Reading: How 3 Wire RTD Lead Wire Resistance Eliminated?
Inst Tools > Blog > Temperature Measurement > How 3 Wire RTD Lead Wire Resistance Eliminated?
Last updated: November 22, 2019 6:26 am
4 Comments
3 Min Read
Today i am sharing an article about how a 3 wire RTD eliminates/reduces the lead wire resistance when compared with 2 wire RTD. Also, we will discuss impact of the ambient temperature on RTD measurement.
2 Wire RTD3 Wire RTD
The following question gives us the clarity about 3 wire RTD and the impact of ambient temperature on RTD temperature measurement.
A Wheatstone bridge, with fixed resistors R1, R2 and R3, of 100 Ω and supplied from a 10 V battery, is used to measure a temperature of 100 °C with a platinum resistance RT, that has a resistance of 139.1 Ω at 100 °C .
The thermometer is connected to the bridge with lead wires that have a resistance Rlead of 10 Ω at 20 °C and the thermometer is correctly calibrated for an ambient temperature of 20 °C.
Assume that the lead resistance changes to 11 Ω when the ambient temperature rises to 30 °C.
Calculate the temperature error introduced at an ambient temperature of 30 °C, when using
a) the two wire method and
b) the three wire method.
We know about RTD Resistance (RT) and bridge resistors values. Calculate I1, I2 and then bridge voltage. The bridge voltage will be used to find-out the equivalent temperature. So measure the bridge voltage for same scenarios with 2 wire & 3 wire RTD at different ambient temperatures and compare them.
2 Wire RTD
RTD Measuring with two leadsTherefore, if the bridge was correctly calibrated for an ambient temperature of 20°C, an error of 0.029 V will occur when the ambient temperature rises to 30 °C.
So instead of reading 100 °C, it would measure approximately 105 °C, an error of 5 °C or 5%.
3 Wire RTD
3 wire RTD lead wire resistanceTherefore, measuring with the three wire method, an error of only 0.006 V will occur. If the thermometer (RTD) was correctly calibrated to read 100 °C at an ambient temperature of 20 °C, then if the ambient temperature rises to 30 °C, the reading of 0.749 V would correspond to a value of 138.76 Ω for RT with no rise in ambient temperature, or in terms of temperature, 99.13 °C, an error of 0.87 °C or 0.87%. This is clearly a remarkable improvement over the two wire method.
So generally we prefer 3 wire RTD instead of 2 wire. We use 4 wire RTD for more accurate temperature measurements (rarely used).
Also Read: How a 4 Wire RTD Works ?
Single Position Calibration of Temperature Bath
Pressure and Temperature Gauges
Bridge Circuit Construction
Use of Temperature Transmitters instead of Direct Wiring
Temperature Transmitter Preventive Maintenance
Peltier Effect Theory
4 Comments
  • Rahul says:
    October 23, 2016 at 5:25 am
    Pl include save as PDF option also as it was previously.
  • Evgeny says:
    November 7, 2016 at 10:14 am
    Hello,
    very useful inf. thanks,
    Is it possible to download as pdf file?
    • S Bharadwaj Reddy says:
      November 7, 2016 at 11:33 am
      I am planning for pdf download option. soon it can be available. Thanks
  • BHASKAR says:
    May 22, 2023 at 7:12 am
    Hi Bharadwaj,
    Can you pls clarify me, in above 2 wire method example, how 1.17V equal to 105deg C of RTD ohms value..? Also in 3 wire method how 0.748V equal to 99.13 degC and how 0.749 V would correspond to a value of 138.76 Ω for RT. Thanks..
Manually Interpreting Thermocouple Voltages
Resistance Temperature Detectors (RTD) Construction
Mechanical Temperature Measuring Sensors
RTD Calculator Software
Thermocouple Software compensation
Thermocouple Working Principle
Pyrometers Handbook
Formula of 2 Wire RTD, 3 Wire RTD & 4 Wire RTD
Stability and Uniformity of Temperature Bath
non-contact pyrometer principle
Non-contact Temperature Sensors
Thermovcouple Circuit
Thermocouple and its Principle
Thermocouple simulator
Problems of Reference Junction Compensation : Thermocouples
Relationship between Temperature Scales
Probe Thermometer
What is a Probe Thermometer? How to Calibrate and Use it?
Spiral bimetallic thermometer principle
Spiral Bimetallic Thermometer Principle
Delete Siemens CPU Memory
Closed-tank-DP-Level-Transmitter-with-wet-leg-elevation-zero-direct-mount-Calibration
Closed tank DP Level Transmitter with wet leg elevation zero direct mount Calibration
Electrician Tools
Electrician Tools MCQ Questions
Functions of Instrument Transformers
Functions of Instrument Transformers (CTs and PTs)
Welding Machine Fail in Dusty and Corrosive Areas
harmonics-effect-on-induction-motor
Harmonics effect on Induction Motor
Percentage-to-Current-Conversion
Formula to Calculate 4-20ma from Percentage
PLC Boxes Sorting Based on Height
PLC Programming: Sorting and Distribution of Boxes by Height
