Reading: Why is the Humming Sound Produced in Transformer?
Inst Tools > Blog > Electrical Basics > Why is the Humming Sound Produced in Transformer?
In this post, we will learn why a humming sound is produced in a transformer because it will help to design the transformer properly.
Last updated: January 27, 2023 7:28 pm
Electrical Basics
Whenever you pass around a transformer, you must have heard a strange sound of humming surrounding it. This is mostly heard in large transformers. This sounds weird but it is true; because everyone wonders why if there is no moving part in it, then why the sound is produced.
Transformer Humming SoundHow to Reduce the Humming Sound in the Transformer?
In this post, we will learn why a humming sound is produced in a transformer because it will then help the engineers to design the transformer properly.
A transformer works on converting voltage either in step-up or step-down mode. It has two basic windings – primary and secondary. The windings are wound on a laminated magnetic core sheet. There are multiple such sheets in a transformer housing.
These cores are multiple in number to reduce Eddy current losses. When current flows through windings, a magnetic field is generated around the cores. It will then flow fully around the cores. This means that the laminated sheets are now turning into a magnet when electric current flows through them.
Now, an AC current pulsates up and down in every cycle. So, suppose at 50 Hz of supply, the magnetic field will change its shape 200 times even in just two cycles (50 up and 50 down). As the magnetic field is flowing through the core, it means that the field will expand and contract 200 times in 2 cycles.
So, you can imagine how the magnet is expanding and contracting such fast. This is not only in a single core sheet; there are multiple such core sheets. If all the cores are behaving in the same way, then the sheets will vibrate in a large way. This rapid vibration causes a humming sound. This concept causes a humming sound in the transformer.
Humming Sound in Transformer
You cannot completely eliminate the noise, but at least you can reduce the humming sound or stay away from it in the following ways:
  1. As the core is vibrating, the very first step will be to hold the core tight. Practically speaking, this can be done by mounting the transformer body on a solid concrete structure that is very heavy than the body weight (at least 10 times).
  2. As the sound is annoying, maintain a safe distance of at least 10 feet from the transformer. Prolonged sound hearing can damage the ears after a certain period of time.
  3. Ensure that the nuts and bolts in the transformer (majorly around the core) are tight and not loosened. This will ensure the parts are properly bonded with each other.
  4. Ensure there are no wall surfaces or other reflective layers around the transformer at some distance, which will help avoid the reflection of sound.
  5. Oil barriers and cushion padding may also help insulate transformer noise and prevent it from spreading.
  6. Install vibration dampeners between the case and coil assembly, which will prevent contact between the mounting surface and unit and help reduce noise reflection.
In this way, we understand how a humming sound is produced in a transformer.
  • Why is IGBT used in VFD?
  • Auto Changeover Switch
  • SCADA in Power System
  • What is a Buchholz Relay?
  • Motor Winding Sensors
Partial Discharge in Power Lines and its Detection through Sensors
Root Cause Analysis – Burst Transformers and 11 kV Input Breakers
Download Electrical Enclosure Book
MCB vs Fuse Questions and Answers
What is an Overhead Cable? Types of Overhead Conductors
How to Read and Understand an Electrical Single Line Diagram?
Basic Electrical Engineering Questions & Answers
Motor STAR – DELTA Starter Working Principle
What is a Solid State Relay? – Working Principle, Types of Control
Variable Frequency Drive (VFD) Working Principle
What is a Semiconductor Fuse?
What is a Power Transformer
What is a Power Transformer? – Components and Types
What is a Current Transformer
What is a Current Transformer?
running two single-phase induction motors sequentially
Control Two Motors in Sequence after Time Delay – Circuit, Operation
What is an Instrument Transformer?
What is an Instrument Transformer? – Types, Principle, Advantages
Ground Rod
What is a Ground Rod?
MCCB (Molded Case Circuit Breaker)
Industrial Circuit Breakers – Most Common Types – Principle
Difference between Stepper Motor and DC Motor
Electrical Conduit Seal
Safety Control System
What is Safety Control System ?
Instrumentation and Control Project Packages
RAID stands for Redundant Array of Independent Disks
DeltaV Tune Tutorial
How to Tune a Loop in DeltaV System
temperature compensation circuit for PMMC
PMMC Temperature Compensation
Instrumentation Design Details
Instrument Air Calculations
Basic Calculations of Instrument Air
Ziegler-Nichols closed-loop Tuning
Ziegler-Nichols Closed-Loop Method (Ultimate Gain)
