Reading: What is Synchroscope ?
Inst Tools > Blog > Electrical Theory > What is Synchroscope ?
Last updated: August 13, 2018 1:11 pm
Electrical Theory
2 Min Read
A synchroscope indicates when two AC generators are in the correct phase relation for connecting in parallel and shows whether the incoming generator is running faster or slower than the on-line generator.
The synchroscope consists of a two-phase stator. The two stator windings are at right angles to one another, and by means of a phase-splitting network, the current in one phase leads the current of the other phase by 90°, thereby generating a rotating magnetic field. The stator windings are connected to the incoming generator, and a polarizing coil is connected to the running generator.
The rotating element is unrestrained and is free to rotate through 360°. It consists of two iron vanes mounted in opposite directions on a shaft, one at the top and one at the bottom, and magnetized by the polarizing coil.
If the frequencies of the incoming and running generators are different, the synchroscope will rotate at a speed corresponding to the difference. It is designed so that if incoming frequency is higher than running frequency, it will rotate in the clockwise direction; if incoming frequency is less than running frequency, it will rotate in the counterclockwise direction. When the synchroscope indicates 0° phase difference, the pointer is at the “12 o’clock” position and the two AC generators are in phase.
3-Wire, Three-Phase Delta Wiring System
Transformer Voltage Ratio
Transformer Impedance Ratio
Parallel Circuit Current Calculations
Low Voltage Protection (LVP) and Low Voltage Release (LVR)
Series Open Circuit Faults
AC Generator Voltage Regulators
Series and Parallel Inductors
4-Wire, Three-Phase Delta Wiring System
Rectifiers, Forward Bias and Reverse Bias
Series-Wound Motor
Unbalanced 3 Phase Loads
Applying Kirchhoff’s Voltage Law
Power Triangle
Power Triangle
Battery Hazard
Battery Hazards
Basic AC Generator
AC Generator Parts
Lead Acid Battery charge
Discharge and Charging of Lead-Acid Battery
Voltage Drop in a Series Circuit
Series Resistance
Center Tap Full-Wave Rectifier
Full-Wave Rectifier Circuit
Capacitor Principle
Capacitor
Total Resistance in a Parallel Circuit
Resistance in Parallel Circuits
Questions on Pneumatic Control Loop
Digital Electronics MCQ
Digital Integrated Circuits Objective Questions – Part 1
Difference-between-pneumatic-electric-hydraulic-actuators
Difference between Pneumatic, Electrical & Hydraulic Actuators
Difference between Charge and Mass
Two Wire Sensors Animation
Two Wire Sensor Working Principle and Animation
Instrumentation Abbreviations
surface-mounted water pump
Surface-mounted Water Pump
Valve Safety Factor
Valve Safety Factor
