Reading: Programmable Logic Controllers Multiple Choice Questions
Inst Tools > Blog > Instrumentation MCQ > Programmable Logic Controllers Multiple Choice Questions
Last updated: June 21, 2025 10:09 am
Instrumentation MCQ Multiple Choice Questions
6 Comments
3 Min Read
Question 1
The acronym PLC stands for:
(A) Pressure Load Control
(B) Programmable Logic Controller
(C) Pneumatic Logic Capstan
(D) PID Loop Controller
(E) Pressure Loss Chamber
Answer : B
Question 2
Ladder logic programming consists primarily of:
(A) Virtual relay contacts and coils
(B) Logic gate symbols with connecting lines
(C) Function blocks with connecting lines
(D) Text-based code
(E) Hieroglyphics
Answer : A
Question 3
In a PLC, the scan time refers to the amount of time in which …..
(A) the technician enters the program
(B) timers and counters are indexed by
(C) one “rung” of ladder logic takes to complete
(D) the entire program takes to execute
(E) transmitted data communications must finish
Answer : D
Question 4
Identify the problem in this motor control PLC program:
Motor PLC Program
(A) Coil
(B) Start contact
(C) Seal-in contact
(D) Stop contact
(E) Power source
Answer : C
Question 5
The Boolean representation of this PLC program is:
PLC Boolean Logic
(A) ABC + D
(B) C + (A + B)D
(C) C + D(A + B)
(D) ABC + BD
(E) C(AB + D)
Answer : E
Question 6
The difference between online and offline PLC programming is . . .
(A) whether the PLC is running or stopped
(B) whether the programming PC has internet connectivity
(C) the type of programming cable used
(D) where the edited program resides
(E) the type of programmer used
Answer : D
Question 7
In PLC programming, a retentive function is one that:
(A) Defaults to the “on” state
(B) Comes last in the program
(C) Defaults to the “off” state
(D) Cannot be edited or deleted
(E) Is not reset after a power cycle
Answer : E
Question 8
What is the largest integer number that a PLC counter function can reach if it uses a 16 bit register?
(A) 32,768
(B) 65,535
(C) 65,536
(D) 65,537
(E) 32,767
Answer : B
Question 9
An OR function implemented in ladder logic uses:
(A) Normally-closed contacts in series
(B) Normally-open contacts in series
(C) A single normally-closed contact
(D) Normally-open contacts in parallel
(E) Normally-closed contacts in parallel
Answer : D
Question 10
A good application for a timed interrupt in a PLC program would be:
(A) A communications function block
(B) A PID function block
(C) A math function block
(D) A motor start/stop rung
(E) A “watchdog” timer
Answer : B
Credits : by Tony R. Kuphaldt
Flow and Level Measurement Quiz
Paramagnetic Oxygen Analyzers Questions & Answers
Continuous Wave NMR Spectroscopy Questions & Answers
Online Analyzers Questions & Answers
Inductive Transducers Objective Questions
Frequency Measurement Objective Questions
6 Comments
  • Rathete says:
    June 2, 2020 at 5:10 am
    Question 5 is erroneous,because input B and D should be negated, and thus that correct answer must have B and D with a bar on top,not so?
    • Kareem says:
      March 19, 2023 at 1:01 am
      Answer B is correct
  • K.arunkumar says:
    December 28, 2020 at 10:46 am
    The answer key parten very useful the question paper which then read is better answer
  • Shivam kumar says:
    July 17, 2021 at 1:07 pm
  • Rahul says:
    August 12, 2021 at 11:51 pm
    Here, the solution of Q5 should be C(AB’+D’).
  • Gabriel says:
    November 16, 2023 at 12:27 am
    Thank you very much!
Orifice Plate Questions and Answers
Measurement and Instrumentation Objective Questions – Part 4
Stability of Nonlinear System
Electronic Amplifiers Objective Questions
Electron Spin Resonance
250+ Electronic Measurements and Instrumentation MCQ Questions
Linearizing Effect & Regenerative Feedback MCQ
Frequency Division Multiplexers Objective Questions
Circuit Protection Devices Questions
Circuit Protection Devices Objective Questions and Answers
Total Reflection Spectrometer Questions & Answers
Measurement of Resistance Objective Questions
Time Interval Measurement Objective Questions
Measurement of Current Objective Questions
Controller Components – Part 1 Objective Questions
DC Motors Objective Questions and Answers
175+ DC Motors Objective Questions and Answers
What are Fire Branches?
Top 100 Microcontrollers Project Ideas
Basic Process Control Loop
Introduction to Industrial Instrumentation
Safety in Automation Systems
Sources of Static Grounding and Methods to Control
Wonderware Recipe Manager Plus
What is Recipe Management in SCADA?
Instrumentation Engineering Materials Test
Instrumentation Materials Test
