Reading: Ion Analyzer Questions & Answers
Inst Tools > Blog > Multiple Choice Questions > Ion Analyzer Questions & Answers
1. If a solid or liquid membrane is placed in pure water, the membrane dissolves slightly, producing an equilibrium concentration of the measured ion. This is represented as __________
a) A constant, Eo
b) Activity
c) Blank correction, Cb
d) Concentration of standard solution, Cs
Answer: c
Explanation: If a solid or liquid membrane is placed in pure water, the membrane dissolves slightly, producing an equilibrium concentration of the measured ion. This is represented as blank correction, Cb. This is the constant background for all measurements.
2. During which of the following conditions is the blank correction not necessary?
a) If sample concentration rises in linear response region
b) If sample concentration falls in linear response region
c) If sample concentration rises in non-linear response region
d) If sample concentration falls in non-linear response region
Answer: b
Explanation: The blank correction is not necessary if sample concentration falls in linear response region. This is the constant background for all measurements.
3. During which of the following conditions is the blank correction necessary?
Answer: d
Explanation: The blank correction is necessary if sample concentration falls in non-linear response region. This is the constant background for all measurements.
4. Ion analysers need calibration once in which of the following durations?
a) Every two or three hours
b) Every nine or ten hours
c) Every 24 hours
d) Every 48 hours
Answer: a
Explanation: Ion analysers need calibration every two or three hours. Temperature affects the output.
5. In ion analysers, which of the following serve the dual purpose of controlling the operating current of FET and providing current gain?
a) FET itself does it
b) SCR
c) Op-amp
d) Diode
Answer: c
Explanation: In ion analysers, op-amp serves the dual purpose of controlling the operating current of FET and providing current gain. Two FETs are operated as source followers.
6. The presence of dirt or moisture degrades which of the following?
a) Circuit components
b) High input impedance of buffer amplifier
c) Low input impedance of buffer amplifier
d) Low output impedance of buffer amplifier
Answer: b
Explanation: The presence of dirt or moisture degrades the high input impedance of buffer amplifier. Solder flux may also degrade it.
7. Which of the following is not a type of ground in ion analyser?
a) Chassis and electrostatic ground
b) Digital ground
c) Analog ground
d) Reference ground
Answer: d
Explanation: There is no such point as reference ground. Three types of grounding is provided which are chassis and electrostatic ground, digital ground and analog ground.
8. The timing for microprocessor and for all signals is generated by the CPU clock.
a) True
b) False
Answer: a
Explanation: The timing for microprocessor and for all signals is generated by the CPU clock. A crystal may be present to provide clock signals.
9. Which of the following is the only operator entry required in PC-based ion analysers?
a) Hardware set-up
b) Signal measurement
c) Calibration
d) Sample calculation
Answer: c
Explanation: Calibration is the only operator entry required in PC-based ion analysers. The operator has to enter the concentration of calibration standards.
10. The analog and digital grounds are connected together in ion analysers.
a) True
b) False
Answer: b
Explanation: The analog and digital grounds are not connected together in ion analysers. This is to ensure that the digital signals never flow through the same conductor as analog signals.
MCQ on Measurement and Instrumentation
Instrumentation for Electron Spectroscopy
Frequency Response MCQ
Level and Density Measurement Objective Questions
Gamma Camera Questions & Answers
Inductively Coupled Plasma Mass Spectrometer
Optimal Control Problems – Part 1
Construction of Root Loci
Liquid Chromatograph- Mass Spectrometer
Infrared Spectrometers Questions & Answers
Operation of Chromatography Questions & Answers
Actuators Questions and Answers
Controllability & Observability
Dissolved Oxygen Analyzer Questions and Answers
Permit to Work System Online Test
High Pressure Liquid Chromatography Questions & Answers
Pneumatic Systems Objective Questions
Liapunov’s Stability Analysis
Liapunov’s Stability Criterion – Part II
Time Response Analysis
Time Response of First Order Systems Objective Questions
Continuous Wave NMR Spectroscopy Questions & Answers
Nuclear Magnetic Resonance Spectrometer Questions & Answers
Detection System of Liquid Chromatography Questions & Answers
RTD with Thermowell
Temperature Sensor Accessories
Level Transmitter with Zero Suppression
DP Level Transmitters Compensation Techniques
Gearbox within week Failing Journal Bearing upset Plant Operations
Instrumentation in Industries
Why is Instrumentation used in Industries?
T-Junction Traffic Control System
T-Junction Traffic Control System – PLC Programming
Instrumentation Project Documents
List of Instrumentation Project Engineering Documents
Electronic Devices & Circuits Quiz – Set 5
DTMF Based Project Topics and Ideas
Top 100 DTMF Based Projects, Topics and Ideas
