwitchGear & Protection | What are the various faults to which a turbo alternator is likely to be subjected? |
| 597 | SwitchGear & Protection | Mention the short comings of Merz Price scheme of protection applied to a power transformer |
| 598 | SwitchGear & Protection | What is the need of relay coordination? |
| 599 | SwitchGear & Protection | What is biased differential bus zone reduction? |
| 600 | SwitchGear & Protection | Applications of differential relay |
| 601 | SwitchGear & Protection | What are over and under current relays? |
| 602 | SwitchGear & Protection | Define resetting time of a relay |
| 603 | SwitchGear & Protection | Define operating time of a relay |
| 604 | SwitchGear & Protection | Define energizing quantity |
| 605 | SwitchGear & Protection | Different types of over current relays |
| 606 | SwitchGear & Protection | What is back up protection? |
| 607 | SwitchGear & Protection | What is primary protection? |
| 608 | SwitchGear & Protection | What are unit system and non unit system? |
| 609 | SwitchGear & Protection | Define protected zone |
| 610 | SwitchGear & Protection | Give the consequences of short circuit |
| 611 | SwitchGear & Protection | What are the functions of protective relays |
| 612 | SwitchGear & Protection | What is meant by motors in synchronous tie? |
| 613 | SwitchGear & Protection | What is a slip resistance? |
| 614 | SwitchGear & Protection | Advantage of a liquid resistance for starting purposes |
| 615 | SwitchGear & Protection | What is liquid resistance? |
| 616 | SwitchGear & Protection | How is speed control of a slip-ring motor effected? |
| 617 | SwitchGear & Protection | What are the essentials of a full-automatic stator-rotor starter? |
| 618 | SwitchGear & Protection | What is the usual arrangement of connections for a hand-operated slip-ring starter? |
| 619 | SwitchGear & Protection | How are slip-ring motors started? |
| 620 | SwitchGear & Protection | What is sequence starting? |
| 621 | SwitchGear & Protection | What mechanical methods of reducing starting current can be adopted? |
| 622 | SwitchGear & Protection | How do the various methods of starting on reduced voltage compare as regards torque per ampere? |
| 623 | SwitchGear & Protection | Why are the above values of initial-starting current and torque approximate? |
| 624 | SwitchGear & Protection | What are the initial-starting line current and motor torque when star-delta starting? |
| 625 | SwitchGear & Protection | When is an auto-transformer starter used? |
| 626 | SwitchGear & Protection | When is direct-on-line starting used for three-phase squirrel-cage motors? |
| 627 | SwitchGear & Protection | How do built-in thermal overload protectors work? |
| 628 | SwitchGear & Protection | How are built in thermal overload protector arranged? |
| 629 | SwitchGear & Protection | What are the alternatives to the use of overload releases? |
| 630 | SwitchGear & Protection | What special protection can be provided against single-phasing? |
| 631 | SwitchGear & Protection | Will normal overload relays trip on single-phasing? |
| 632 | SwitchGear & Protection | What happens when one of the three lines supplying a three-phase induction motor becomes open-circuited? |
| 633 | SwitchGear & Protection | How many overload relays are required in the control gear? |
| 634 | SwitchGear & Protection | How does the magnetic overload relay operate? |
| 635 | SwitchGear & Protection | How thermal relays work? |
| 636 | SwitchGear & Protection | What are the usual forms of overload relay in motor-control gear? |
| 637 | SwitchGear & Protection | What provision must be made for short-circuit conditions in motor circuits? |
| 638 | SwitchGear & Protection | What devices are required to give adequate protection to the motor? |
| 639 | SwitchGear & Protection | What are the main functions of control gear? |
| 640 | SwitchGear & Protection | For an Resistive Load and Inductive load considered for switching operation of circuit breaker, Switching of which load is difficult and Why? |
| 641 | SwitchGear & Protection | What is re-striking voltage? |
| 642 | SwitchGear & Protection | When does an arc extincts? |
| 643 | SwitchGear & Protection | What is recovery voltage in circuit breaker? |
| 644 | SwitchGear & Protection | Why asymmetrical breaking current is higher than the symmetrical breaking current in a circuit breaker? |
| 645 | SwitchGear & Protection | Why Isolation switches are provided along with the circuit breakers? |
| 646 | SwitchGear & Protection | What is meant by Current Chopping? |
| 647 | SwitchGear & Protection | What are the some precautions must be taken when using a booster transformer? |
| 648 | SwitchGear & Protection | Why excitation control is not possible beyond certain limits? |
| 649 | SwitchGear & Protection | Why it is necessary to keep the receiving end voltage constant within specified limits? |
| 650 | SwitchGear & Protection | What is a booster transformer? |
| 651 | SwitchGear & Protection | Different methods of controlling voltage in an ac supply system? |
| 652 | SwitchGear & Protection | How the Voltage Control in power system is achieved? |
| 653 | SwitchGear & Protection | Purpose of Circuit Breakers |
| 654 | SwitchGear & Protection | For EHV applications which type of circuit breaker is mostly preferred? |
| 655 | SwitchGear & Protection | Why current chopping considered as serious drawback in a circuit breaker? |
| 656 | SwitchGear & Protection | Materials used for the contacts of vacuum circuit breakers? |
| 657 | SwitchGear & Protection | Why current chopping is not common in oil circuit breakers? |
| 658 | SwitchGear & Protection | What is meant by making capacity of the circuit breaker? |
| 659 | SwitchGear & Protection | How does a Circuit Breaker different from Switch? |
| 660 | SwitchGear & Protection | What is a Circuit Breaker? |
| 661 | SwitchGear & Protection | Some of the causes for relay failures? |
| 662 | SwitchGear & Protection | What are the good features of protective relaying? |
| 663 | SwitchGear & Protection | What are the fundamental elements of relay? |
| 664 | SwitchGear & Protection | What is Reach? |
| 665 | SwitchGear & Protection | What is fault clearance time? |
| 666 | SwitchGear & Protection | What is Relay Time? |
| 667 | SwitchGear & Protection | Action carried out by the relay and circuit breaker during fault condition? |
| 668 | SwitchGear & Protection | What are different types of principles of operation of electro-mechaical relays? |
| 669 | SwitchGear & Protection | How relays are connected in the power system? |
| 670 | SwitchGear & Protection | How the electrical power system protection is divided? |
| 671 | SwitchGear & Protection | Different relays that employed for protection of apparatus and transmission lines |
| 672 | SwitchGear & Protection | What is protective relay? |
| 673 | SwitchGear & Protection | About the SwitchGear & Protection category |
| 674 | Transmission & Distribution | What is Ferranti Effect? |
| 675 | Transmission & Distribution | Advantages of HVDC Transmission |
| 676 | Transmission & Distribution | Methods to improve the strength of transmission system |
| 677 | Transmission & Distribution | Factors that limit the maximum power transfer capability in a transmission line? |
| 678 | Transmission & Distribution | Why does surge impedance loading increase with increase in voltage level? |
| 679 | Transmission & Distribution | What are the problems associated with EHV transmission? |
| 680 | Transmission & Distribution | What for series and shunt compensation provided in EHV transmission lines? |
| 681 | Transmission & Distribution | What are the different types of cores? |
| 682 | Transmission & Distribution | What is a Window Space Factor? |
| 683 | Transmission & Distribution | What is a Field Form Factor? |
| 684 | Transmission & Distribution | Which are preferred – Underground or Overhead cables? |
| 685 | Transmission & Distribution | Why do we use a wave trap? |
| 686 | Transmission & Distribution | What are the faults in a three phase line? |
| 687 | Transmission & Distribution | What is transmission cable made up of? |
| 688 | Transmission & Distribution | What is grading of cables? |
| 689 | Transmission & Distribution | Why do we require protection against lightning? |
| 690 | Transmission & Distribution | What is 3-Phase supply? |
| 691 | Transmission & Distribution | What is Arc formation? |
| 692 | Transmission & Distribution | What are Lightning Arrestors? |
| 693 | Transmission & Distribution | What is PLCC? |
| 694 | Transmission & Distribution | Equipment’s used in sub- station |
| 695 | Transmission & Distribution | Explain Transmission and Distribution systems |
| 696 | Transmission & Distribution | What are standard Transmission and Distribution voltages? |
| 697 | Transmission & Distribution | Why is voltage stepped up before transmission? |
| 698 | Transmission & Distribution | What is skin effect? |
| 699 | Transmission & Distribution | Why is alternating current used for transmission? |
| 700 | Transmission & Distribution | What is the first equipment of the substation connected to the incoming transmission line? |
| 701 | Transmission & Distribution | How standard lightning impulse wave is represented? |
| 702 | Transmission & Distribution | What is meant by voltage surge? |
| 703 | Transmission & Distribution | What is meant by impulse ratio of any lightning arrester? |
| 704 | Transmission & Distribution | What is meant by Lightning arrester or surge diverter? |
| 705 | Transmission & Distribution | What is the difference between the lightning arrester and surge absorber? |
| 706 | Transmission & Distribution | What is meant by protective angle? Give its value for reliable operation? |
| 707 | Transmission & Distribution | Why Earth Wire is provided in the overhead transmission lines? |
| 708 | Transmission & Distribution | What is the minimum time interval set for two adjacent circuit breakers to operate in radial feeders? |
| 709 | Transmission & Distribution | What is Unit Protection? |
| 710 | Transmission & Distribution | What is the purpose of Line trap and Coupling capacitors in carrier channels? |
| 711 | Transmission & Distribution | What types of relays are suitable for the protection of radial feeders? |
| 712 | Transmission & Distribution | Why Merz-Price Protection is not suitable beyond 33kV? |
| 713 | Transmission & Distribution | What are the main elements of current carrier protection? |
| 714 | Transmission & Distribution | What is meant by Tine Graded Protection? |
| 715 | Transmission & Distribution | About the Transmission & Distribution category |
| 716 | Electrical Engineering | Edz file Logger1000A-EU |
| 717 | Electrical Engineering | PCB Miroscopes |
| 718 | Electrical Engineering | ETAP Software Use |
| 719 | Electrical Engineering | How to Test an SCR?-Silicon Controlled Rectifier |
| 720 | Electrical Engineering | Mitigating the risk of 450kVa transfomer failure |
| 721 | Electrical Engineering | Types of Electrical Cables for different Voltages |
| 722 | Electrical Engineering | Motor Protection Equipment |
| 723 | Electrical Engineering | Affinity Laws for Pumps and Hydraulic Machinery |
| 724 | Electrical Engineering | Advantages and Disadvantages of VFD |
| 725 | Electrical Engineering | What is a VFD? |
| 726 | Electrical Engineering | Speed Control Equipment |
| 727 | Electrical Engineering | Thermographic Analysis |
| 728 | Electrical Engineering | Motor Energy Efficiency Opportunities |
| 729 | Electrical Engineering | Efficiency of Motors |
| 730 | Electrical Engineering | Characteristics of Induction Motor |
| 731 | Electrical Engineering | Starters-Starting Methods of three-phase Induction Motor |
| 732 | Electrical Engineering | Prime Movers |
| 733 | Electrical Engineering | UPS-Uninterruptible Power Supply |
| 734 | Electrical Engineering | Diesel Engine |
| 735 | Electrical Engineering | Standby Power Supply System (Generator) |
| 736 | Electrical Engineering | Operation of Electrical Equipment During Power Supply Interruption |
| 737 | Electrical Engineering | Power Factor Correction |
| 738 | Electrical Engineering | What is a Bus-bar? |
| 739 | Electrical Engineering | Low Tension (LT) Panel |
| 740 | Electrical Engineering | What is High Tension (HT) Substation? |
| 741 | Electrical Engineering | How do pull up and pull down resistors remove electrical noise? |
| 742 | Electrical Engineering | Voltage in ground |
| 743 | Electrical Engineering | Earthing and Grounding |
| 744 | Electrical Engineering | RCDs-residual-current device |
| 745 | Electrical Engineering | Locked rotor current of a motor |
| 746 | Electrical Engineering | Basic Motor Formulas |
| 747 | Electrical Engineering | Transformer Tap Changer Circuit |
| 748 | Electrical Engineering | Top Electrical Engineering Software Download |
| 749 | Electrical Engineering | Two bulbs of 100w and 40w respectively connected in series? |
| 750 | Electrical Engineering | Snake in Electrical Control Panel |
| 751 | Electrical Engineering | Cable Size Calculator |
| 752 | Electrical Engineering | What if the motor has to run in both directions and Phase Reversal protection is not required? |
| 753 | Electrical Engineering | What is meant by Phase Unbalance Protection? |
| 754 | Electrical Engineering | How a condition of Single Phasing or Phase Loss is protected? |
| 755 | Electrical Engineering | What is the meaning of Locked Rotor? |
| 756 | Electrical Engineering | What is better-Inverse or Definite type of protection? |
| 757 | Electrical Engineering | What is O-Time? |
| 758 | Electrical Engineering | What is D-Time? |
| 759 | Electrical Engineering | Bimetal Over Load Relay versus EOCR Electronic motor Protection Relay |
| 760 | Electrical Engineering | What is an Energy Audit? |
| 761 | Electrical Engineering | Bus coupler and Interconnecting transformers |
| 762 | Electrical Engineering | HVDC Transmission System |
| 763 | Electrical Engineering | Understanding Harmonics in a Simple Way |
| 764 | Electrical Engineering | Difference between Load angle and Power angle |
| 765 | Electrical Engineering | What is Smart Grid? |
| 766 | Electrical Engineering | Can we use an insulation tester for Ground Testing? |
| 767 | Electrical Engineering | What is static torque & dynamic torques? |
| 768 | Electrical Engineering | What is smallest achievable step angle in stepper motor? And how? |
| 769 | Electrical Engineering | Which type of motors maintain their position for a very long time, even if plant is off? |
| 770 | Electrical Engineering | Why do we have ac power line transmission, why can’t we feed DC? |
| 771 | Electrical Engineering | What happens if all coils(poles) in stepper motor are simlutaneously excited? What will be position attained by it? |
| 772 | Electrical Engineering | What are ways to lock position in stepper motor? |
| 773 | Electrical Engineering | Where does motor gets power to meet extra Torque Requirements? |
| 774 | Electrical Engineering | Hand off Auto Switch Operation |
| 775 | Electrical Engineering | Adsorption and desorption system-HVAC |
| 776 | Electrical Engineering | Absorption Refrigeration System |
| 777 | Electrical Engineering | How does evaporator work? |
| 778 | Electrical Engineering | What is An Absorption Chiller? |
| 779 | Electrical Engineering | What is an HVAC? |
| 780 | Electrical Engineering | What is a HVAC System? |
| 781 | Electrical Engineering | Working Principle of Water Chiller in HVAC System |
| 782 | Electrical Engineering | Working Principle of Absorption Chiller |
| 783 | Electrical Engineering | What is an Air-Conditioning System? |
| 784 | Electrical Engineering | Absorption Chiller Principle-HVAC System |
| 785 | Electrical Engineering | Capacity Control of Absorption Chillers |
| 786 | Electrical Engineering | Types of HVAC systems |
| 787 | Electrical Engineering | Heat Transfer Loops in HVAC System |
| 788 | Electrical Engineering | Difference between Water Cooled Chiller and Air Cooled Chiller in HVAC System |
| 789 | Electrical Engineering | Tips for HVAC System Engineers |
| 790 | Electrical Engineering | HVAC Applications of Valves |
| 791 | Electrical Engineering | Types of Chillers |
| 792 | Electrical Engineering | Difference between HVAC Absorption Chillers and Electric Chillers |
| 793 | Electrical Engineering | Silicon Carbide Lightning Arresters |
| 794 | Electrical Engineering | Cable Type : CV, CVS, CVVS ,CVV, MVVS |
| 795 | Electrical Engineering | Overload and Heater Elements for Motor Starters |
| 796 | Electrical Engineering | Air Insulated Substation |
| 797 | Electrical Engineering | How often should battery impedance testing be carried out? |
| 798 | Electrical Engineering | How important is inter-cell connection resistance in batteries? |
| 799 | Electrical Engineering | What are Instrument Transformers? |
| 800 | Electrical Engineering | What is Scott- connected transformer? |
| 801 | Electrical Engineering | Why an induction motor is called a rotating transformer? |
| 802 | Electrical Engineering | Why is transformer flux constant? |
| 803 | Electrical Engineering | Types of DC Generators |
| 804 | Electrical Engineering | What is Automatic Voltage Regulator (AVR)? |
| 805 | Electrical Engineering | What is Eddy Current Loss? |
| 806 | Electrical Engineering | What is the principle of operation of tube light? |
| 807 | Electrical Engineering | Potential Transformer (PT) |
| 808 | Electrical Engineering | Current Transformer (CT) |
| 809 | Electrical Engineering | Do stepper motors have internal or external fans? |
| 810 | Electrical Engineering | Which has more efficiency; synchronous or induction motor? |
| 811 | Electrical Engineering | Factors on which Hysteresis loss depends? |
| 812 | Electrical Engineering | WTypes of ratings of a machine |
| 813 | Electrical Engineering | What is the basic structure of a rotating electrical machine? |
| 814 | Electrical Engineering | How positive and negative terminals of a battery are identified? |
| 815 | Electrical Engineering | What is stratification in the battery? |
| 816 | Electrical Engineering | Do temperature have effect on battery? |
| 817 | Electrical Engineering | What is primary cell and secondary cell? |
| 818 | Electrical Engineering | What is mean by leakage flux? |
| 819 | Electrical Engineering | Define leakage inductance |
| 820 | Electrical Engineering | Properties of the oil used in the transformer |
| 821 | Electrical Engineering | How are sledging in transformer oil caused? |
| 822 | Electrical Engineering | Why is the efficiency of transformers more than that of other rotating machines? |
| 823 | Electrical Engineering | Why transformers are rated in KVA instead of KW? |
| 824 | Electrical Engineering | Advantages of switched reluctance motor |
| 825 | Electrical Engineering | Disadvantages of a Switched Reluctance Motor |
| 826 | Electrical Engineering | Working principle of Switching Reluctance Motor |
| 827 | Electrical Engineering | What is phase wingdings? |
| 828 | Electrical Engineering | What is Switched Reluctance Motor? |
| 829 | Electrical Engineering | Disadvantages of armature resistance control |
| 830 | Electrical Engineering | Four quadrant operation |
| 831 | Electrical Engineering | Advantages of using cycloconverter for synchronous motor speed control |
| 832 | Electrical Engineering | Why a synchronous motor without damper winding is used, in the drive system employing a cycloconverter? |
| 833 | Electrical Engineering | What is constant margin angle control of synchronous motor drive? |
| 834 | Electrical Engineering | What is self-control mode of synchronous motors? |
| 835 | Electrical Engineering | Advantages and disadvantages of short-pitched winding |
| 836 | Electrical Engineering | What is meant by short pitched winding? |
| 837 | Electrical Engineering | What is meant by full pitched winding? |
| 838 | Electrical Engineering | Define coil span |
| 839 | Electrical Engineering | Define Pole Pitch |
| 840 | Electrical Engineering | Types of rotors used in the alternators |
| 841 | Electrical Engineering | What is meant by turbo alternators? |
| 842 | Electrical Engineering | How to minimize the eddy current losses? |
| 843 | Electrical Engineering | Principle of operation of alternators/DC generators |
| 844 | Electrical Engineering | What is meant by stator? What is meant by rotor? |
| 845 | Electrical Engineering | What is form factor and peak factor? |
| 846 | Electrical Engineering | What are different Bus bar materials used in Substation? |
| 847 | Electrical Engineering | Why EHV busbars are hallowed and circular? |
| 848 | Electrical Engineering | What are the different electrical clearances in Substation? |
| 849 | Electrical Engineering | Factors on which material of station busbar depends? |
| 850 | Electrical Engineering | For distribution network which type of Switching scheme is employed? |
| 851 | Electrical Engineering | Which type of bus arrangement is costlier and more reliable? |
| 852 | Electrical Engineering | What are different types of busbar arrangement Schemes in Substations? |
| 853 | Electrical Engineering | What are the different substation components? |
| 854 | Electrical Engineering | What is the neutral point earthing and its advantages? |
| 855 | Electrical Engineering | What is the significance of Corona rings in substations? |
| 856 | Electrical Engineering | What are the disadvantages of corona? |
| 857 | Electrical Engineering | What is Basic Impulse Level (BIL)? |
| 858 | Electrical Engineering | What is creepage distance? |
| 859 | Electrical Engineering | What are different insulators employed in substations? |
| 860 | Electrical Engineering | What is meant by PMDC? |
| 861 | Electrical Engineering | What is Universal Motor? |
| 862 | Electrical Engineering | Why almost all large size Synchronous machines are constructed with rotating field system type? |
| 863 | Electrical Engineering | Power Systems Interview Questions |
| 864 | Electrical Engineering | Power Systems Questions & Answers |
| 865 | Electrical Engineering | Static VAR Compensator (SVC) |
| 866 | Electrical Engineering | What is synchronous condenser? |
| 867 | Electrical Engineering | Give two kinds of capacitors used in shunt compensator? |
| 868 | Electrical Engineering | What are the effects of capacitor in series compensation circuit? |
| 869 | Electrical Engineering | Disadvantage of switched capacitors are employed for compensation |
| 870 | Electrical Engineering | What is known as bank of capacitors? How it is adjusted? |
| 871 | Electrical Engineering | Characteristics of line compensators? |
| 872 | Electrical Engineering | When is feedback stability compensation used? |
| 873 | Electrical Engineering | Give some excitation system amplifier |
| 874 | Electrical Engineering | What are the sources of reactive power? |
| 875 | Electrical Engineering | What are the name plate details of transformer? |
| 876 | Electrical Engineering | What is transformer impedance? |
| 877 | Electrical Engineering | What is transformer regulation? |
| 878 | Electrical Engineering | Advantages of three phase systems |
| 879 | Electrical Engineering | What is single phase transformer? |
| 880 | Electrical Engineering | What is a three phase transformer? |
| 881 | Electrical Engineering | What is the impact if the 60 Hz transformer is operated at 50 Hz transformer? |
| 882 | Electrical Engineering | What happens if the input voltage of the transformer is higher than name plate? |
| 883 | Electrical Engineering | What is the difference between instrument and protection transformer? |
| 884 | Electrical Engineering | What is the difference between isolating and shielding transformer? |
| 885 | Electrical Engineering | What is on-load tap changer? |
| 886 | Electrical Engineering | What is off-loading tap changer? |
| 887 | Electrical Engineering | What is transformer tap changer? |
| 888 | Electrical Engineering | What is isolation transformer? |
| 889 | Electrical Engineering | Advantages of air core transformer |
| 890 | Electrical Engineering | Advantages of iron core transformer |
| 891 | Electrical Engineering | What is current transformer? |
| 892 | Electrical Engineering | What is voltage transformer? |
| 893 | Electrical Engineering | What is step-down transformer? |
| 894 | Electrical Engineering | What is step-up transformer? |
| 895 | Electrical Engineering | Methods of transformer cooling |
| 896 | Electrical Engineering | Why high voltage winding is wounded over low voltage winding? |
| 897 | Electrical Engineering | Why taping is connected to high voltage side? |
| 898 | Electrical Engineering | What is auto transformer? |
| 899 | Electrical Engineering | What is difference between induction motor and transformer? |
| 900 | Electrical Engineering | What is the difference between transformer and amplifier? |
| 901 | Electrical Engineering | What is a transformer core? |
| 902 | Electrical Engineering | What precautions should be observed when applying reduced voltage starting to a load with rising characteristic such as fans? |
| 903 | Electrical Engineering | What are the connections for the Korndorfer system? |
| 904 | Electrical Engineering | What does the simple auto-transformer starter consist of? |
| 905 | Electrical Engineering | What are the connections for a star-delta starter? |
| 906 | Electrical Engineering | When is the star-delta starter used? |
| 907 | Electrical Engineering | When is the primary reactor method of starting employed? |
| 908 | Electrical Engineering | When is primary-resistance starting employed? |
| 909 | Electrical Engineering | What methods are employed to reduce the starting current of squirrel-cage motors? |
| 910 | Electrical Engineering | Advantages of permanent magnet stepper motor |
| 911 | Electrical Engineering | Advantages and disadvantages of VR stepper motor |
| 912 | Electrical Engineering | What is the main application of the micro stepping VR stepper motor? |
| 913 | Electrical Engineering | What is meant by micro stepping in stepper motor? |
| 914 | Electrical Engineering | What is meant by full-step operation in stepper motor? |
| 915 | Electrical Engineering | What is meant by half-step operation in stepper motor? |
| 916 | Electrical Engineering | Different modes of excitation in a stepper motor |
| 917 | Electrical Engineering | Types of stepping motors |
| 918 | Electrical Engineering | Advantages and disadvantages of the stepper motor |
| 919 | Electrical Engineering | Define resolution in stepper motor? |
| 920 | Electrical Engineering | What is slewing in stepper motor? |
| 921 | Electrical Engineering | What is stepper motor? |
| 922 | Electrical Engineering | What is step angle in stepper motor? |
| 923 | Electrical Engineering | What are the main effects of armature reaction? |
| 924 | Electrical Engineering | Define armature reaction |
| 925 | Electrical Engineering | What are the different types of DC generator? |
| 926 | Electrical Engineering | Why the armature poles are made of laminations? |
| 927 | Electrical Engineering | What is the purpose of interpoles in modern dc machine? |
| 928 | Electrical Engineering | What is the purpose of yoke in a dc machine? |
| 929 | Electrical Engineering | What is the basic principle of an electric generator? |
| 930 | Electrical Engineering | Classification of PMSM? |
| 931 | Electrical Engineering | What is a PMSM? |
| 932 | Electrical Engineering | What is brushless DC motor? |
| 933 | Electrical Engineering | What is meant by chopper? |
| 934 | Electrical Engineering | What are modes of operation of electrical drives? |
| 935 | Electrical Engineering | What are the parts of electrical drives? |
| 936 | Electrical Engineering | Different factors for the selection of electrical drives |
| 937 | Electrical Engineering | Advantages of electrical drives |
| 938 | Electrical Engineering | Define electric drives? |
| 939 | Electrical Engineering | Advanced methods of speed control of traction motors |
| 940 | Electrical Engineering | What are the various methods of applying electric traction? |
| 941 | Electrical Engineering | Requirements of a braking system |
| 942 | Electrical Engineering | Methods of traction motor control |
| 943 | Electrical Engineering | Advantages of slip power recovery system |
| 944 | Electrical Engineering | What is slip power? |
| 945 | Electrical Engineering | Advantages and disadvantages of rotor resistance control |
| 946 | Electrical Engineering | What is rotor resistance control? |
| 947 | Electrical Engineering | What is meant by plugging? |
| 948 | Electrical Engineering | What is dynamic braking? |
| 949 | Electrical Engineering | What is regenerative braking? |
| 950 | Electrical Engineering | What is meant by stator current control? |
| 951 | Electrical Engineering | What are the advantages of V/F control? |
| 952 | Electrical Engineering | What is meant by V/F control? |
| 953 | Electrical Engineering | Power System Interview Questions Answers |
| 954 | Electrical Engineering | What is locked rotor current of induction motor? |
| 955 | Electrical Engineering | Why no load test is performed in induction motor? |
| 956 | Electrical Engineering | Why induction motor has high starting torque? |
| 957 | Electrical Engineering | What is the unit of torque? |
| 958 | Electrical Engineering | What is the breakdown torque? |
| 959 | Electrical Engineering | What is the induction motor pull out torque? |
| 960 | Electrical Engineering | What is the starting torque? |
| 961 | Electrical Engineering | What is rated torque of a motor? |
| 962 | Electrical Engineering | What is locked rotor torque? |
| 963 | Electrical Engineering | What is Torque in electrical motors? |
| 964 | Electrical Engineering | What are the benefits of choosing a soft starter? |
| 965 | Electrical Engineering | Why slip ring induction motor has high starting torque? |
| 966 | Electrical Engineering | Why slip is never zero in an induction motor? |
| 967 | Electrical Engineering | What is the meaning of slip frequency? |
| 968 | Electrical Engineering | What is the difference between commutator ring and slip ring? |
| 969 | Electrical Engineering | What is slip in an induction motor? |
| 970 | Electrical Engineering | How does a slip ring commutator work? |
| 971 | Electrical Engineering | How does a slip ring work? |
| 972 | Electrical Engineering | What is a slip ring induction motor? |
| 973 | Electrical Engineering | What motors are in the Scope of the Efficiency Standard? |
| 974 | Electrical Engineering | Why transformer rating in KVA instead of KW? |
| 975 | Electrical Engineering | About the Electrical Engineering category |
| 976 | Digital Electronics | Incremental Encoder Working Principle |
| 977 | Digital Electronics | Absolute Encoder Working Principle |
| 978 | Digital Electronics | Rotary Encoder Working Principle |
| 979 | Digital Electronics | Digital Electronics Question and Answer |
| 980 | Digital Electronics | 8051 Questions |
| 981 | Digital Electronics | Digital Electronics Notes |
| 982 | Digital Electronics | Shift Registers |
| 983 | Digital Electronics | What is radix (or base) of a number system? |
| 984 | Digital Electronics | What is a weighted code and non-weighted code? |
| 985 | Digital Electronics | What is LSB and MSB? |
| 986 | Digital Electronics | What is an BCD code? |
| 987 | Digital Electronics | What is an excess-3 code? |
| 988 | Digital Electronics | Difference between binary code and BCD? |
| 989 | Digital Electronics | Disadvantage of a 8-4-2-1 code |
| 990 | Digital Electronics | Why is an excess-3 code called an unweighted code? |
| 991 | Digital Electronics | Use of excess-3 code |
| 992 | Digital Electronics | Advantages of Gray code |
| 993 | Digital Electronics | What is associate law? |
| 994 | Digital Electronics | Why is a two-input NAND gate called universal gate? |
| 995 | Digital Electronics | Why NAND-NAND realization is preferred over AND-OR realization? |
| 996 | Digital Electronics | What is the specialty of NAND and NOR gates? |
| 997 | Digital Electronics | What are the universal logic gates? |
| 998 | Digital Electronics | What is an inverter gate? |
| 999 | Digital Electronics | What is pulse logic system? |
| 1000 | Digital Electronics | Define positive logic and negative logic |
| 1001 | Digital Electronics | What is a truth table? |
| 1002 | Digital Electronics | What are the basic logic elements? |
| 1003 | Digital Electronics | What is Boolean Algebra? |
| 1004 | Digital Electronics | What is a state table? |
| 1005 | Digital Electronics | What is an excitation table? |
| 1006 | Digital Electronics | What is a latch? |
| 1007 | Digital Electronics | What is a flip-flop? |
| 1008 | Digital Electronics | What is a full-adder? |
| 1009 | Digital Electronics | What is a half-adder? |
| 1010 | Digital Electronics | What is a combinational circuit? |
| 1011 | Digital Electronics | About the Digital Electronics category |
| 1012 | Digital Electronics | 7 Bit Ring Counter’s Initial State Is 0100010. After How Many Clock Cycles Will It Return To The Initial State? |
| 1013 | Digital Electronics | How Do You Detect If Two 8-bit Signals Are Same? |
| 1014 | Digital Electronics | How Can You Convert The Jk Flip-flop To A D Flip-flop? |
| 1015 | Digital Electronics | How Can You Convert An SR Flip-flop To A JK Flip-flop? |
| 1016 | Digital Electronics | What is a Multiplexer? |
| 1017 | Digital Electronics | Differences Between D-latch And D Flip-flop? |
| 1018 | Digital Electronics | What Will Happen If Contents Of Register Are Shifter Left, Right? |
| 1019 | Digital Electronics | Design A Four-input Nand Gate Using Only Two-input Nand Gates |
| 1020 | Digital Electronics | Give Two Ways Of Converting A Two Input Nand Gate To An Inverter? |
| 1021 | Digital Electronics | Applications of Buffer |
| 1022 | Digital Electronics | Difference Between Mealy And Moore State Machine? |
| 1023 | Electronic Devices & Circuits | Issue Observed in data saving in EEPROM of pic16f887 |
| 1024 | Electronic Devices & Circuits | What is a Light sensor? |
| 1025 | Electronic Devices & Circuits | Which sensor to be used to measure luminous lux? |
| 1026 | Electronic Devices & Circuits | How To Read Resistor Colour Codes |
| 1027 | Electronic Devices & Circuits | What is a Photocell? |
| 1028 | Electronic Devices & Circuits | Microphone Working Principle |
| 1029 | Electronic Devices & Circuits | Photodiodes and Phototransistors |
| 1030 | Electronic Devices & Circuits | Types of Potentiometer |
| 1031 | Electronic Devices & Circuits | Permanent Magnet Moving Coil Instrument Working, Advantages and Disadvantages |
| 1032 | Electronic Devices & Circuits | Phototube Principle and Operation |
| 1033 | Electronic Devices & Circuits | What is a Varistor? |
| 1034 | Electronic Devices & Circuits | Zener Diode Construction, Symbol, Principle, Vi Characteristics, Zener Break Down |
| 1035 | Electronic Devices & Circuits | What is a Oscilloscope? |
| 1036 | Electronic Devices & Circuits | How zener diode maintains constant voltage across the load? |
| 1037 | Electronic Devices & Circuits | What is the effect of temperature on extrinsic semiconductor? |
| 1038 | Electronic Devices & Circuits | Explain the term doping and its need |
| 1039 | Electronic Devices & Circuits | Drift current in a semiconductor |
| 1040 | Electronic Devices & Circuits | Diffusion current in a semiconductor |
| 1041 | Electronic Devices & Circuits | What is the forbidden energy gap? |
| 1042 | Electronic Devices & Circuits | Importance of valence shell and valence electrons? |
| 1043 | Electronic Devices & Circuits | What is small signal amplifier? |
| 1044 | Electronic Devices & Circuits | Difference between active and passive filters |
| 1045 | Electronic Devices & Circuits | Why is bleeder resistance employed in a filter circuit? |
| 1046 | Electronic Devices & Circuits | Rectifiers & Filters Interview Questions |
| 1047 | Electronic Devices & Circuits | What is a loop gain in amplifier? |
| 1048 | Electronic Devices & Circuits | Advantages and disadvantages of Negative feedback amplifiers |
| 1049 | Electronic Devices & Circuits | What is negative and positive feedback in amplifiers? |
| 1050 | Electronic Devices & Circuits | What is feedback amplifier? |
| 1051 | Electronic Devices & Circuits | What is miller’s theorem? |
| 1052 | Electronic Devices & Circuits | What is transformer coupling in amplifier? |
| 1053 | Electronic Devices & Circuits | What is capacitive coupling? |
| 1054 | Electronic Devices & Circuits | What is direct coupling in amplifiers? |
| 1055 | Electronic Devices & Circuits | What are the types of coupling used in amplifiers? |
| 1056 | Electronic Devices & Circuits | Why amplifier gains will reduce at higher frequency? |
| 1057 | Electronic Devices & Circuits | What is cascade amplifier? |
| 1058 | Electronic Devices & Circuits | What is Darlington pair? |
| 1059 | Electronic Devices & Circuits | Applications of transistor amplifiers |
| 1060 | Electronic Devices & Circuits | What is a Common collector amplifier? |
| 1061 | Electronic Devices & Circuits | What is a Common emitter amplifier? |
| 1062 | Electronic Devices & Circuits | What is a common Base amplifier? |
| 1063 | Electronic Devices & Circuits | What is a Lissajous pattern? |
| 1064 | Electronic Devices & Circuits | What is sweep time? |
| 1065 | Electronic Devices & Circuits | What is meant by retrace time? |
| 1066 | Electronic Devices & Circuits | What is auadag? |
| 1067 | Electronic Devices & Circuits | What is graticule? |
| 1068 | Electronic Devices & Circuits | What are the essential components of a CRT? |
| 1069 | Electronic Devices & Circuits | How is CRO superior to ordinary measuring instruments? |
| 1070 | Electronic Devices & Circuits | What is a cathode ray oscilloscope (CRO)? |
| 1071 | Electronic Devices & Circuits | What is meant by transistor operating point? |
| 1072 | Electronic Devices & Circuits | What do you understand by collector reverse saturation? |
| 1073 | Electronic Devices & Circuits | Which configuration among CE, CB, CC gives highest input impedance and no voltage gain? |
| 1074 | Electronic Devices & Circuits | Define beta of a transistor |
| 1075 | Electronic Devices & Circuits | How α and β are related to each other in a Transistor? |
| 1076 | Electronic Devices & Circuits | What is Power amplifier? |
| 1077 | Electronic Devices & Circuits | What is a Video amplifier? |
| 1078 | Electronic Devices & Circuits | What is an Audio amplifier? |
| 1079 | Electronic Devices & Circuits | Transconductance, Transresistance, voltage gain, current gain? |
| 1080 | Electronic Devices & Circuits | Types of amplifiers |
| 1081 | Electronic Devices & Circuits | What is tuned amplifier? |
| 1082 | Electronic Devices & Circuits | What is complementary push-pull amplifier? |
| 1083 | Electronic Devices & Circuits | What is push-pull amplifier? |
| 1084 | Electronic Devices & Circuits | What is class A, Class B, Class AB, Class C amplifiers? |
| 1085 | Electronic Devices & Circuits | Types of power amplifier |
| 1086 | Electronic Devices & Circuits | Different types of Transistor feedback topologies? |
| 1087 | Electronic Devices & Circuits | Which diodes will operate in reverse bias? |
| 1088 | Electronic Devices & Circuits | What is continuity equation? |
| 1089 | Electronic Devices & Circuits | Forward and reverse recovery times of diode |
| 1090 | Electronic Devices & Circuits | Why direct band gap semiconductors are used in LED? |
| 1091 | Electronic Devices & Circuits | What are high frequency diodes? |
| 1092 | Electronic Devices & Circuits | What are Reverse break down mechanisms in a diode? |
| 1093 | Electronic Devices & Circuits | What is Reverse Break down (VBD) voltage of a diode? |
| 1094 | Electronic Devices & Circuits | What is a Junction capacitance of a diode? |
| 1095 | Electronic Devices & Circuits | Condition to eliminate thermal run away in BJT |
| 1096 | Electronic Devices & Circuits | Eemitter bypass capacitor an input output blocking capacitors |
| 1097 | Electronic Devices & Circuits | Avalanche multiplication factor in transistor |
| 1098 | Electronic Devices & Circuits | What is punch through in transistor? |
| 1099 | Electronic Devices & Circuits | What is base width modulation or earlier effect? |
| 1100 | Electronic Devices & Circuits | What is thermal resistance of a transistor? |
| 1101 | Electronic Devices & Circuits | Define stability factors of a transistor operated at Q-Point? |
| 1102 | Electronic Devices & Circuits | Transistor fixed bias |
| 1103 | Electronic Devices & Circuits | What is self bias (or) voltage divide bias circuit of transistor? |
| 1104 | Electronic Devices & Circuits | What is Q point? |
| 1105 | Electronic Devices & Circuits | Different regions of operation of transistor? |
| 1106 | Electronic Devices & Circuits | What are α,β and γ in a transistor? |
| 1107 | Electronic Devices & Circuits | What are the types of transistor configurations? |
| 1108 | Electronic Devices & Circuits | Why inverse active mode of transistor is not useful? |
| 1109 | Electronic Devices & Circuits | What is bipolar junction transistor? |
| 1110 | Electronic Devices & Circuits | What is a transistor and types of transistors? |
| 1111 | Electronic Devices & Circuits | Op-amp is used mostly as an integrator than a differentiator. why? |
| 1112 | Electronic Devices & Circuits | What is an integrator |
| 1113 | Electronic Devices & Circuits | What is an adder or summing amplifier? |
| 1114 | Electronic Devices & Circuits | What is a differential amplifier? |
| 1115 | Electronic Devices & Circuits | Applications of an inverting amplifier |
| 1116 | Electronic Devices & Circuits | What is an inverting amplifier? |
| 1117 | Electronic Devices & Circuits | Advantages of voltage follower amplifier |
| 1118 | Electronic Devices & Circuits | What is a voltage follower? |
| 1119 | Electronic Devices & Circuits | What kind of negative feedback is present in a non-inverting op-amp |
| 1120 | Electronic Devices & Circuits | Define slew rate |
| 1121 | Electronic Devices & Circuits | Define offset voltage as applied to an op-amp |
| 1122 | Electronic Devices & Circuits | Why open-loop op-amp configurations are not used in linear applications? |
| 1123 | Electronic Devices & Circuits | Why does an op-amp have high CMRR? |
| 1124 | Electronic Devices & Circuits | Define CMRR |
| 1125 | Electronic Devices & Circuits | What are differential gain and common-mode gain of a differential amplifier? |
| 1126 | Electronic Devices & Circuits | What is a voltage transfer curve of an op-amp? |
| 1127 | Electronic Devices & Circuits | Ideal op-amp |
| 1128 | Electronic Devices & Circuits | What is an operational amplifier? |
| 1129 | Electronic Devices & Circuits | What is impedance diagram |
| 1130 | Electronic Devices & Circuits | What is Instrumentation Amplifier (IA) |
| 1131 | Electronic Devices & Circuits | Different types of feedback |
| 1132 | Electronic Devices & Circuits | What is CDMA, TDMA, FDMA? |
| 1133 | Electronic Devices & Circuits | What is Barkhausen criteria? |
| 1134 | Electronic Devices & Circuits | Advantages of negative feedback over positive feedback |
| 1135 | Electronic Devices & Circuits | What is a feedback? |
| 1136 | Electronic Devices & Circuits | What is op-amp? |
| 1137 | Electronic Devices & Circuits | What is transistor? |
| 1138 | Electronic Devices & Circuits | What is diode? |
| 1139 | Electronic Devices & Circuits | What is a semi conductor? |
| 1140 | Electronic Devices & Circuits | What is conductor? |
| 1141 | Electronic Devices & Circuits | What is inductor? |
| 1142 | Electronic Devices & Circuits | What is resistor? |
| 1143 | Electronic Devices & Circuits | What is crosstalk? |
| 1144 | Electronic Devices & Circuits | What is an Integrated Circuit? |
| 1145 | Electronic Devices & Circuits | What is Oscillator? |
| 1146 | Electronic Devices & Circuits | Example for negative feedback and positive feedback? |
| 1147 | Electronic Devices & Circuits | What is an Amplifier? |
| 1148 | Electronic Devices & Circuits | What is a repeater? |
| 1149 | Electronic Devices & Circuits | Explain AM and FM |
| 1150 | Electronic Devices & Circuits | Modulation techniques |
| 1151 | Electronic Devices & Circuits | What is demodulation? |
| 1152 | Electronic Devices & Circuits | What is modulation? |
| 1153 | Electronic Devices & Circuits | Explain RF? |
| 1154 | Electronic Devices & Circuits | What is stop band? |
| 1155 | Electronic Devices & Circuits | What is pass band? |
| 1156 | Electronic Devices & Circuits | What is cut-off frequency? |
| 1157 | Electronic Devices & Circuits | State sampling theorem |
| 1158 | Electronic Devices & Circuits | What is sampling? |
| 1159 | Electronic Devices & Circuits | Dynamic resistance of a p-n junction diode in forward biased condition |
| 1160 | Electronic Devices & Circuits | What is static resistance of a diode? |
| 1161 | Electronic Devices & Circuits | What is the effect of temperature on the reverse saturation current of a diode? |
| 1162 | Electronic Devices & Circuits | Why is germanium more temperature dependent than silicon? |
| 1163 | Electronic Devices & Circuits | What is reverse saturation current? |
| 1164 | Electronic Devices & Circuits | What is an ideal diode? |
| 1165 | Electronic Devices & Circuits | What does the arrow head represent in the schematic symbol of a p-n junction? |
| 1166 | Electronic Devices & Circuits | Why is silicon preferred over germanium in the manufacture of semiconductor devices? |
| 1167 | Electronic Devices & Circuits | What is a pn junction? |
| 1168 | Electronic Devices & Circuits | Characteristics of ideal Opamp? |
| 1169 | Electronic Devices & Circuits | What Is the use of the Load Line? |
| 1170 | Electronic Devices & Circuits | What does a Q-point of a Transistor Indicate? |
| 1171 | Electronic Devices & Circuits | In An Alternating-current Circuit, What Is The Relationship Between The Impedance Of A Capacitor And The Frequency Of The Current? |
| 1172 | Electronic Devices & Circuits | How Does The Total Capacitance Of Two Capacitors Arranged Together In Series Compare To The Individual Capacitances Of Each? |
| 1173 | Electronic Devices & Circuits | In An Alternating-current Circuit, What Is The Relationship Between The Impedance Of An Inductor And The Frequency Of The Current? |
| 1174 | Electronic Devices & Circuits | What Is Breakdown Voltage? |
| 1175 | Electronic Devices & Circuits | How Is The Charge Stored In A Capacitor Related To The Voltage Applied To The Capacitor? |
| 1176 | Electronic Devices & Circuits | How Does The Total Capacitance Of Two Capacitors Arranged Together In Parallel Compare To The Individual Capacitances Of Each? |
| 1177 | Electronic Devices & Circuits | When A Series Rlc Circuit Is Driven At Resonance, How Does The Impedance Of The Circuit Compare To The Resistance In The Circuit? |
| 1178 | Electronic Devices & Circuits | Which Components Form A Darlington Pair? |
| 1179 | Electronic Devices & Circuits | What Does Mosfet Stand For? |
| 1180 | Electronic Devices & Circuits | Under What Physical Conditions Is Magnetic Energy Stored In An Inductor? |
| 1181 | Electronic Devices & Circuits | In What Form Is The Energy Stored In A Charged Capacitor? |
| 1182 | Electronic Devices & Circuits | In A Series Circuit Consisting Of A Battery And Two Identical Resistors, How Do The Currents Through The Two Resistors Compare? |
| 1183 | Electronic Devices & Circuits | In A Circuit Consisting Of A Battery In Parallel With Two Identical Parallel Resistors, How Do The Currents Through The Two Resistors Compare? |
| 1184 | Electronic Devices & Circuits | What Is Bias? |
| 1185 | Electronic Devices & Circuits | Define Diffusion Capacitance? |
| 1186 | Electronic Devices & Circuits | Define Power Rating? |
| 1187 | Electronic Devices & Circuits | Define Transition Capacitance? |
| 1188 | Electronic Devices & Circuits | Define Forward Resistance? |
| 1189 | Electronic Devices & Circuits | Define Reverse Resistance? |
| 1190 | Electronic Devices & Circuits | Define Reverse Biasing? |
| 1191 | Electronic Devices & Circuits | Define Forward Biasing? |
| 1192 | Electronic Devices & Circuits | Define P-n Junction? |
| 1193 | Electronic Devices & Circuits | Explain Forbidden Energy Gap? |
| 1194 | Electronic Devices & Circuits | Define Conduction Band? |
| 1195 | Electronic Devices & Circuits | Define Valence Band? |
| 1196 | Electronic Devices & Circuits | Define Extrinsic Semiconductor? |
| 1197 | Electronic Devices & Circuits | Define Intrinsic Semiconductor? |
| 1198 | Electronic Devices & Circuits | Define Doping? |
| 1199 | Electronic Devices & Circuits | What Are Free Electrons? |
| 1200 | Electronic Devices & Circuits | Define Energy Band Diagram? |
| 1201 | Electronic Devices & Circuits | Define Insulator? |
| 1202 | Electronic Devices & Circuits | Define Conductor? |
| 1203 | Electronic Devices & Circuits | Define Semiconductor? |
| 1204 | Electronic Devices & Circuits | Define Electronics? |
| 1205 | Electronic Devices & Circuits | Electronic Symbols |
| 1206 | Electronic Devices & Circuits | About the Electronic Devices & Circuits category |
