Reading: Measurement and Instrumentation Objective Questions – Part 5
Inst Tools > Blog > Multiple Choice Questions > Measurement and Instrumentation Objective Questions – Part 5
Last updated: July 16, 2021 3:40 pm
4 Comments
12 Min Read
1. Self generating type transducers are _____ transducers.
a) Active
b) Passive
c) Secondary
d) Inverse
Ans : (a)
2. The transducers that converts the input signal into the output signal, which is a discrete function of time is known as ______ transducer.
a) Active
b) Analog
c) Digital
d) Pulse
Ans : (c)
3. A transducer that converts measurand into the form of pulse is called
a) Active transducer
b) Analog transducer
c) Digital transducer
d) Pulse transducer
Ans : (d)
4. Which of the following is a digital transducer?
a) Strain gauge
b) Encoder
c) Thermistor
d) LVDT
Ans : (b)
5. Strain gauge, LVDT and thermocouple are examples of
a) Active transducers
b) Passive transducers
c) Analog transducers
d) Primary transducers
Ans : (c)
6. An inverse transducer is a device which converts
a) An electrical quantity into a non electrical quantity
b) Electrical quantity into mechanical quantity
c) Electrical energy into thermal energy
d) Electrical energy into light energy
Ans : (a)
7. A strain gauge is a passive transducer and is employed for converting
a) Mechanical displacement into a change of resistance
b) Pressure into a change of resistance
c) Force into a displacement
d) Pressure into displacement
Ans : (a)
8. Resolution of a transducer depends on
a) Material of wire
b) Length of wire
c) Diameter of wire
d) Excitation voltage
Ans : (c)
9. The sensitivity factor of strain gauge is normally of the order of
a) 1 to 1.5
b) 1.5 to 2.0
c) 0.5 to 1.0
d) 5 to 10
Ans : (b)
10. In wire wound strain gauges, the change in resistance is due to
a) Change in diameter of the wire
b) Change in length of the wire
c) Change in both length and diameter
d) Change in resistivity
Ans : (c)
11. Bonded wire strain gauges are
a) Exclusively used for construction of transducers
b) Exclusively used for stress analysis
c) Used for both stress analysis and construction of transducer
d) Pressure measurement
Ans : (c)
12. Certain type of materials generates an electrostatic charge or voltage when mechanical force is applied across them. Such materials are called
a) Piezo-electric
b) Photo-electric
c) Thermo-electric
d) Photo-resistive
Ans : (a)
13. Quartz and Rochelle salt belongs to _______ of piezo-electric materials
a) Natural group
b) Synthetic group
c) Natural or Synthetic group
d) Fiber group
Ans : (a)
14. Which of the following are piezo electric substances?
1. Barium titanate
2. Lead titanate
3. Lead Zirconate
4. Cadmium and sulphate
Choose correct one
a) 1,2 and 4
b) 1,3and4
c) 1,2and 3
d) 2,3and 4
Ans : (c)
15. Piezo-electric transducers are
a) Passive transducers
b) Inverse transducers
c) Digital transducers
d) Pulse transducers
Ans : (b)
16. Piezo – electric transducers work when we apply ________ to it.
a) Mechanical force
b) Vibrations
c) Illuminations
d) Heat
Ans : (a)
17. Piezo electric crystal can produce an emf
a) When external mechanical force is applied to i
b) When radiant energy stimulates the crystal
c) When external magnetic field is applied
d) When the junction of two such crystals are heated
Ans : (a)
18. The draw backs of strain gauges are
S1: Low fatigue life
S2: They are expensive, brittle and sensitive to temperature
S3: Poor linearity
Choose the correct one
a) S1 and S2
b) S2 and S3
c) S1 and S3
d) S1 only
Ans : (b)
19. LVDT windings are wound on
a) Steel sheets
b) Aluminium
c) Ferrite
d) Copper
Ans : (c)
20. The size of air cored transducers in comparison to the iron core parts is
a) Smaller
b) Larger
c) Same
d) Unpredictable
Ans : (b)
21. The principle of operation of LVDT is based on the variation of
a) Self inductance
b) Mutual inductance
c) Reluctance
d) Permanence
Ans : (b)
22. LVDT is an/a _______ transducer
a) Magneto-strict ion
b) Inductive
c) Resistive
d) Eddy current
Ans : (b)
23. Which of the following can be measured with the help of piezo electric crystal?
a) Force
b) Velocity
c) Sound
d) Pressure
Ans : (a)
24. S1: Transducer is a device which converts physical into electrical quantity
S2: Transducer is also called as sensor.
a) S1 is true & S2 is false
b) S2 is true & S1 is false
c) Both S1 & S2 are true
d) Both S1 & S2 are false
Ans (b)
27. In a LVDT, the two secondary voltages
a) Are independent of the core position
b) Vary unequally depending on the core position
c) Vary equally depending on the core position
d) Are always in phase quadrature
Ans : (b)
28. Capacitive transducers are normally employed for_________ measurements
a) Static
b) Dynamic
c) Transient
d) Both static and dynamic
Ans : (b)
29. Match the following
1. EEG A. Diagnostic tool for heart alignment
2. ECG B. Diagnostic tool for brain alignment
3. Sphygmo-manometer C. Instrument used for measuring blood pressure
4. Stethoscope D. instrument used to hear pulse/heart beat
a) 1- B, 2 – A, 3 – C, 4 – D
b) 1 – B, 2 – A, 3 – D, 4 – C
c) 1- C, 2 – A, 3 – B, 4 – D
d) 1 – A, 2 – B, 3 – C, 4 – D
Ans : (a)
30. Pick the correct statement regarding functions of a transducer
S1: Sense the magnitude, change in & / or frequency of same measurand
S2: To provide electrical output that furnishes accurate, quantitative data about the measurand
Ans : (c)
31. The transducers which requires an external power and their output is a measure of some variation such as resistance, inductance, capacitance etc., are called as
b) Primary sensor
c) Passive transducer
d) Self generating transducer
Ans : (c)
32. The principle of operation of variable resistance transducer is
a) Deformation leads to change in resistance
b) Displacement of a contact slider on a resistance
c) Coupling of two coils changes with displacement
d) Movement of magnetic field produces variation in resistance of material
Ans : (b)
33. The application of LVDT is
a) Joint motion
b) Finger movement
c) Limb movement
d) Heart wall motion
Ans : (c)
34. Venturi is associated with
a) Venous blood pressure
b) Digital plethysmography
c) Dialysate flow in artificial kidney
d) Blood flow in heart lung machine
Ans : (d)
35. Pressure transducer for measuring blood pressure is
a) Strain gauge transducer only
b) Strain gauge or capacitive transducer
c) Resistive transducer
d) Fiber optic transducer
Ans : (b)
36. The change in resistance of a metal wire owing to strain is due to
S1: Change in dimension of wire expressed by factor (1-2µ)
S2: Change in resistance ?
Ans : (b)
37. In foil strain gauge the thickness of foil varies from
a) 2.5 micron to 6 micron
b) 25 micron (or) less
c) 25 micron to 60 micron
d) 2.5 micron to 5 micron
Ans : (a)
38. Photo conductive cell consists of a thin film of
a) Quartz
b) Lithium sulphate
c) Barium titanate
d) Selenium
Ans : (d)
39. S1: In multimode fiber optics, intensity modulating schemes can be employed.
S2: Schemes using polarizing techniques need birefringent fiber.
a) S1 is true and S2 is false
b) Both S1 and S2 are true
c) S1 is false and S2 is true
d) Both S1 and S2 are false
ans (b)
40. Test electrode is also known as
a) Indicator electrode
b) Reference electrode
c) Second electrode
d) Primary electrode
Ans : (a)
41. Most commonly used indicator electrode is
a) Calomel electrode
b) Silver electrode
c) Silver – Silver chloride electrode
d) Glass electrode
Ans : (d)
42. _________ is the example of photo emissive cell.
a) LDR
b) Photo diode
c) Photo transistor
d) Photo multiplier
Ans : (a)
43. pH value of venous blood is
a) 7.30
b) 7.40
c) 7.35
d) 7.45
Ans : (c)
44. Silver chloride electrode is used as a reference electrode due to its
a) Large half cell potential
b) Stable half cell potential
c) Stable resting potential
d) Stable action potential
Ans : (b)
45. The capacitance microphone is used for the detection of
a) Heart rate
b) Blood flow
c) Heart sound
d) Foot pressure
Ans : (c)
46. In a graded index fiber, the total reflected light takes a _________
a) Straight line path
b) Parabolic path
c) Elliptical path
d) Circular path
Ans (b)
47. ________ fiber is used in interferometric instruments.
a) Monomode
b) Multimode
c) Birefringent
d) Coated
Ans (a)
48. Fiber optic sensor can be used to sense _________
a) Displacement
b) Power
c) Current
d) Resistance
Ans (a)
49. Photo multiplier consists of
a) 1 Photo emissive cathode & 2 dynodes
b) 2 Photo emissive cathodes & 2 dynodes
c) 2 Photo emissive cathodes & 1 dynode
d) 1 Photo emissive cathode & 1 dynode
Ans : (a)
50. The resistance of LDR ______ when exposed to radiant energy.
a) Remains unaltered
b) Increases
c) Reaches maximum
d) Decreases
Ans : (d)
Observer Systems
Neural Networks
Controllability & Observability
Z-transform Analysis of Sampled-Data Control Systems
Robotic Control System – Part I
4 Comments
  • devid says:
    May 22, 2020 at 10:14 pm
    a) Mechanical force
    b) Vibrations
    c) Illuminations
    d) Heat
    Ans : (d)
    please update your website there are many answer is wrong.
  • Pranav says:
    February 12, 2021 at 3:26 am
    @devid
    Piezo Electric transducers works when we apply mechanical force to it only in my points of view.
  • Lokesh says:
    July 16, 2021 at 9:51 am
    b) Inductive
    c) Resistive
    d) Eddy current
    Ans : d).
    I think correct ans is b)inductive
  • Vivek sawant says:
    July 19, 2021 at 10:36 am
    b) Inductive
    c) Resistive
    d) Eddy current
    Ans : (b)
    I think correct ans is d) Eddy current
Nuclear Power Plant Multiple Choice Questions
Top 100 Control Systems Objective Questions & Answers
Quadrupole Mass Spectrometer
Continuous Wave NMR Spectroscopy Questions & Answers
Logic Families Questions and Answers
Process Pressure Measurement Objective Questions
Flame Emission Photometers Questions & Answers
Infrared Gas Analyzers Questions & Answers
Advances in Control System
Fuzzy Logic Control
Nonlinear Control Systems
Constructing Phase-Trajectories
AC Circuits Multiple Choice Questions
MCQ on Measurement and Instrumentation
Gas Solid Chromatography Questions & Answers
Liapunov’s Stability Analysis
Liapunov’s Stability Criterion – Part I
Components of Mass Spectrometer Questions & Answers
Cybersecurity in PLC
Dual-junction thermocouple circuit
Find Thermocouple Ouput Voltage
4-20mA Transmitter NAMUR Signal Levels
OPC Communication
OPC Solves Automation’s Data Connectivity
Selection of Weighing Balance
Selection of Weighing Balance and Weight for Calibration
Force Commutated Inverters Objective Questions
DCS Alarm and Setpoint
Setpoints and Alarms in Control System
Logic for Always ON and Always OFF bit
Always ON and OFF Bit using Ladder Logic and Statement List
