Reading: Moving Coil Type Velocity Transducer
Inst Tools > Blog > Common > Moving Coil Type Velocity Transducer
Last updated: March 31, 2018 5:58 am
Common
1 Min Read
Principle of Moving coil Type Velocity Transducer
  1. A coil moves in a magnetic field according to the velocity applied.
  2. The voltage in the coil becomes a measure of the velocity when calibrated.
Description of Moving coil Type Velocity Transducer
  1. The instrument has permanent pole pieces which generate the magnetic field.
  2. There is a pivoted arm on which a coil is mounted.
  3. There is a mass attached to the end of the coil.
  4. The whole device is contained in an antimagnetic case.
Operation of Moving coil Type Velocity Transducer
  1. The velocity to be measured is applied to the arm.
  2. Due to this coil moves in the magnetic field.
  3. A voltage is generated on account of motion of the coil in the magnetic field.
  4. The output voltage is proportional to the velocity.
Advantages of Moving coil Type Velocity Transducer
  1. The antimagnetic case reduces the effects of stray magnetic field.
  2. Damping is obtained electrically.
  3. There is high stability under varying temperature conditions.
Applications of Moving coil Type Velocity Transducer
These transducers are used for measuring velocities in linear, sinusoidal or random manner.
How to Achieve Sustainability in UX Design and Make a Difference?
Automation in Farming & Agriculture
How to Use a Paint Thickness Gauge?
Difference between HVAC Absorption Chillers and Electric Chillers
Imbibition Water Flow Control System – Sugar Factory
Job and Career Opportunities in Instrumentation Engineering
Electro-Pneumatic Circuit Using Pressure Sensor and Timer Relay
Difference Between Resistive Touch and Capacitive Touch
Awesome YouTube Channels About Tech and Engineering
What is an Instrument Skid? – Example of Metering Skid
Why is CO2 the Most Promising Refrigerant in Cooling Industry?
Types of Sensors used in the Dairy Industry
Intrinsic Safety of Instruments
Brix Measurement
Measurement of POL, pH, and BRIX in the Sugar Industry
water treatment station
What is a Vent Filter? – Water Treatment Plant
Laser Doppler anemometer
Laser Doppler Anemometer
Ultrapure Water in the Semiconductor Industry
Optical Line Terminal
What is an Optical Line Terminal? – OLT Working Principle
What is a Process Alarm
What is a Process Alarm? Types of Alarms
Homebrew CNC Machine
Embarking on a Homebrew CNC Project: A Journey of Creativity
Difference Between Process and Project
Contact-Type-GWR-Level-Transmitter-Working-Animation
Probe Type GWR Level Transmitter Working Animation
Pressure gauge is subjected to five different pressures
How a Bourdon Tube Pressure Gauge might be Adjusted for Linearity?
Feedforward with Dynamic Compensation - 3
Feedforward Control with Dynamic Compensation
Control of Lube Oil Pressure and Flow
Lubrication Control System – Turbo Alternator
What are HP and LP Switches in HVAC
DC Circuit Node Equations
DC Circuit Analysis Node Equations
circuit-breaker-working-principle-animation
Circuit Breaker Working Principle Animation
Faceplates
What are Faceplates? How to Create a Faceplate? HMI Visualization
