Reading: How Does an Infrared Thermometer Work?
Inst Tools > Blog > Temperature Measurement > How Does an Infrared Thermometer Work?
An infrared thermometer is a non-contact type instrument used to measure the temperature and display the readings.
Last updated: September 28, 2022 4:13 pm
In this post, we will see the working of an infrared thermometer
Infrared ThermometerDistance to Spot Ratio (DTS)
Nowadays, apart from hand-held thermometer probes, which needed to be fitted around a human arm or mouth, infrared thermometers are widely used in place of that.
Infrared is one of the types of radiation in the electromagnetic spectrum. Other types of radiation are visible light, radio, ultraviolet, gamma, and X-rays.
Basically, every object in this world has some energy and mass in it. The energy is emitted in the form of heat. This means that atoms are involved in this energy.
The more the movement of these atoms, the more the heat emitted. The heat emitted is in the form of infrared rays. These rays are not visible to human eyes. But, its warmth can be sensed on the skin surface.
An infrared thermometer does this job exactly by capturing the infrared radiation coming from the object. Like a camera has a lens to focus the surrounding light in it, this thermometer has a lens to focus the infrared radiation and transmit it to its internal circuit for detection.
Basically, a spot is focused on the object which then captures all the atomic movement there in the form of infrared heat.
The infrared rays captured are passed from the lens to an IR detector. The role of the detector is to convert thermal energy into electrical energy.
There are normally two types of detectors
  1. Optical and
  2. Thermal.
The conversion time of optical detectors is faster than thermal detectors.
The electrical output is then passed to ADC’s (Analog to Digital Converter) and then to microprocessor circuits to give the final digital reading of the temperature in the display.
An infrared thermometer will display the temperature in a quicker time than a standard thermometer.
In this way, an infrared thermometer captures the infrared heat and converts it into a digital temperature reading.
Now, let us see an important aspect of this device when buying it. It is called DTS (Distance to Spot Ratio).
Consider a simple example of a person standing near a building. Only that part of the building will be visible to him that is in his eyesight. He cannot see the whole building in single eyesight.
But as he moves away from the building, his range of eyesight increases; due to which he can see a more part of the building than he could see earlier. This same principle is called DTS in infrared thermometer.
Infrared Thermometer Operation
As discussed earlier, a focus is captured in the lens from the spot where it is placed. So, imagine a beam of infrared energy coming from the surface to the lens.
Now, as you move the lens away from the object, the spot covered too increases; same as the eyesight example we saw earlier. The larger the spot covered, the larger the amount of energy captured in the lens.
You get a bigger probability of the atoms moving at the surface which makes it easier for the thermometer to give more accurate results.
So, the higher the DTS, the higher the accuracy covered.  Generally, it comes like a ratio of 20:1, 50:1, etc.
For example, 20:1 means when the thermometer is placed at a distance of 20 feet from the object, a spot distance of 1 foot can be covered from the object. As you move closer towards the object, the spot area to decreases.
This is the basic principle of an infrared thermometer. It is more accurate and quick than a standard thermometer.
  • Types of Fire Detectors
  • Resistance Temperature Detectors
  • How RTD Measuring the Temperature
  • Thermal Imaging Temperature Measurement
  • Infrared Gas Analyzers Questions & Answers
Temperature Gauges and Elements : Detailed Specifications
Bi-metal Temperature Sensors
Thermowell Outer Diameter Larger than Nozzle Inside Diameter?
Single Position Calibration of Temperature Bath
Types of Thermocouple Measuring Junction
Why have been limits imposed on the frequency ratio for thermowells?
Why RTD installed after the Orifice Plate ?
Why we use Wheatstone bridge in RTD?
Resistance Temperature Detectors Troubleshooting Tips
Thermowell Problems
Different Types of Thermometers
Thermocouples Sources of Error
Calculate Temperature Transmitter Output
Thermowell Design Guidelines
How to calculate Thermocouple Temperature by measuring the output millivoltage
Three Wire RTD Temperature Compensation
Ambient Temperature Effects on RTD
Effect of Lead Wire Resistance on RTD
Thermocouples
Important Factors for Thermocouple Selection
Temperature Calibration Bath
Temperature Calibration Bath Principle
Four Wire RTD Principle
How a 4 Wire RTD Works ?
RTD Questions & Answers
RTD Questions and Answers
thermocouple voltages
Manually Interpreting Thermocouple Voltages
Optimal Control Systems
The Infinite Time Regulator Problem
Omron PLC programs
Signal Flow Graphs Objective Questions
Instrument Air Calculations
Basic Calculations of Instrument Air
absorption-type optical analyzer
Absorption Type Optical Analyzer
PLC Compressor Control Ladder Logic
250+ Control System MCQ
250+ Control System MCQ Test Questions
DP-Level-Measurement-Calculation-Above-Tapping-Point-Open-Tank
Differential Pressure (DP) Level transmitter Installed Above Tapping Point
