Reading: Oxygen Safety Analyzer
Inst Tools > Blog > Fire & Gas System > Oxygen Safety Analyzer
Last updated: March 13, 2018 4:12 am
Fire & Gas System
2 Min Read
Most living things require oxygen to survive. The oxygen you breathe combines with nutrients from the food you eat to produce energy in a form usable by your body. If you are deprived of oxygen, your body very quickly shuts down, much like a fire dies when starved of oxygen (and for approximately the same reason). Ambient air is approximately 20.9% oxygen by volume, the majority of air (about 78% by volume) being nitrogen.
The oxygen content of air may be reduced by combustion (which combines oxygen with flammable substances to produce carbon dioxide and water vapor) or by displacement by a denser gas (such as propane) in a low-lying area or by any gas in sufficient quantity filling an enclosed area.
A modern oxygen sensor technology for safety applications is the micro fuel cell, generating a measurable electric current in the presence of oxygen by the oxidation of a self-contained fuel source. In many sensors, the fuel is pure lead (Pb), with the resulting chemical reaction producing lead oxide (PbO):
O2 + 2Pb → 2PbO
Fuel cell sensors are relatively rugged, accurate, and self-powering, enabling their use in portable oxygen analyzers. Due to their principle of operation, where an internal fuel is slowly oxidized over time, these sensors have a rather limited life and therefore must be periodically replaced.
An interesting and useful technique for testing the operation of an oxygen safety sensor is to exhale on the sensor, watching for a decrease in oxygen content to 15% or below. This testing technique makes use of the fact that your body extracts oxygen from the air, such that your exhaled breath contains less oxygen than it did when inhaled. Therefore, your own body acts as a crude “calibration gas” source for an oxygen safety analyzer.
Rate Compensated Heat Detectors Working Principle
Importance of Fire & Gas Detection System
What is Gas Leak Detection System ?
Gas Detectors Interview Questions & Answers
Flame Detectors Working Principle
What is Fire Alarm System?
Hydrogen Sulfide Gas Detector Calibration Procedure
Why LEL important in Gas Detection?
Safety Gas Analyzers
Which One is Best – Conventional or Addressable Fire Alarm System?
Deluge Valve Operation
Interview Questions on Gas detection System
Infrared Gas Detectors Working Principle
Objective Questions of Building Fire and Gas Detectors
Catalytic Gas Sensor Working
Catalytic Type Gas Sensor Principle
Purpose of End of Line (EOL) Resistor in Fire & Gas System ?
Why we use End of Line (EOL) Resistor in Fire and Gas System ?
LEL vs Percent By Volume vs Parts Per Million vs Parts per Billion
Portable Gas Detectors Calibration Procedure
ultrasound
Ultrasonic Gas Leak Detectors (UGLD)
Rate of Rise Thermal Detectors Working Principle
Industrial Gas Detection Systems
PLC based Gas Detection System using Ladder Logic Project
Transformer Protection using fire water spray system
Fire Water Spray Systems Principle
Electrical Frequency
One Nation One Grid One Frequency – Electrical Engineering
Top PLC Manufacturers
PLC Brands Software Information
Basics of Thyristor
Basics of Thyristor
Comparison of Venturi and Orifice flow meterComparison of Venturi and Orifice flow meter
Safety Relief Valve Material Selection
Instrumentation Project Documents
List of Instrumentation Project Engineering Documents
In this article, you will learn the configuration of PlantPAx library in factory talk studio of Rockwell Automation.
Configuration of PlantPAx Library in Factory Talk Studio
Thyristor Mounting Objective Questions and Answers
