Reading: Different Types of HVAC Applications
Inst Tools > Blog > Common > Different Types of HVAC Applications
HVAC stands for Heating, Ventilation, and Air Conditioning. In this post, we will see the different types of HVAC applications.
Last updated: September 28, 2022 4:14 pm
Common
6 Min Read
HVAC ApplicationsAir Handling Unit (AHU)ChillersVentilationHeat PumpsHumidifiers and Dehumidifiers
HVAC stands for Heating, Ventilation, and Air Conditioning. It is a type of automation system which is used for handling air quality and thermal comfort given to the human environment for survival.
HVAC is based on thermodynamics, fluid mechanics, and heat transfer. Just like different types of automation systems, HVAC is one type of automation system.
HVAC Applications
HVAC is one of the most important parts required when setting a high-rise building, commercial complex, industrial unit, hospital, parking unit, hotels, etc. where air quality and thermal parameters need to be maintained so that the personnel around can live properly.
Traditional HVAC systems worked without PLCs; but nowadays, almost all of them have PLCs installed for better and accurate control.
Basically, there are numerous number of HVAC applications that are used worldwide. We will see some of the most commonly used ones.
AHU stands for Air Handling Unit. It is one of the most commonly used applications of HVAC. It works on refrigeration logic.
AHU is used for providing cool air to the indoor environment. Basically, it takes a higher temperature air as input and converts it to a lower temperature air through a heat transfer mechanism.
Compressor or chilled water supply is used as a cooling medium for heat exchange. AHU’s also control humidity apart from temperature.
High humidity can lead to excessive sweating and low humidity can lead to dry skin. So, humidity also needs to be maintained alongside a proper working environment.
Chillers
Chillers are the same as AHU in working principle. The main difference is that it is used to cool water instead of air.
Chillers are mostly used in large commercial or industrial complexes to provide low-temperature water for their various applications.
A compressor is used as a cooling medium for heat exchange. As water is of larger density and volume as compared to air, the components used are larger in size as compared to the ones used in AHU.
Ventilation
Ventilation is an application of exhausting bad air out of the working environment. The bad components can be moisture, smoke, heat, dust, carbon dioxide, or airborne bacteria and viruses.
It uses various mechanisms to remove exhaust air from the working environment. The fans used are of big size as compared to traditional ones with accurately designed vents for proper removal of bad air into the outer environment.
A simple example is an exhaust fan used in your bathroom or toilet, which is used to remove bad odor from inside into the outer air.
Heat Pumps
For environments where both heating and cooling are required, heat pumps are used.
During heating requirement, they move heat from the cool outdoors into the warm environment; and during cooling requirement, they move heat from your cool requirement into the warm outdoors.
This technology of moving heat rather than generating heat makes it very efficient for use and is also cost-savvy.
Generally, there are three types of heat pumps –
  1. air to air,
  2. water source, and
  3. geothermal (ground).
They just collect heat from the mentioned types of sources outside your environment and concentrate it inside for use.
Heat pumps are a very advanced type of component used in HVAC.
As the name suggests, humidifiers are used to make an environment more humid and dehumidifiers are used to make an environment less humid.
Humidifiers are used in dry air climates, to inject moisture into the air. Humidity control is also an important factor in an HVAC application.
Basically, these are some of the common applications used in HVAC. These components mostly work in a package as they cannot function alone. They work in links to work for a better air environment.
If you look into the basic components used in HVAC, they are – air filter, supply fan, exhaust fan, supply and return ducts, heating and cooling units, condensing units, boilers, etc.
Applications work depending on the requirement and automation makes great use in it as accurate control of analog parameters can be achieved through them.
  • Recommendations to HVAC Engineers
  • Heat Transfer Loops in HVAC System
  • HVAC Water Chillers Principle
  • HVAC Absorption Chillers
List of Cybersecurity Labs
How Technology is Shaping the Future of Education?
Difference Between CNC Machine and VMC Machine
Seismic Displacement Sensing Accelerometer
Top 100 Microcontrollers Project Ideas
  • bhovan singhn rana says:
    August 10, 2023 at 4:28 pm
    Thanks HVAC Team and Organisations
Difference between LVDT and RVDT?
Electrical Switches Principle & Types
Lag time
How Does a Touch Sensor Work?
Basic Components of Effluent Treatment Plant (ETP)
Instrumentation Functional diagrams
HVAC Valves
Understanding the Difference between HOP Test and OTDR
Common Materials used in Instrumentation Cables
Automation in Agriculture
Automation in Farming & Agriculture
Product Packaging Automation
Why Does Product Packaging Matter in Retailing?
Instrument Interactive User Experience
Streamlining Field Instrumentation: The Role of Advanced Overlays
Construction of strain gauge Load cell
Strain Gauge Load Cell
What is a Flange Gasket ?
Single layer PCB
Step-by-Step Guide: How PCBs are Manufactured from Start to Finish
CNC Milling versus CNC Turning
CNC Milling versus CNC Turning – Which is the Best Option?
Loop Diagram
PT Loop Diagram Faults
Stability and Uniformity of Temperature Bath
Ion Analyzers Questions and Answers
Special Designs of Ion Selective Electrodes Questions & Answers
PLC-Complete-Training-Package
Free PLC Training Software Download
Hydraulic Actuators
Working Principle of Hydraulic Actuators
Densitometers Principle
Vibrating Tube Densitometers Working Principle
Flow Transmitter Readings mismatch with DCS
Heat Exchanger Outlet Temperature Control
Heat Exchanger Temperature Control
