Reading: What is a Solid State Relay? – Working Principle, Types of Control
Inst Tools > Blog > Electrical Basics > What is a Solid State Relay? – Working Principle, Types of Control
In this article, you will learn about what is a solid state relay (SSR), working principle and types of control methods.
Last updated: September 28, 2022 3:44 pm
Electrical Basics
In this post, we will cover the basic concepts of solid state relay.
What is a Solid State Relay?Solid State Relay Working PrincipleTypes of Control for Solid State RelaysRandom Turn-On of Solid State RelayZero Crossing of Solid State RelayProportional Control of Solid State Relay
One of the most important components used in an electrical panel is a relay. Mostly, people are familiar with standard electromechanical relays.
But, there is another type of relay which is also used widely for a large variety of loads – mainly heavy and resistive types. This is a solid state relay (SSR). In this post, we will understand the basic concept of a solid state relay.
As the name implies, solid state relay (SSR) works on semiconductors. In contrast to an electromechanical relay which uses mechanical contacts to switch on or off a circuit, there are no mechanical contacts inside the solid state relay.
Switching is done swiftly through semiconductors like triac, transistor, diode, and thyristors. The technique works on either infrared light emitting diodes or LED couplers to operate. Due to the use of semiconductors, the switching is very fast as compared to a standard electromechanical relay.
Also, you can get a wide variety of control voltage from SSR, either fixed or variable, due to the use of semiconductors. The solid state relay is mostly used for resistive and heavy loads like heaters and heat tracings, which require a large amount of load current.
Refer to the below figure. As discussed before, solid state relay (SSR) does not have moving parts. They consist of semiconductors and electronic parts.
The input circuit consists of a LED which is triggered by the input voltage. Then, there is isolation between input and output circuits.
The output circuit consists of a photo-coupler for capturing the light and converting it into electrical energy for the load drive circuit (consisting of either triac, diodes, transistors, or thyristors).
When the power supply is applied to the input circuit, current flows through LED which emits light from it. The photo-coupler detects it and converts it into an electrical voltage which is then fed to the load drive circuit, for controlling the final output voltage to the load. When the input voltage turns off, the load too turns off.
Due to the use of Opto-coupling technology, the switching is swift, sensitive, and has high insulation levels. The output voltage can be digital or analog, depending upon the input circuit and load drive circuit used.
There are three types of control methods available for solid state relays (SSR).
They are as follows
  1. Random Turn-On of Solid State Relay
  2. Zero crossing of Solid State Relay
  3. Proportional Control of Solid State Relay
When the input voltage is applied as shown in the figure, the output voltage immediately turns on and is applied for the whole AC cycle as long as the input voltage is on.
As soon as it turns off, the output voltage also turns off.
As shown in the figure below, when the input voltage is applied, the output voltage does not immediately turn on; rather it starts the cycle as soon as it touches the next available zero point in the waveform.
Then, it is applied for the whole AC cycle as long as the input voltage is on. When the input voltage is released, the output voltage does not immediately turn off; rather it stops the cycle as soon as it touches the next available zero point in the waveform.
The earlier two types we discussed were digital output types. As the name implies, proportional control solid state relay provides an analog output.
According to the input voltage given, the output voltage will be given accordingly. This type is used for PID control of heaters and other devices, where accurate control of temperature is required.
In this way, we saw the concept of solid state relay, and it is widely used in many types of loads.
  • Servo Motor Control Drives
  • Industrial Storage Batteries
  • Motor Timer Control Circuit
  • Switched Mode Power Supply
  • Variable Frequency Drive (VFD)
Difference Between NEMA and IEC Motors?
Electrical Motor Jogging Operation
Formula of AMP, KW, KVA, HP for AC and DC Voltages
What is Floating Neutral? – Electrical Engineering Basics
Difference between Servo Motor and DC Motor
NO vs NC Contact
How to Size a Cable for Industrial AC Motors?
Motor STAR – DELTA Starter Working Principle
Electrical Terminology
Bus Riser in Switchgear
What are Ground Fault and Earth Fault?
Basic Electrical Engineering Questions & Answers
Difference Between Circuit Breaker and Fuse
Why is HV Testing important in Electrical Panels?
Top 100 Power Systems Projects
Top 100 Power Systems Projects – Electrical Engineering
Automatic Circuit Recloser
What is Automatic Circuit Recloser? Principle and Types
3 Phase Motor in Star and Delta Connections
How to Connect a 3 Phase Motor in Star and Delta Connections?
Hybrid Solar Power System
What is a Magnetic Field
Difference Between Electric Field and Magnetic Field
Things to Know When Measuring Voltage
Alternating Current
Difference between AC and DC
Smart Transmitter Calibration Tutorial Part 2
PLC Program for Temperature Control using Thermostat
Ambient Air Quality Monitoring System Principle
Evolution of Air Compressors
Manometer with two different liquids
Calculate the Height of Glycerine
Top 100 Switchgear and Protection Interview Questions
Basics of Vibration Measurement
Multiplexers and Demultiplexers Objective Questions
