Reading: Summary of Valve Types Characteristics
Inst Tools > Blog > Control Valves > Summary of Valve Types Characteristics
Last updated: January 25, 2021 3:53 pm
Control Valves
2 Min Read
This article shares the Summary of Valve Types Characteristics includes gate valves, ball valves, butterfly valves, globe valves, diaphragm valves, needle valves, plug valves.
Summary of Valve TypesGlobe Valves:Ball Valves:Butterfly Valves:Gate Valves:Diaphragm valve:Needle Valves:Plug Valves:Non Return Valves:Pressure Relief Valves:
Globe Valves:
  • Suitable for regulating flow
  • Tight shut-off
  • Pressure drop when open
  • Used for high pressure clean fluids
Ball Valves:
  • Not suitable for regulating flow except in some specialized ball valves
  • Tight shut-off
  • Low pressure drop when open
  • Used for gas, liquids or slurries
Butterfly Valves:
  • Not suitable for tight shut-off
  • Used for low line pressure and large pipe line diameters
  • Wide range of service: gas, liquids and slurries
Gate Valves:
  • Not suitable for flow regulation, only suitable for on or off
  • Tight shut-off
Diaphragm valve:
  • Suitable for on/off or narrow range throttling control
  • Tight shut-off
  • Used for corrosive fluids and slurries
Needle Valves:
  • Fine control in small diameter piping
  • Tight shut-off
  • Used for clean fluids that have low flows
  • High pressure drop when open
Plug Valves:
  • Tight shut-off
  • Quick opening
Non Return Valves:
  • Allow flow in one direction only
  • Self closing
  • Not suitable for reciprocating pump discharge
  • Opens at pre-determined pressure level
Articles You May Like :
Basics of Butterfly Valves
Orifice vs Restriction Orifice
Cage-guided Globe Valve
What is Shutdown Valve ?
How Ball Valves Work ?
Deluge Valve Operation
Valve Basics, Sizing, and Actuators Books
Bellows Seal Valve Working Principle
Basics of Gate Valves
Control Valve Testing for Noise Measurement
Difference between Globe Valve and Gate Valve ?
Difference between Butterfly Valves and Ball Valves
What is a Float Control Valve? Types, Advantages, Disadvantages
Difference between RTJ and T&G Flange Facings
Working Principle of Pneumatic Actuators
Dome Valve Working Principle
What is Plug Valve ?
Difference Between Solenoid Valve and Motorized Valve
Safety Relief Valve Quiz: Test Your Knowledge
Identify Valve Parts Quiz with Answers
Locked Open (LO) and Locked Close (LC) Valves
Locked Open (LO) and Locked Closed (LC) Valves
BALL CHECK VALVE THEORY
Types of Check Valves
Control Valve Flow Characteristics
Different Control Valve Flow Characteristics
Facts of Control Valves
Facts About Control Valves
Weir Diaphragm Valve
Diaphragm Valves Construction, Types, Stem & Bonnet Assembly
Electric Motor Actuators
What is Motor Actuator ?
Hydraulic Actuator
Types of Valve Actuators
Siemens PLC Simulator and Plant Simulation Software
Pressure and Level Control Loop
Problem on Pressure and Level Control Loops
Automating Car Parking with Advanced PLC Logic
Selector Control Function in DCS
Selector Control Functions
two-way communication between PLC systems
Transferring Data Across PLC Systems – TSEND_C and TRCV_C
Arc Fault Breaker (AFB) Electrical Problem Solved
Premature Arc Fault Breaker Failures
Purpose of Emergency Shutdown (ESD) System
Mass Flow Calculations of flow measurement
