Reading: Nuclear Plant Sensors and Detectors Quiz
Inst Tools > Blog > Instrumentation MCQ > Nuclear Plant Sensors and Detectors Quiz
Test your knowledge with the 60 quiz questions and answers on the nuclear plant sensors and detectors.
Last updated: November 24, 2020 3:59 pm
Instrumentation MCQ
3 Min Read
Test your knowledge with the 60 quiz questions and answers on the Nuclear Plant Sensors and Detectors.
Image Courtesy: Pixabay
Question 1:
What is the function of the positive electrode in an ion chamber?
A) Release electrons to combine with positive ions.
B) Perform gas quenching to maximize detector sensitivity.
C) Collect the electrons released during gas ionization.
D) Produce ions when exposed to a radiation field.
Question 2:
Which one of the following types of radiation detectors uses a gas volume for radiation detection and will typically produce the weakest output signal if all of the detectors are placed in the same gamma radiation field?
A) Scintillation
B) Geiger-Mueller
C) Ion chamber
D) Proportional counter
Question 3:
Which one of the following contains the pair of radiation detector types that are the most sensitive to low-energy beta and/or gamma radiation?
A) Ion chamber and scintillation
B) Geiger-Mueller and scintillation
C) Ion chamber and proportional
D) Geiger-Mueller and ion chamber
Question 4:
Which one of the following types of radiation is the major contributor to the dose indication on a self-reading pocket dosimeter (SRPD)?
A) Gamma
B) Neutron
C) Beta
D) Alpha
Question 5:
Which one of the following types of radiation detectors is typically the least accurate in determining the dose rate to a human body from an unspecified source of radiation?
A) Geiger-Mueller
B) Scintillation
C) Ion chamber
Question 6:
A fission chamber neutron monitoring instrument is operating in the proportional region.
If a complete loss of fission chamber gas pressure occurs, the instrument indication will fail
A) downscale.
B) as is.
C) to midscale.
D) upscale.
Question 7:
Scintillation detectors convert radiation energy into light by a process known as
A) space charge effect.
B) luminescence.
C) gas amplification.
D) photoionization.
All questions and answers are available in the Quiz.
Instrumentation Quiz
Next Quizzes:
  • PLC Quiz
  • Valve Quiz
  • Pump Quiz
  • Process Control
Flow Measurement Objective Questions
Valve Quiz
100+ Questions and Answers on Industrial Automation and Control
Proportional Integral Derivative Controllers – PID MCQ
Electrical Networks Objective Questions
Level Sensors MCQ – Industrial Instrumentation
Quiz: Identifying I/O Examples in PLC Systems
Fibre Optic Sensors Objective Questions
Transducers Objective Questions
GATE Instrumentation Questions and Answers
Performance of Control Systems Objective Questions
Bio Sensors Objective Questions
Self Balancing Potentiometer Objective Questions
Control Valves Multiple Choice Questions
Measuring Instruments MCQ
Measurements & Instrumentation Quiz – Set 5
DC Power Supplies Objective Questions
Level Measurement Objective Questions
Level and Density Measurement Objective Questions
Chemical Sensors Objective Questions
Flanged Rotameter
Flanged Rotameter Caused Pipe Weld Cracks and Gives Wrong Readings
Methods of Transistor Biasing
X-Ray Fluorescence Spectrometry Questions and Answers
Simple Three Digital Electronic Project Ideas
UV Visible Spectrometers Questions and Answers
Encode and Decode Instructions
How to Use Encode and Decode Instructions in PLC ?
Electronic Devices & Circuits Quiz – Set 2
Calculate Power in Parallel RC Circuit
