Reading: LIFO Instruction in PLC
Inst Tools > Blog > PLC Tutorials > LIFO Instruction in PLC
LIFO instruction used in the PLC programming applications that require to store the sequence of data in order and unload it.
Last updated: March 4, 2021 11:18 am
6 Min Read
LIFO is a special programming instruction that can be used in the applications that require to store the sequence of data in order and unload it.
Now we are gonna see how are loading and unloading done in LIFO.
LIFO Instruction in Allen Bradley PLC Programming
Yes! LIFO should be used in a pair. There should be an instruction to load and there should be an instruction to unload.
The following are the block parameters in LIFO load instruction,
Source: Here is where one should give an address where the values to be loaded are present.
LIFO: Here is where one should specify the address where the values have to be loaded. This address seems weird right with an ‘#’ in the front. When we use an ‘#’ symbol in the front, It is called an array of addresses. Obviously there will be a sequence of values present to be loaded arrays are capable of storing many values right? So why we gave ‘#’ in the front should make sense now.
Control: Here is where one should specify the control address. In the Rockwell PLC programming environment, there is a separate address for the control with R6:0 as starting one. So when the LIFO load is done loading the values the R6:0 address gives us a true bit.
Length: Here is where we have to specify the length of the array so that the array of address prepares them for loading the values.
Position: Here is where we have to give the index number of an array from where the loading has to start. I’ll leave it to 0 so the loading starts from the 0th index.
The following are the block parameters in LIFO unload instruction,
LIFO: Here is where one has to give the address where the values to be unloaded are present. So obviously both the load and unload has the same address in here.
Dest: Here is where one has to give the address where the values have to be unloaded.
Control, Length, and Position carry the same explanation from the LIFO load.
Now we’re going to the run time to see how the loading and unloading happens,
PLC loading=
Now we are on the run time and when the input to LFL is made to turn on the value on N7:0 gets loaded to the array address #B3:0. B3:0 is a binary address to view the value as decimal change the radix to decimal.
Refer to the below figure for the first loaded value.
LIFO Instruction
You can also see the number of lengths we specified is 4 and the Binary data file shows us from 0 to 3.
Here is the next loaded value.
LIFO Load and Unload Instructions for Allen Bradley
Since we didn’t change the number in the source the same number will get loaded to the destination address.
You can see that the position is increasing in the LFL and LFU as the value is getting loaded. So the value is getting loaded from left to right the starting position is 0 and the ending is 3.
Also, notice that the value gets loaded for each false to the true transition of the rung. Refer to the below figure.
So now we have completed loading the values now the Position is at 10 and the done bit goes to the true state.
Tutorial on LIFO instruction of Allen- Bradley PLC
You can also notice from the figure that the Done bit is turned on after completely loading the values.
Now we are going to look at the unloading of the data,
LIFO logic in PLC
Now I made the LFU rung true you can notice that the done bit goes OFF again.
Also, notice that the value which got loaded last comes out first. So the expansion of LIFO is called Last in First Out. The one which came last unloads first.
Likewise, whenever the rung makes false to true transition each value unloads in a manner that which came last goes out. So the last value which comes out should be 30.
Last-In First-Out instruction in PLC
You can also notice from the figure that the empty bit goes up when the values on the LIFO address become empty.
An example of a real-time application where LIFO is used might be tracking parts through an assembly line where parts are represented by values that have a part number and assembly code.
Author: Abishek D
  • InTouch SCADA to Excel
  • FIFO Instruction in PLC
  • Advantages of RTO Timer
  • Scaling for Analog Input
  • Configuration of Alarms
How Could FB and FC Make Me Professional PLC Programmer?
Flexible Input Output Modules
Difference Between NO and NC Contacts
SCADA Engineer Job Responsibilities and Skills
What is CODESYS? Why Do You Need to Learn it?
PLC Logic GATE Program
Concept of Interlocking in PLC
Repeat Until Statement in SCL Language
Free Industrial Control System (ICS) Cyber Security Training Course
PLC Memory Organization – Data Files and Program Files
PLC Logic Functions
SCADA Graphics
What is SCADA ? How does SCADA Works ?
Relay Permissive and interlock circuits
PLC control 4 machines with 1 button
CX-Programmer Tutorial: 1 Button To Activate 4 Different Machines
Reset Logic for pump Run Hours
PLC Program to Count Running Hours of any Equipment
What is an instruction list language?
Structured Text vs. Instruction List for PLC Programming
Save to Memory Card
How to Save a PLC Project to a Micro Memory Card?
How to Choose a PLC
How to Choose a PLC for New Project? – Criteria for Selection of PLC
PLC Timer Program
PLC Timer Instructions
Multivibrators Objective Questions
FDA Process Validation
Why You Need FDA Process Validation and How to Do It Right ?
Orifice Plate Sizing
Orifice Sizing Guidelines and Thumb Rules with Flowchart
PID with Practical Example
Two Out of Three Logic
Alarm and Trip Systems
Solve Pressure Control System Problems
Smart Transmitter Calibration Tutorial Part 3
HMI Screen Design for Hazardous Applications
