Reading: Hydrocarbons Questions & Answers
Inst Tools > Blog > Multiple Choice Questions > Hydrocarbons Questions & Answers
1. Which of the following methods cannot be used for the estimation of hydrocarbons?
a) Mass spectroscopy
b) Chemiluminescence method
c) Ultraviolet absorption
d) Gas chromatography
Answer: b
Explanation: Chemiluminescence method cannot be used for the estimation of hydrocarbons. This is because hydrocarbons do not produce chemiluminescence effect.
2. Which of the following is the most abundant hydrocarbon which is emitted into the atmosphere by biological activity?
a) Ethane
b) Methane
c) Poly Aromatic hydrocarbons
d) Pentane
Answer: b
Explanation: The most abundant hydrocarbon which is emitted into the atmosphere by biological activity is methane. It is also emitted by automobile exhausts, burning of coal, etc.
3. Flame ionization detectors are sensitive to which of the following gases?
a) Carbon dioxide
b) Methane
c) Carbon monoxide
d) Sulphur dioxide
Answer: b
Explanation: Flame ionization detectors are sensitive to methane since, they are sensitive to organic compounds. They are insensitive to non-combustible gases. Hence, they are not sensitive to carbon monoxide, carbon dioxide and sulphur dioxide.
4. How can carbon monoxide be detected using flame ionization detectors while using gas chromatography technique?
a) By converting it into carbon di-oxide
b) By converting it into methane
c) By mixing it with combustible gases
d) It cannot be detected
Answer: b
Explanation: Carbon monoxide cannot be detected directly using flame ionization detectors while using gas chromatography technique. Hence, it is converted into methane and is then detected.
5. Which of the following organic compounds will have the highest intensity of response when introduced in a flame ionization detector?
a) Methane
b) Ethane
c) Propane
d) Butane
Answer: d
Explanation: Butane will have the highest intensity of response when introduced in a flame ionization detector. This is because the intensity of response will be in proportion with the number of carbon atoms in the chain.
6. Propane would give three times the intensity of response as compared to methane.
a) True
b) False
Answer: a
Explanation: Propane would give three times the intensity of response as compared to methane. This is because the intensity of response will be in proportion with the number of carbon atoms in the chain.
7. In flame ionization detectors, which of the following is the range adequate for atmospheric sampling?
a) 0-1 ppm
b) 0-2 ppm
c) 0-20 ppm
d) 0-100 ppm
Answer: c
Explanation: In flame ionization detectors, the range adequate for atmospheric sampling is 0-20ppm. It is useful for detecting organic compounds.
8. Which of the following methods make use of pyrolysis while used for detecting methane?
b) Flame ionization detector
Answer: b
Explanation: Flame ionization detector makes use of pyrolysis while used for detecting methane. It is used to detect organic compounds.
9. In flame ionization detector, the ions collected on the negatively charged grid are amplified at the high impedance amplifier.
a) True
b) False
Answer: b
Explanation: In flame ionization detector, the ions collected on the positively charged grid are amplified at the high impedance amplifier. Its output is given to the chart recorder.
10. Which of the following is not the characteristic of flame ionization detector?
a) Good linearity
b) Narrow range of concentration
c) High sensitivity
d) Fast response
Answer: b
Explanation: Narrow range of concentration is not the characteristic of flame ionization detector. It has a broad range of concentration.
Continuous Wave NMR Spectroscopy Questions & Answers
Assessment of Relative Stability Using Nyquist Criterion
Measurement and Instrumentation Objective Questions – Part 1
Root Locus in Control Systems
Carbon Monoxide Questions & Answers
Design Considerations for Higher Order Systems
Pneumatic Control Mechanisms Objective Questions
Preliminary Considerations of Classical Design
MCQ on Measurement and Instrumentation
The Infinite Time Regulator Problem
Temperature Measurement Multiple Choice Questions
Constructing Phase-Trajectories
Measurement and Instrumentation Objective Questions – Part 2
Steady-state Errors & Error Constants
Programmable Logic Controllers Multiple Choice Questions
Single Beam and Double Beam Instruments
Chromatographic Behaviour of Solutes Questions & Answers
Instrument Calibration Multiple Choice Questions
Magnetic Wind Instruments Questions & Answers
Pumps Quiz
Pumps Quiz
Electrochemical Methods for Oxygen Analysis Questions & Answers
Liquid Tank Filling and Emptying PLC System
Auto and Manual Liquid Tank System: PLC Program Example
Automotive Rail Rapid Transit
Timer STL Programming
Timers using Statement List (STL) PLC Programming
baffle-and-nozzle assembly
Pneumatic Sensing Elements
RDOL starter
What are DOL and RDOL starters? Advantages, Disadvantages
PLC Ladder Logic Example
Instrumentation Documents
Instrument Document Quiz
Formula of 2 Wire RTD, 3 Wire RTD & 4 Wire RTD
