Reading: What is insulation? How to Choose the Insulation Material?
Inst Tools > Blog > Electrical Basics > What is insulation? How to Choose the Insulation Material?
Insulation is a material used to restrict the transfer of heat and electricity from one area to another. Learn how to choose the materials.
Last updated: January 23, 2024 2:28 pm
Electrical Basics
6 Min Read
Whenever you use an electrical wire, you must have thought why you do not get an electrical shock on touching it, if it is live. This is because an insulator material is used to cover the conductor wire and does not expose it to the external environment.
What is insulation?How to Choose the Right Insulation?Approving bodyOperating VoltageAmbient temperatureDurabilityMaterials used for Wire InsulationPlasticRubberFluoropolymer
The insulation is thus used to protect the persons as well as the nearby environment from electric shocks and also protect the conductor from any external noise. So, it is necessary for an engineer who designs an electrical wire to understand the concept of insulation properly. In this post, we will see the outcome of wire Insulation.
What is insulation?
Electrical atoms have two properties – conduction and insulation. The ones that allow electricity to pass are called conductors and the ones that block electricity flow through it are called insulators. They don’t pass electrical current and if ever you want to pass current through it, then you will require a very high voltage to make it pass. This is called the breakdown voltage.
But, in normal scenarios, this voltage is rarely applied deliberately. So practically, insulators are electrical objects that do not allow electricity to pass through them. In electrical terms, it is also called a dielectric. If the insulation is strong, then the wire too will last long, as it will be less prone to external contacts and environment.
Also, electrical insulation is so strong that they do not allow even leakage current to pass, which thus helps in accidentally getting in contact with nearby wires.
What is insulation
Well, this question is the most asked one by engineers. Because, the whole thing is surrounded by this answer and if we don’t choose the right one, then the wire may get damaged and even nearby personnel will face danger.
Take a look at the below points for considering selection criteria.
Approving body
There are many approvals in the world standards set for choosing the right insulation, like UL (Underwriter Laboratories), CSA (Canadian Standards Association), CE (Conformite Europeenne), SAE (Society of Automotive Engineers) and ISO (International Organization for Standardization).
As you can see by names, these are standards set by different countries or continents as per their work for approving a product and saying that it is safe to use. An insulator with any of these marks is safe to use.
Operating Voltage
As discussed earlier, a breakdown voltage can cause an insulator to conduct. So, the operating voltage of a wire using an insulator must always be less than this voltage.
Ambient temperature
The temperature has an adverse effect on any product. Even in the case of insulators, excess high temperature can affect its quality and working. This is because as per electrical standards, as temperature increases, the resistance decreases. And as insulators are all about resistance, drop in it is of no use.
Durability
Durability defines how the insulation will perform in any rugged condition or environment. Then be it chemical corrosion, environment corrosion, moisture, fire, or high temperatures, the insulator with the highest durability must be chosen for the wires.
Now that we have seen what is insulation and what is the selection criteria for the same, let us have a look at the materials used for insulation making.
Plastic
It is the most widely used material in wire Insulation. This is because it has the highest durability and resistance to the external environment. They increase energy efficiency and contribute a lot to the environment. Also, they have a long lifeline and can be recycled easily.
Some of the common types of plastic insulation are
  • polyvinyl chloride (PVC),
  • Semi-rigid PVC,
  • Plenum PVC,
  • Polyethylene,
  • Polypropylene, and
  • Nylon.
Rubber
Plastics tend to lose their performance at lower temperatures. They tend to lose their durability. For this reason, particularly for this environment, rubber material is used.
Some of the general types of rubber insulation materials are
  • Thermoplastic,
  • Silicone,
  • Ethylene propylene,
  • Polychloroprene, and
  • Fiberglass.
Fluoropolymer
When it comes to chemicals and another acidic environment, this material is the best used as it offers the highest possible durability.
Some of the most widely used materials in this type are
  • polytetrafluoroethylene,
  • ethylene tetrafluoroethylene,
  • polyvinylidene fluoride,
  • perfluoro alkoxy, and
  • fluorinated ethylene propylene.
As the name implies, all these materials are related to chemicals.
If you found this article informative and engaging, we encourage you to consider subscribing to our YouTube Channel, where you can access video tutorials covering topics such as Instrumentation, Electrical, PLC, and SCADA.
For daily updates and to stay connected with our latest content, be sure to follow us on Facebook and Twitter.
To further expand your knowledge, we recommend checking out our next insightful articles.
  • Single Core and Multi-Core Cables
  • Difference Between HV and LV Cables
  • Types of Cables in Industrial Automation
  • Instrumentation Cables Testing Steps
  • Flame Resistant and Retardant Cables
Difference Between Overcurrent and Overload
What is a VFD? – Theory, Advantages, Disadvantages
What is a Ground Rod?
Dahlander Motors – Principle, Advantages, Disadvantages
Circuit Breaker Making Capacity
What is Floating Neutral? – Electrical Engineering Basics
Effects of Long Distance Cables between VFD and Motor
Understanding Protection Relays – 50, 50N, 51, 51N
What is Electrical Conduit? Types, Advantages, Disadvantages
Star Delta Starter – Working, Circuit, Advantages, Disadvantages
Difference between Power Cables and Signal Cables
Difference between AC and DC
Testing and Inspection of Bonding and Grounding Systems
Difference between KW and KVA
IEC 60909 and IEC 61363 for Short Circuit
Top 10 Common Mistakes on Electrical Systems
Constant Torque Load of Electrical Motor
Types of Motor Loads – Constant & Variable Torque, Horsepower
Solid State Relay Working Principle
What is a Solid State Relay? – Working Principle, Types of Control
Electrical Terminal Blocks
How to Protect Electrical Terminal Blocks From Tampering?
Why is White Powder Used in Electrical Cables
Why is White Powder Used in Electrical Cables?
Motor Control On-Delay Timers Circuit
Motor Control Timer Circuit – Automatic Motor START and STOP
Totally Enclosed Fan Cooled (TEFC) Motor
Totally Enclosed Fan Cooled (TEFC) Motors Rampant Winding Burnouts
Programmable Logic Controller (PLC) Questions and Answers – 6
Python in Industrial Automation
Python in Industrial Automation and Control Systems
PLC Best Practices
#1 PLC Best Practices – Split PLC Code into Modules
Power Systems MCQ Series 19
4-20mA Current Loop
Basics of 4-20mA Current Loop
Tuning Fork Level Switch principle
Temperature Balance System Objective Questions
