Reading: Identify Valve Parts Quiz with Answers
Inst Tools > Blog > Control Valves > Identify Valve Parts Quiz with Answers
Identify Valve parts by clicking on the question mark that represents each component, such as the Yoke, Bonnet, or Stem, etc.
Last updated: August 23, 2024 9:17 pm
Control Valves Instrumentation MCQ
Identify Valve parts by clicking on the question mark that represents each component, such as the Yoke, Bonnet, Stem, etc.
Identify Valve PartsWhat is the primary role of packing in a gate valve?The stuffing box in a gate valve is used to house which component?What is the purpose of the flange in a gate valve?What is the function of the yoke in a gate valve?The main function of the body in a gate valve is to?What is the function of the handwheel in a gate valve?What is the role of the stem in a gate valve?What do seat rings in a gate valve ensure?The gasket in a gate valve serves what primary function?The gate (disc) in a gate valve is used to?The grease fitting in a gate valve is primarily used to?The bonnet in a gate valve is primarily used for what purpose?The packing gland in a gate valve is designed to?In a gate valve, the nut primarily functions to?
Your task is to correctly match each part to its location on the valve diagram. These questions are based on an interactive image quiz where participants need to identify and click on different parts of a gate valve based on the provided labels.
Let’s start the quiz by clicking on the below start button.
Start Valve Parts Quiz
The animation below shows the demo of the valve quiz.
Question 1
A. Secure the handwheel
B. Prevent stem leakage
C. Align the gate
D. Guide fluid flow
Show the Answer
Question 2
A. Gate
B. Yoke
C. Packing
D. Bonnet
Show the Answer
Packing
Question 3
A. Seal the bonnet
B. Connect the valve to pipes
C. Direct fluid flow
D. Guide the stem
Show the Answer
Question 4
A. Guides the disc
B. Connects stem to handwheel
C. Secures the valve body
D. Prevents leakage
Show the Answer
Question 5
A. Support external components
B. Support internal components
C. Adjust fluid pressure inside the valve
D. Seal the valve
Show the Answer
Try Drag and Drop Valve Quiz:
Interactive Control Valve Parts Quiz: Drag & Drop Challenge
Question 6
A. Secure the yoke
B. Regulate fluid flow
C. Align the stem
D. Rotate the stem
Show the Answer
Rotate the stem
Question 7
A. Seals the bonnet
B. Moves the gate up and down
C. Holds the valve body
D. Connects to the handwheel
Show the Answer
Question 8
A. Secure the bonnet
B. Hold the disc in place
C. Guide the stem’s movement
D. Prevent leakage when the gate is closed
Show the Answer
Question 9
A. Lubricates the stem
B. Aligns the gate
C. Guides fluid flow
D. Prevents leakage at joints
Show the Answer
Question 10
A. Regulate fluid temperature
B. Connect to the yoke
C. Control fluid flow
D. Seal the bonnet
Show the Answer
Control fluid flow
Question 11
A. Seal the bonnet
B. Lubricate the stem
C. Adjust the handwheel
D. Secure the gate
Show the Answer
Lubricate the stem
Question 12
A. Secures the valve disc
B. Guides the stem
C. Regulates flow
D. Seals the valve body
Show the Answer
Question 13
A. Tighten the stuffing box
B. Lubricate the valve
C. Guide the stem
D. Secure the bonnet
Show the Answer
Question 14
A. Rotate the handwheel
B. Secure the bonnet
C. Fasten components
D. Adjust the gate
Show the Answer
Fasten components
  • Top 100 Valve Interview Questions
  • Control Valve Questions and Answers
  • Safety Relief Valve Questions & Answers
  • Solenoid Valves Questions & Answers
  • Pneumatic Valves Questions & Answers
  • Control Valves Multiple Choice Questions
Control Valve Interview Questions and Answers
100 Test and Electrical Measurement Objective Questions and Answers
Multiple Choice Questions on Sensors & Transducers
Control Valve Testing for Noise Measurement
Thermo Electric Transducers Objective Questions
Mechanical Systems Objective Questions
Speed of Actuators
Photo Electric Transducers Objective Questions
Measurement of Impedance Objective Questions
Analysis Instrumentation Objective Questions
Chemical Sensors Objective Questions
Process Control & Instrumentation Objective Questions – Set 4
Two SOV Connections
Two Solenoid Valves Working Principle
Globe Control Valve Animation
Basics of Globe Valves
Flow Control Valves Interview Questions
solenoid-valves-types-principle-animation
Solenoid Valves Types, Principle & Animation
Cage-guided globe valves
What is Cage-guided Globe Valve ?
Flow Measurement Questions
MCQ on Flow Measurement
Measuring Instruments Questions and Answers
150+ Measuring Instruments Questions and Answers
Application of Feedback Objective Questions
SIS PFD - Safety Instrumented System
SIS PFD – Safety Instrumented System
Variable Air Volume Controller in HVAC
What is Variable Air Volume Controller in HVAC?
Pulse Generation using Timer in Siemens PLC
Full Wave Bridge Rectifier Operation
Sutro weir flow meter principle
Weirs and Flumes Flow Measurement
Instrument Interactive User Experience
Streamlining Field Instrumentation: The Role of Advanced Overlays
Diaphragm
Diaphragms
