Reading: MCB Nameplate Questions and Answers
Inst Tools > Blog > Electrical MCQ > MCB Nameplate Questions and Answers
Update your understanding of MCB nameplate details with expert questions and answers perfect for exam prep and electrical studies.
Last updated: August 31, 2024 8:08 pm
Electrical MCQ
9 Min Read
MCB Nameplate QuestionsWhat is the Rated Current of the MCB?What is the Rated Voltage of the MCB?What is the Breaking Capacity of the MCB?What is the Tripping Characteristic (Type B, C, D, etc.) of the MCB?What is the Number of Poles in the MCB?What is the Frequency of the MCB?What Standards Compliance does the MCB have (e.g., IEC, ANSI)?What is the Manufacturer’s Name or Logo on the MCB?What is the Product Code or Part Number of the MCB?What Certification Marks does the MCB have (e.g., UL, CE)?What is the Short Circuit Current Rating (SCCR) of the MCB?What is the IP Rating of the MCB?What is the Operating Temperature Range of the MCB?What is the Mounting Type of the MCB?What is the Terminal Capacity of the MCB?What is the Endurance (Mechanical and Electrical) of the MCB?What is the Insulation Voltage of the MCB?What is the Impulse Withstand Voltage of the MCB?What is the Ambient Temperature for the MCB?What is the Derating Information for the MCB?What is the Response Time of the MCB?What is the Power Loss of the MCB?What is the Manufacturing Date or Batch Number of the MCB?What are the Locking Options for the MCB?What is the Indicator Status of the MCB?
Watch the below MCB video to learn more about each question with their explanation.
MCB Nameplate Details - Electrical Interview Questions
Question 1
A. Maximum breaking capacity it can handle
B. Maximum voltage it can handle
C. Maximum current it can handle without tripping
D. Maximum frequency it can handle
Show the Answer
Question 2
A. Maximum voltage it can handle
B. Maximum frequency it can handle
D. Maximum breaking capacity it can handle
Show the Answer
Question 3
A. Maximum operating temperature it can withstand
B. Voltage it carries in normal operation
C. Maximum fault current it can interrupt
D. Current it carries in normal operation
Show the Answer
Question 4
A. Indicates the current rating
B. Indicates the breaking capacity
C. Indicates the time-current characteristics
D. Indicates the voltage rating
Show the Answer
Question 5
A. Indicates the rated current capacity
B. Indicates the tripping speed
C. Indicates the rated voltage capacity
D. Indicates the number of circuits it can protect
Show the Answer
Question 6
A. The maximum current it can carry
B. The maximum voltage it can carry
C. The maximum breaking capacity it can handle
D. The rate of electrical oscillation it supports
Show the Answer
Question 7
A. Current rating compliance
B. International safety and performance standards
C. Voltage rating compliance
D. Frequency rating compliance
Show the Answer
Question 8
B. Indicates the compliance standards
C. Indicates the breaking capacity
D. Indicates the manufacturer identity
Show the Answer
Question 9
A. Identifies the current rating
B. Identifies the frequency rating
C. Identifies the specific model and specifications
D. Identifies the voltage rating
Show the Answer
Question 10
A. Marks indicating compliance with safety standards
B. Marks indicating tripping characteristics
C. Marks indicating voltage rating
D. Marks indicating current rating
Show the Answer
Question 11
A. The maximum frequency it can handle
B. The maximum operating temperature it can withstand
C. The maximum short-circuit current it can safely interrupt
D. The maximum voltage it can handle
Show the Answer
Question 12
A. Indicates the voltage rating
B. Indicates the degree of protection against dust and water
C. Indicates the current rating
D. Indicates the frequency rating
Show the Answer
Question 13
A. The temperature range within which it operates safely
B. The frequency range it can handle
C. The maximum current it can carry
D. The voltage range it can handle
Show the Answer
Question 14
A. Indicates its voltage rating
B. Indicates how it is installed in the panel
C. Indicates its breaking capacity
D. Indicates its current rating
Show the Answer
Question 15
A. Indicates the maximum current it can handle
B. Indicates the tripping characteristic
C. Indicates the maximum voltage it can handle
D. Indicates the wire size it can accommodate
Show the Answer
Question 16
A. Indicates its protection against dust and water
B. Indicates its voltage rating
C. Indicates its current rating
D. Indicates how long it lasts under normal operation
Show the Answer
Question 17
B. Maximum operating temperature
C. Voltage the insulation can withstand
D. Maximum current it can handle
Show the Answer
Question 18
A. Ability to handle high frequencies
B. Ability to withstand transient overvoltages
C. Voltage rating of the MCB
D. Current rating of the MCB
Show the Answer
Question 19
A. Temperature around the MCB during operation
Show the Answer
Question 20
A. Frequency rating adjustments
B. Current rating adjustments
C. Adjustments due to temperature or altitude
D. Voltage rating adjustments
Show the Answer
Question 21
A. Time it takes to handle maximum voltage
B. Time it takes to handle maximum current
C. Time it takes to interrupt the current
D. Time it takes to reset after tripping
Show the Answer
Question 22
A. Frequency loss during operation
B. Energy dissipated during normal operation
C. Current loss during operation
D. Voltage loss during operation
Show the Answer
Question 23
C. Indicates the date of production
D. Indicates the current rating
Show the Answer
Question 24
A. Options for connecting wires to the MCB
B. Options for adjusting the current rating
C. Options for mounting the MCB
D. Options to secure the MCB in the ‘off’ position
Show the Answer
Question 25
A. Shows the voltage rating
B. Shows the breaking capacity
C. Shows whether the MCB is on or off
D. Shows the current rating
Show the Answer
  • Automatic Motor START and STOP
  • Answers on Motors and Generators
  • Motor Control Center Signal Interface
  • Synchronous Motors MCQ Questions
  • Three Phase Induction Motors Questions
Electric Circuits Objective Questions – Set 6
Power Systems MCQ Series 12
100 Quiz Questions on Manual Motor Starters
100+ Quiz on Electrical Circuits and Control
AC Fundamentals Objective Questions and Answers
DC Motors Characteristics Quiz
Power Systems MCQ Series 6
100+ Economics of Power Generation Objective Questions and Answers
Power Systems MCQ Series 14
Electric Circuits Objective Questions – Set 1
Parallel Operation of Single Phase Transformers
Alternators Multiple Choice Questions
Electrostatics Objective Questions and Answers
225+ Electrostatics Objective Questions and Answers
Equivalent Circuit of Transformer
Induction Motor Rotor EMF, Current and Power
Illumination Objective Questions
Electric Circuits Objective Questions – Set 18
Electric Circuits Objective Questions – Set 15
Heating and Welding Objective Questions
Power Systems MCQ Series 22
Flip Flop Circuits Objective Questions
Power Supply Voltage Regulator Problem
Troubleshooting a Power Supply Circuit
Elevator Control
Purpose of Instrument Loop Diagrams
Purpose of Loop Diagrams
How are Data Centers Cooled
How are Data Centers Cooled?
what is calibration
Important Terms in Calibration
Vacuum Tubes Multiple Choice Questions and Answers
Design Engineering of Process Plant Project
