Reading: 200 Pneumatic and Hydraulic Projects List
Inst Tools > Blog > Projects > 200 Pneumatic and Hydraulic Projects List
200 Pneumatic and Hydraulic projects list based on mechanical engineering topics and ideas for students and engineers.
Last updated: July 12, 2024 11:09 am
Projects
10 Min Read
Get the 200 Pneumatic and Hydraulic projects list based on mechanical engineering topics and ideas for students and engineers.
S.No.Projects
1Automated Pneumatic Powered Guillotine
2Hydraulic Regenerative Braking System
3Pneumatic High-Speed Sheet Cutter
4Hydro-Electric Power Generation System
5Pneumatic Waste Material Transport System
6Hydraulic Patient Hoist with Adjustable Control
7Pneumatic Operated Gear Shifting Mechanism
8Hydraulic Bench Vice with Quick Clamping
9Pneumatic Powered Metal Pick and Place Arm
10Automated Bottle Capping System with Hydraulic Control
11Pneumatic Angular Sheet Metal Bender
12Hydraulic Automotive Lift and Angle System
13Pneumatic Craft Paper Cutter
14Hydrostatic Transmission System
15Pneumatic Operated Conveyor Belt System
16Hydraulic Synchronized Lift for Platform Adjustment
17Pneumatic Bulk Material Handling System
18Hydraulic Operated Bench Press
19Pneumatic Variable Speed Drilling System
20Hydraulic Ram Pump for Rural Water Supply
21Pneumatic Operated Robotic Arm
22Hydraulic Cargo Lift with Safety System
23Pneumatic Sheet Metal Punching Machine
24Hydraulic Wheel Alignment System
25Pneumatic Operated Diaphragm Pump
26Hydraulic Braking System Analysis Simulator
27Pneumatic Operated Table Clamping Device
28Hydraulic Bore Well Rescue Robot
29Pneumatic Rotary Engine Mechanism
30Hydraulic Emergency Steering Assist System
31Pneumatic Automated Valve System
32Hydraulic Powered Floor Crane
33Pneumatic Controlled Temperature Chamber
34Hydraulic Power Generation from Speed Bump
35Pneumatic Elevating Table
36Hydraulic Turbine Efficiency Measurement System
37Pneumatic Dust Removal System
38Hydraulic Forklift with Load Balancer
39Pneumatic Operated Multi-nozzle Sprayer
40Hydraulic Pressurized Glue Gun System
41Pneumatic Horizontal Drilling Machine
42Hydraulic Lift-Gated Transport System
43Pneumatic Car Elevator Design and Build
44Automated Drilling Equipment with Pneumatic Feed
45Printing Device Operated by Pneumatic Systems
46Securing Mechanism with Pneumatic Actuators
47Universal Pneumatic Grinder Construction
48Integrated Hydraulic Jack System for Vehicles
49Electrically Operated Car Jack
50Hydro Pneumatic Lifting Device
51Compaction Device with Pneumatic Operation
52Wall Ascending Robot Powered by Pneumatics
53Pneumatic Sorting and Separation System
54Bar Cutting Device Using Hydro-pneumatic Technology
55Vehicle Safety Bumper with Pneumatic Mechanism
56Hybrid Hydraulic System Fabrication for Four-Wheelers
57Multi-Point Lubricant Dispenser with Automatic Operation
58Pneumatic Trailer with Three-Axis Modern Design
59Intelligent Damping System with Fabrication
60Automated Bumper System for Vehicles with Pneumatic Control
61Construction of 4-Axis Pneumatic JCB
62Wall Articulator Robot with Sensor Control
63Multi-Machine Lubrication with PLC Automation
64Dual-Wheeler Query Control System with Automation
65Pneumatic Mechanism for Paper Cup Folding
66Automated Equipment for Painting Applications
67Vice and Jack System Operated by Pneumatics
68Adaptive Braking System with Hydraulic Control
69Ladle Tilting Mechanism for Foundries Using Pneumatics
70Bar Feeding Mechanism with Automation for Sawing
71Multi-purpose Trailer with Hydraulic Revolution
72Dual-Axis JCB with Pneumatic Operation
73Four-Wheeler’s Electro-Hydraulic Braking System
74Differential Unit with Automatic Locking System
75Suspension-Based Air Production Mechanism
76Automatic Packaging Machine with Pneumatic Control
77Hydraulic Truck for Pallet Movement
78Chapati Production with Pneumatic Automation
79Auto Gear Changer Using Pneumatics
80Reciprocating Machine for Pneumatic Grinding
81Gear Cutting Attachment with Pneumatic Indexing
82Enhanced Hydraulic Brake System with Electronic Assistance
83Ultrasonic-Based Distance Measuring and Braking System
84Pneumatic Bottle Washer with Auto Feed
85Reciprocating Water Pump with Pneumatic Operation
86Machine for Abrasive Jet Processing
87Pneumatic Door Mechanism for Remote-Controlled Vehicles
88Cold Chamber Die Casting with Pneumatic Control
89Hammering Machine with Pneumatic Automation
90Time Reduction in Shaping Machine Using Pneumatics
91Sprocket Manufacturing with Automated Paint Marker
92Welding Robot with Pneumatic Operation
93Hydro Coupling Mechanism Construction
94Spring End Grinder with Pneumatic Power
95Multipurpose Press with Automatic Operation
96Vegetable Slicer with Pneumatic Control
97Punch Die Fabrication with Pneumatic Features
98Pneumatic Lift for Automated Jacking
99Belt Conveyor System Using Pneumatics
100Welding Machine with Pneumatic Assistance
101Testing Equipment for Hydraulic Oil Pumps
102Riveting Machine with Hydraulic Pressure
103Mirror Slicing with Compressed Air Technology
104Hydraulic Ascender for Utility Purposes
105Indication and Braking System for High-Speed Highways
106Remote Control Paint Sprayer
107Gear-Based Quick Lifting Hydraulic Jack
108Pipe Bender with Hydraulic Function
109Conveyor Belt with Remote Operation
110Jack System with Hydraulic Motorization
111Pressure Testing Hydraulic Pump
112Automobile Puller with Hydraulic Operation
113Multipurpose Press with Pneumatic Control
114Pneumatic Ramming with Auto Function
115Material Handler with Pneumatic Four-Axis Control
116Drilling with Pneumatic Feed and Automation
117Sticker Production Machine
118Auto-Feed Vice with Pneumatic Control
119Zip Crane with Motorization
120Cutting Machine Safety System for Accidents
121Metal Forming with Pneumatic Auto Feed
122Shape Crafting with Pneumatic Automation
123Ramming Machine Controlled by SMS
124Material Handling Equipment with Cell Phone Control
125CNC Pneumatic Packing Controller
126Intelligent Braking System with Pneumatic Operation
127Locking System with Pneumatic Intelligence
128Anti-Lock Braking Mechanism
129Riveting with Pneumatic Auto Feed
130Ball Printing with Pneumatic Robotics
131Robotic Hand Model with Conveyor Operation
132Paper Cup Machinery Fabrication
133Automated Placement and Painting Equipment
134Lemon Cutter with Pneumatic Feed
135Accident Prevention for Cutting Machinery
136Two-Wheeler Stand with Pneumatic Automation
137Hydraulic Press with Power Pack
138Injection Molding with Pneumatic Function
139Radial Plunger Pump Fabrication
140Vice with Automated Pneumatic Feeding
141Hand Operated Hydraulic Cylinder Liner Puller
142Jack with Hydraulic Trolley Type
143Lift Enhancement with Hydraulic Power
144Printing Press with Pneumatic Automation
145Bottle Washer with Pneumatic Operation
146Leaf-Cup Maker with Pneumatics
147Ramming with Sensor Operation
148Bending and Bend Removal with Pneumatics
149Punching and Riveting with Pneumatic Automation
150Vice with Hydro-Pneumatic Pressure Boost
151Riveting with Pneumatic Automation
152Vehicle Automation with Electro-Hydraulic System
153Automatic Lubrication System
154Bearing Puller with Pneumatics
155Combined Hydraulic and Disk Brake System
156Electro-Hydraulic Braking System
157Speed Sensing and Automatic Braking for Highways
158Drilling Machine with Pneumatic Indexing
159Punching Machine with Accident Avoidance
160Sensor-Operated Pneumatic Braking
161Bearing Press with Pneumatics
162Hand-Operated Mini Zip Crane
163Multipurpose Machine with Pneumatics
164Slotting Machine with Pneumatic Functionality
165Sheet Cutting with Pneumatic Automation
166Vulcanizing Machine with Pneumatic Operation
167Active Suspension for Two-Wheeler with Pneumatics
168Sheet Cutter with Auto Feed Pneumatic
169Punching Machine with Sensor Feed
170Trainer Kit with Pneumatic and Compressor
171Hydraulic Lift with Enhanced Power
172Vice with Pneumatic Control
173Injection Moulding with Hydraulic Operation
174Bus Bar Bender with Hand Operation
175Crane with Pneumatic Mobile
176Robot with Pneumatic Pick and Place
177Scissor Platform with Hydraulic Control
178Punching Machine with Pneumatic Feed
179Miniature Hydraulic Press
180High-Speed Hacksaw with Pneumatics
181Intelligent Hydraulic Jack
182Cutting and Grinding with Pneumatics
183Screw Driver Machine with Pneumatic Operation
184Four-Wheeler Jack with Automatic Pneumatics
185Sander and Polisher with Pneumatic Control
186Multipurpose Grinder with Pneumatics
187Reversible Drilling Attachment with Pneumatics
188Conveyor Belt with Pneumatic Operation
189Reciprocating Water Pumping with Pneumatics
190Automation System with Electro-Hydraulic
191CNC Pneumatic Punching Machine
192PC-Based Ramming Machine with Pneumatics
193Drilling Machine with CNC
194Inspection Conveyor with Pneumatic Operation
195Conveyor Automation with Pneumatic Operation
196Reverse Braking System for Automatic Vehicles
197Scissor Lifter with Hydraulic Control
198Hacksaw with Pneumatic Reciprocating
199Hydraulic Jack with Intelligent Motorization
200CNC Machine for Pneumatic Operation
  • 100+ Electronics Projects & Ideas
  • 300+ Sensor-Based Projects List
  • Top 100 Home Automation Projects
  • Best 100 Wireless Engineering Projects
  • ESP8266 WiFi Module Projects for Students
ESP8266 WiFi Module Projects for Engineering Students
Top 100 Solar-Based Engineering Projects
Artificial Intelligence Projects List and Ideas for Students
300 Power Electronics Projects – Top Electrical Major Project Titles
CAN based Projects – Controller Area Network Protocol
100 VHDL Projects for Engineering Students
Final Year Engineering Projects for ECE, EEE and EIE Students
GSM Based Projects – Ideas and Topics
Real-time PLC Projects – Industrial Automation
RFID Projects for Engineering Students
ECE Projects – IEEE and IoT Projects List
Top 300 Digital Signal Processing Projects – DSP Project Ideas
314 Mechanical Mini Projects List
Analytical Instrumentation Engineering Projects
Top 100 Analytical Instrumentation Engineering Projects
Mechanical Engineering Design and Fabrication Projects
300+ Mechanical Engineering Design and Fabrication Projects
Top 100 PLC Projects List
Top 100 Robotic Projects for Engineering Students
Digital Image Processing Projects - DIP Project Ideas
600+ Digital Image Processing Projects – DIP Project Ideas
Counters and Timers Projects Using Analog Electronic Devices
Top 100 Counters and Timers Projects Using Analog Electronic Devices
Wireless Projects
100 Wireless Projects – Electrical and Electronics Engineering
Top 100 Electrical Machines Projects for Electrical Engineers
Current to Pressure Converter Principle
Current to Pressure (I/P) Converter Principle
Induction Motor as a Transformer
Direct Lift Diaphragm Normally Open Solenoid Valve
Types of Pilot Operated Diaphragm Solenoid Valve Principle
Tilting Disk Check Valve Principle
What is Tilting Disk Check Valve ?
Half Subtractor and Full Subtractor Objective Questions
RFID Technology in Industrial Automation
Single-Phase Full Wave AC-DC Converter Quiz
Identification of Equipment Standards
