Reading: Synchronous Motor Working Principle
Inst Tools > Blog > Electrical Machines > Synchronous Motor Working Principle
Last updated: December 22, 2018 1:25 am
Electrical Machines
A motor is an electro-mechanical device which converts electrical energy to mechanical energy. and a 3 phase motor runs at synchronous speed is called synchronous motor.Synchronous motor mainly runs on principle of magnetic locking between rotor and RMF(Rotating magnetic field).When two unlike poles are brought near each other, if the magnets are strong, there exists a tremendous force of attraction between those two poles. In such condition the two magnets are said to be magnetically locked.
Synchronous Motor Working Principle:-
When 3 phase voltage applied to electric conductors are placed in a certain geometrical positions which are specially arranged (In certain angle from one another) rotating magnetic field produces.this RMF rotates with synchronous speed.The synchronous speed of a stator rotating magnetic field depends on the supply frequency and the number of poles for which stator winding is wound. if the frequency of the a.c. supply is f Hz and stator is wound for P number of poles, then the speed of the rotating magnetic field is synchronous given by,
Ns = 120f/P   rpm.
synchronous motor working principle
How Rotor Rotates at Synchronous Speed?
Now to understand the concept of synchronous motor working,consider a two pole simple rotor(shown in fig).Synchronous motor is a doubly excited machine i.e two electrical inputs are provided to it. It’s stator winding which consists of a 3 phase winding is provided with 3 phase supply and rotor is provided with DC supply.when DC supply given to rotor it acts like a electromagnet.as we know rotating magnetic field rotates with synchronous speed when two opposite poles of rotor and RMF locked rotor also rotates with same speed of RMF in the direction of rotating magnetic field.Hence synchronous motor rotates at one and only one speed i.e. synchronous speed. But this all depends on existence of magnetic locking between stator and rotor poles. Practically it is not possible for stator poles to pull the rotor poles from their stationary position into magnetic locking condition. this is the reason why synchronous motors are not self starting.
Methods of Starting of Synchronous Motor:-
1.Pony motor method:
Synchronous motors are mechanically coupled with another 3 phase induction motor or DC shunt motor. DC excitation to the rotor is not fed initially. It is rotated at speed very close to its synchronous speed and after that DC excitation is given to the rotor. After some time when magnetic locking takes place supply to the external motor is cut off from coupling.
2.Damper winding Method:
In damper winding method synchronous motor is first run as three phase induction motor using damper winding and finally it is synchronized with the RMF.
Application Of Synchronous Motors
1.It is used where high power at constant speed is required.EX: rolling mills, chippers, mixers, pumps, pumps, compressor etc.
2.As synchronous motor is capable of operating under either leading and lagging power factor, it can be used for power factor improvement. A synchronous motor under no-load with leading power factor is connected in power system where static capacitors can not be used.
3.Synchronous motor finds application where operating speed is less (around 500 rpm) and high power is required.
DC Motor Speed Control
Types of Transformers
Advantages and Disadvantages of Slip Ring Induction Motor
Electrical Motor Starter Circuits
Synchronous Generator Salient Pole vs Non Salient Pole
Types of Generators
Advantages and Applications of zigzag transformer
Star to Delta and Delta to Star Conversion Formula
Applications of Synchronous Motors
Why Starting Current of Induction Motor is High
Use of line reactors
Transformer Tap Changing Working Principle
Advantages of Hydrogen cooling in Synchronous Generators
Why Armature is placed on Stator for Synchronous machines
Synchronous Motor Starting Methods
Induction Motor Operating Characteristics
Difference between Induction motor and Synchronous motor
Difference between Permanent Magnet BLDC and DC Motor
Alarm Trip for 24v DC Loop
Advantages & Disadvantages of Synchronous Motors
Importance of Hysteresis Loop
AC Induction Motor Construction
Basics of AC Induction Motors
Metering pumps
Metering Pumps
Add an alarm display to the graphics.
How to Configure an Alarm in InTouch SCADA?
Reasons to Calibrate Flowmeters
Reasons to Calibrate Different Types of Flow Meters
Types of Industrial Storage Batteries
Auto Transformer Schematic
Classification of Transformers
Closed Tank Remote Seal Level Transmitter calculation
Remote Seal Transmitters Ranging Calculation
Resistance firing of an SCR in a half-wave circuit
Thyristor Triggering Circuits – Types, Explanation, Waveforms (SCR)
Ultrasonic Thickness Gauge
How to Use a Paint Thickness Gauge?
Specific-Conductance-Calibration-Procedure
Types of AC Motors and DC Motors
