Reading: Flow Meter Questions and Answers
Inst Tools > Blog > Flow Measurement > Flow Meter Questions and Answers
In this post, you can read the basic flow measurement questions and answers on flow meters which are useful for the viva, tests, interviews.
Last updated: November 2, 2023 1:07 pm
Flow Measurement Instrumentation Interview Questions
2 Comments
In this post, you can read the basic flow measurement questions and answers on flow meters which are useful for the viva, tests, and interviews.
Flow Meter Questions and AnswersWhat are the different types of positive displacement meters?What are the major three methods of flow meters?What are the different types of thermal flow meters?Name the different types of weighing methodsWrite any two points of calibration of the flow meterExplain the principle of turbine flow meterList the advantages & disadvantages of turbine flow meterWhat is Rotameter?Explain the principle of calorimeter flow meterList some examples of the inferential flow meter
  • Reciprocating piston type
  • Rotating vane type
  • Nutating disk type
  • Lobed impellar type
  • Oscillating piston type
  • Area flow meter
  • Mass flow meter
  • Quantity meters
  • Heat transfer flow meters
  • Hot wire flow meters
  • semiconductor feed belt weighing ( Batch weighing)
  • continuous conveyor scale
  • radio active transmission gauge
  • volumetric solid methods
  • wet meter – manometer which is calibrated with mercury
  • dry meter – manometer which is calibrated with mercury
when the liquid enters through the inlet, due to the inflow, the shaft rotates which cuts the magnetic pickup, and produces the voltage which is proportional to the inflow of water.
Advantages
  • Better Accuracy [± 0.25% to ± 0.5%].
  • It provides excellent repeatability [± 0.25% to ± 0.02%] and rangeability (10:1 and 20:1).
  • It has fairly low pressure drop.
  • It is easy to install and maintain.
  • It has good temperature and pressure ratings.
  • It can be compensated for viscosity variation.
Disadvantages
  • It is not suitable for non-lubricating fluids.
  • They cannot maintain its original calibration over a very long period and therefore periodical recalibration is necessary.
  • limited use for slurry application
  • They are sensitive to changes in the viscosity of the liquid passing through the meters.
  • They are sensitive to flow disturbances.
  • Due to high bearing friction is possible in small meters, they are not preferred well for low flowrates.
What is Rotameter?
It is an example of a variable area flow meter. When fluid enters lopped moves from the bottom to top. Distance is proportional to the flow rate.
Consist of two coil type resistance thermometer, the difference of temperature between the thermometer is maintained constant.
In the inferential type of flow metering techniques, the out-quantity flow rate is inferred from a characteristic effect of a related phenomenon.
  1. Turbine flow meters
  2. Target flow meters
  3. Ultrasonic flow meters
  • Averaging Pitot Tube Principle
  • Different Types of Control Valve
  • Flow Measuring Devices Questions
  • Linear to Square Root Conversion
  • What is Flow Meter Accuracy?
Linear to Square Root Extraction
Interview Questions on Fire Alarm System
Is it Easy to Measure Natural Gas Flow and Volume?
Laminar Flow Meter Working Principle
2 Comments
  • ahmed S abdullah says:
    November 29, 2021 at 8:54 pm
    how can be change the totalizer sum value to a desired value as shown in the picture??? your support pls
  • suhas kilche says:
    January 18, 2022 at 4:31 pm
    which flowmeter is suitable for gas flow measurement? and why this flowmeter is suitable for gas flow measurement?
Calibration Interview Questions and Answers
Electrical & Instrumentation QC Interview Questions
Interview Questions and Answers on Load Cell
Gas Detectors Interview Questions & Answers
Dissolved Oxygen Analyzer Interview Questions & Answers
Interview Questions for Instrument Engineers
What is a Paddle Wheel Flow Meter?
Basics of Venturi Flow Meter
Heat Tracing Problems
Differential Pressure (DP) Flow Meters Range Calculation Methods
Field Transmitter Installation
Cables and Cable Glands Questions and Answers
Flow Element Symbol
What is a Flow Element? – Types, Comparison of Flow Elements
Total Organic Carbon Analyzers Questions and Answers
Top 100 Control Systems Objective Questions & Answers
Particle Image Velocimetry (PIV) Principle
Gas Turbine Interview Questions and Answers
Insulation of Thermowell
Facts on Thermowell Insulation Thickness
BJT Amplifiers Interview Questions & Answers
RF Capacitance Switch Principle
Safety Switches for Controlling Conveyor Operations
X-Ray Diffractometers Questions & Answers
Chemical Battery
Batteries
Calibration setup for a low-range electronic pressure transmitter
Instrument Lab Exercise – Ranging and Manometer Usage
Control Valves Questions and Answers
Control Valve Questions and Answers
Schneider Electric Modicon M340 PAC
PLC vs PAC – Understanding the Key Differences and Similarities
