Reading: Types of Motor Enclosures
Inst Tools > Blog > Electrical Basics > Types of Motor Enclosures
The enclosure is a part of the motor used for the protection from environment. In this article, we discuss seven types of enclosures.
Last updated: October 17, 2023 2:06 pm
R Jagan Mohan Rao
Electrical Basics
3 Min Read
The enclosure is a part of the motor used for the protection of the motor from the environment and persons from being touch.
Motor EnclosuresOpen-protected typeSemi-enclosed type or screen protected typeTotally enclosed typeTotally-enclosed fan-cooled typeDrip-proof typeSplash-proof typePipe-ventilated or duct-ventilated type
A mechanical fan cannot be left open that can harm the personnel in case of accidental touch. That is the reason enclosures are necessary for safety.
Motor Enclosures
There are certain standardized types of motor enclosures.
Open-protected type
The enclosure provides free access to air and also provides sufficient mechanical protection.
This type of enclosure is suitable where there is no unusual exposure to dust particles or dampness.
In order to give additional protection to the motor, metal grids or perforated covers are provided as shown in the figure.
This will prevent particles from being drawn inside which may cause a short circuit or another type of damage to the motor.
In the totally closed type motor enclosure design, there will be no free circulation of air between the inside and outside of the motor.
However, the enclosure is not necessarily “airtight”. A totally closed type motor enclosure is shown in the figure.
This type of enclosure is used in motors installed in mill and factories where there are dust and moisture in the environment.
In a totally-enclosed machine, an efficient method of cooling can be provided by a fan, driven by the motor itself, blowing external air over the cooling surfaces and through the cooling passages.
This type of enclosure is used in a dirty, dusty, and corrosive environment.
Drip-proof type
In this type of enclosure, the openings for ventilation are so provided as to prevent vertically falling water or dirt from entering inside the motor as shown in the figure.
Splash-proof type
With such an enclosure, liquid or solid particles falling on or reaching any part of the machine at any angle between the vertically downward direction and 100 degrees from that direction cannot enter the machine.
In this type of enclosure, there is a continuous supply of fresh ventilating air. The frame I so arranged that ventilating are conveyed to and from the machine through pipes or ducts attached to the enclosing case as shown in the figure.
Reference: Electrical Engineering drawing by Dr.S.K Bhattacharya 2007
  • What is Smart MCC?
  • Electronic Equipment Purging
  • Instrument Heated Enclosure
  • Classified Areas and Electrical Safety
  • Types of Circuit Breakers
Difference Between Flame Resistant and Flame Retardant Cables
Pros and Cons of Soft Starter
Top 10 Common Mistakes on Electrical Systems
One Nation One Grid One Frequency – Electrical Engineering
Safety Tips When Working With Electricity
Types of Motor Loads – Constant & Variable Torque, Horsepower
All About Electric Fence Gates
Motor Forward and Reverse Direction Control using Limit Switches
Industrial Circuit Breakers – Most Common Types – Principle
How does a Lead Acid Battery Work?
Difference Between RCCB and MCCB
Electrical Contactor, Switch, Circuit Breaker
What is an HRC Fuse? – Material, Types, Advantages
Electric Motor Winding Temperature Sensors
Induction Motor Operation
Induction Motor Over and Under Voltage Problems
Armoured cable
What is an Armoured Cable? Classification of Cables
Lithium-ion Battery Charging System
Lithium-ion Battery Charging Systems
Preventive Maintenance of Variable Frequency Drive
Why Three-phase Voltage is 440 Volts
Why Three-phase Voltage is 440 Volts?
Earth Fault
What are Ground Fault and Earth Fault?
SCADA in Power System
Electrical Energy Management System and SCADA in Power System
DC Power Supplies Objective Questions
Linear Programming in Excel
How to Do Linear Programming in Excel?
Electrical & Electronics Measurements Objective Questions – Set 4
Electrical Projects Ideas
Latest Electrical Projects Ideas for Final Year Students
How to export in Vijeo Designer
Vijeo Designer software – Import and Export
Profibus network
How Profibus Communication Works
Remote Factory Acceptance Test
foam fire protection system
Basics of Foam Fire Fighting System
