Reading: The Z-Transfer Function
Inst Tools > Blog > Multiple Choice Questions > The Z-Transfer Function
7 Min Read
1. Consider the following statements regarding a linear discrete-time system:
H (z) = z2+1/(z+0.5)(z-0.5)
1. The system is stable
2. The initial value of h(0) of the impulse response is -4
3. The steady-state output is zero for a sinusoidal discrete time input of frequency equal to one-fourth the sampling frequency
Which of these statements are correct?
a) 1,2 and 3
b) 1 and 2
c) 1 and 3
d) 2 and 3
Answer: c
Explanation: Characteristic equation is (z+0.5) (z-0.5) =0
Its root are z =0.5, -0.5
Since both roots are inside the unit circle, hence the system is stable.
2. The minimum number of delay elements required realizing a digital filter with transfer function H (z) =
a) 2
b) 3
c) 4
d) 5
Answer: b
Explanation: H (z) =
Minimum number of delay elements= (Maximum power of z-minimum power of z)
Minimum number of delay elements = 3.
3. A system can be represented in the form of state equations as:
S (n+1) =A S (n) +B x (n)
Y (n) = C S (n) +D x (n)
Where, A, B, C, D are the matrices , S(n) is the state vector , x(n) is the input and y(n) is the output . The transfer function of the system.
H (z) =Y (z)/X (z) is given by:
a) A(ZI – B)-1 C + D
b) B(ZI – C)-1 D + A
c) C(ZI – A)-1 B + D
d) D(ZI – A)-1 C + B
Answer: c
Explanation: Solving both the equations and substituting the value of the output equation into the state equation we get the value of the transfer function as obtained.
4. Assertion (A): The signals anu(n) and anu(-n-1) have the same Z transform, z/(z-a)
Reason (R): the region of convergence of anu(n) is |z|>|a|, whereas the ROC for anu(-n-1) is |z|<|a|.
a) Both A and R are true and R is correct explanation of A
b) Both A and R are true but R is not correct explanation of A
c) A is true but R is false
d) A is false but R is true
Answer: d
Explanation: Both have the ROC as given in the reason is true but the z transform for the second is with a minus sign.
5. What is the number of roots of the polynomial F(z) = 4z3-8z2-z+2, lying outside the unit circle?
a) 0
b) 1
c) 2
d) 3
Answer: b
Explanation: Factorizing F (z) and then the factors are the roots which here come out to be 3.
6. Assertion (A): The discrete time system described by y[n] =2x[n] +4x[n-1] is unstable
Reason (R): It has an impulse response with a finite number of non-zero samples
Answer: d
Explanation: For the system to be stable the value of the transfer function in the discrete time domain must be summable and H[n] calculated is summable hence the system is stable.
7. What is the z-transform of the signal x[n] = anu(n)?
a) X(z) =1/z-1
b) X(z) = 1/1-z
c) X(z) = z/z-a
d) X(z) = 1/z-a
Answer: c
Explanation: By definition this is the basic example of the z-transform and the Z-Transform of the equation is calculated is z/z-a.
8. Which one of the following rules determine the mapping of s-plane to z-plane?
a) Right side of the s-plane maps into outside of the unit circle in z-plane
b) Left half of s-plane maps into inside of the unit circle
c) Imaginary axis in s-plane maps into the circumference of the unit circle
d) All of the mentioned
Answer: d
Explanation: S- plane can be mapped into the z plane with certain rules than right side maps into the outside, left side maps into the inside and imaginary axis maps on the unit circle of the z plane.
9. Assertion (A): The z-transform of the output of the sampler is given by the series.
Reason (R): The relationship is the result of the application of z = e-sT, where T stands for the time gap between the samples.
Answer: c
Explanation: T is termed as the time of the sampling instant and z transform is always defined for the instant of the sampling event and this can be as desired by the user.
10. Convolution of two sequences X1[n] and X2[n] are represented by:
a) X1(z)*X2(z)
b) X1(z)X2(z)
c) X1(z)+X2(z)
d) X1(z)/X2(z)
Answer: a
Explanation: Convolution of the two sequences is the combination of multiplication and addition of the two sequences at each instant and convolution in time domain is multiplication in the frequency domain.
Difference Equations
Relative Stability Analysis
Top 100 Power Plant Engineering Objective Questions & Answers
Solution of State Equations
Gamma Camera Questions & Answers
Instrumentation of ESR Spectrometer
Ionization of Gases Questions and Answers
Performance Indices
Output Regulator & the Tracking Problem
Closed-Loop Frequency Response
Logic Families Questions and Answers
Feedback Control Questions & Answers
Feedback Control Loop Questions & Answers
Stability in Frequency Domain
Tuning of PID Controllers
Time Response Analysis
Robotic Control System – Part I
Realization of Basic Compensators
Nonlinear Control Systems
Control Valves Multiple Choice Questions
Pumps Quiz
Pumps Quiz
Digital Control Systems Multiple Choice Questions
Advantages of Industrial Automation
Advantages and Disadvantages of Industrial Automation
Factors for Setting Alarm Levels on Toxic Gas Detectors
Electric Drives and Traction Objective Questions and Answers
Electric Traction Objective Questions and Answers
Bagging Machine Controller
Bagging Machine Controller – Principle, Operation Sequence
The inverse z-transform & Response of Linear Discrete Systems
How to Test a Motor using Megger
How to Test a Motor using Megger?
Which Tube has most Hydrostatic Pressure
Which Tube has most Hydrostatic Pressure?
Feedforward control with feedback trim
Feedforward Control Principle
