Test and improve your knowledge of Flow Measurement Fundamentals with questions and answers covering flow principles, measurement methods, flowmeter types, differential pressure, velocity, density, and practical instrumentation concepts.
Question 1
Which statement correctly defines volumetric flow rate?
A. Volume per unit density
B. Volume per unit time
C. Volume per unit area
D. Velocity per unit mass
View the Answer
Correct Answer: B. Volume per unit time
Volumetric flow rate is the volume of fluid passing through a given cross-sectional area per unit time. It is commonly represented by Q and is expressed in units such as m³/s, m³/h, L/min, or ft³/min.
Question 2
Which SI unit is used for volumetric flow rate?
A. kg/s
B. Pa/s
C. m³/s
D. N/m²
View the Answer
Correct Answer: C. m³/s
The SI unit of volumetric flow rate is cubic meters per second (m³/s). It represents the volume of fluid transported through a flow section during one second.
Question 3
Which equation represents volumetric flow rate?
A. Q = Av
B. Q = ρV
C. Q = P/A
D. Q = A/v
View the Answer
Correct Answer: A. Q = Av
Volumetric flow rate is calculated as Q = A × v, where A is the cross-sectional area and v is the average fluid velocity. Therefore, increasing either pipe area or average velocity increases volumetric flow.
Question 4
In Flow Measurement, in the formula Q = Av, what does v represent?
A. Fluid density
B. Fluid velocity
C. Fluid volume
D. Fluid pressure
View the Answer
Correct Answer: B. Fluid velocity
The variable v represents the average fluid velocity through the flow area. For a known pipe area, increasing velocity directly increases volumetric flow rate.
Question 5
Which statement correctly defines mass flow rate?
A. Mass per unit volume
B. Mass per unit area
C. Mass per unit time
D. Mass per unit density
View the Answer
Correct Answer: C. Mass per unit time
Mass flow rate is the mass of fluid passing a particular point per unit time. It is represented by ṁ and is commonly expressed in kg/s, kg/h, or lb/h.
Question 6
Which SI unit represents mass flow rate?
A. kg/s
B. m³/h
C. L/min
D. Pa/s
View the Answer
Correct Answer: A. kg/s
The SI unit of mass flow rate is kg/s. Unlike volumetric flow, mass flow directly represents the amount of matter transported and is therefore useful when fluid density changes significantly.
Question 7
Which flowmeter operates using differential pressure?
A. Magnetic meter
B. Coriolis meter
C. Ultrasonic meter
D. Orifice meter
View the Answer
Correct Answer: D. Orifice meter
An orifice meter is a differential-pressure flowmeter. The restriction created by the orifice causes a pressure difference, and the measured DP is related to flow velocity and therefore flow rate.
Question 8
What principle does an orifice plate use?
A. Differential pressure
B. Magnetic induction
C. Thermal expansion
D. Coriolis force
View the Answer
Correct Answer: A. Differential pressure
An orifice plate creates a restriction in the pipeline. As fluid passes through the restriction, its velocity and pressure change, producing a measurable differential pressure that can be related to flow.
Question 9
What generally happens to DP across an orifice as flow increases?
A. It decreases
B. It remains fixed
C. It becomes zero
D. It increases
View the Answer
Correct Answer: D. It increases
As flow velocity increases through the restriction, the pressure difference across the orifice generally increases. For an idealized DP flow measurement, flow is approximately proportional to the square root of differential pressure.
Question 10
Flow through a DP element is approximately proportional to what?
B. Square root of DP
C. DP squared
D. Static pressure
View the Answer
Correct Answer: B. Square root of DP
For a differential-pressure primary element, the fundamental relationship is approximately Q ∝ √DP. This is why a square-root extraction is normally required when converting a DP transmitter signal into a linear flow indication.
Question 11
What pressure measurement is required across an orifice?
A. Atmospheric pressure
B. Vacuum pressure
C. Absolute pressure
D. Differential pressure
View the Answer
Correct Answer: D. Differential pressure
An orifice flow measurement requires the pressure difference between two locations. Therefore, a DP transmitter is commonly connected across the upstream and downstream pressure tapping points.
Question 12
What is the primary purpose of an orifice plate?
A. Increase fluid density
B. Measure temperature
C. Create measurable DP
D. Increase flow
View the Answer
Correct Answer: C. Create measurable DP
The purpose of the orifice plate is to create a controlled restriction that produces a measurable pressure differential. The relationship between DP and flow allows the flow rate to be calculated.
Question 13
Which flowmeter has no obstruction in the flow path?
A. Magnetic flowmeter
B. Orifice meter
C. Flow nozzle
D. Venturi meter
View the Answer
Correct Answer: A. Magnetic flowmeter
A magnetic flowmeter has an unobstructed flow tube because there is no primary restriction or moving mechanical element inside the flow path. This results in very low permanent pressure loss.
Question 14
Which flowmeter operates using Faraday’s law?
A. Vortex meter
B. Magnetic flowmeter
C. Rotameter
View the Answer
Correct Answer: B. Magnetic flowmeter
A magnetic flowmeter operates according to Faraday’s law of electromagnetic induction. When a conductive fluid moves through a magnetic field, a voltage is induced across electrodes, and this voltage is proportional to fluid velocity.
Question 15
What property must a fluid have for a magnetic flowmeter?
A. High pressure
B. High viscosity
C. Electrical conductivity
D. High temperature
View the Answer
Correct Answer: C. Electrical conductivity
A magnetic flowmeter requires the process fluid to have sufficient electrical conductivity so that the induced voltage can be detected by the electrodes. Water, wastewater, and many conductive chemicals are suitable applications.
Question 16
Which fluid is generally unsuitable for a magnetic flowmeter?
A. Conductive water
B. Wastewater
C. Conductive slurry
D. Hydrocarbon oil
View the Answer
Correct Answer: D. Hydrocarbon oil
Conventional magnetic flowmeters require conductive fluids. Most hydrocarbon oils have very low electrical conductivity, making them generally unsuitable for standard electromagnetic flow measurement.
Question 17
What generates the signal in a magnetic flowmeter?
A. Moving conductive fluid
B. Pressure difference
C. Moving magnets
D. Mechanical rotation
View the Answer
Correct Answer: A. Moving conductive fluid
When a conductive fluid moves through the magnetic field generated inside the flowmeter, an electrical voltage is induced. The magnitude of this voltage is proportional to the average fluid velocity.
Question 18
Which components contact the fluid in a magnetic meter?
A. Pressure ports
B. Measuring electrodes
C. Mechanical rotation
D. Float mechanism
View the Answer
Correct Answer: B. Measuring electrodes
Magnetic flowmeters use electrodes mounted in the flow tube to detect the voltage induced by the moving conductive fluid. The electrodes must make suitable electrical contact with the process fluid.
Question 19
Why must magnetic meter electrodes contact the fluid?
A. To measure pressure
B. To measure density
C. To sense induced voltage
D. To measure temperature
View the Answer
Correct Answer: C. To sense induced voltage
The electrodes detect the small voltage generated by the moving conductive fluid. Without electrical contact between the fluid and electrodes, the induced flow signal cannot be measured correctly.
Question 20
Which flowmeter is suitable for conductive liquids?
B. Vortex meter
C. Turbine meter
D. Rotameter
View the Answer
Magnetic flowmeters are particularly suitable for conductive liquids, including water, wastewater, acids, alkalis, and many slurries. They have no moving parts and introduce very little permanent pressure loss.
Question 21
Which flowmeter directly measures mass flow?
A. Magnetic meter
B. Coriolis meter
C. Orifice meter
D. Vortex meter
View the Answer
Correct Answer: B. Coriolis meter
A Coriolis flowmeter directly measures mass flow using the Coriolis effect created by fluid movement through vibrating measurement tubes. It does not require a separate density measurement to calculate mass flow.
Question 22
Which additional variable can a Coriolis meter measure apart from mass flow?
A. Density
B. pH
C. Conductivity
D. Turbidity
View the Answer
Correct Answer: A. Density
Many Coriolis flowmeters can also determine fluid density by measuring the natural frequency of their vibrating tubes. Some models can also provide process temperature as an additional measurement.
Question 23
What phenomenon is fundamental to vortex meters?
A. Magnetic induction
B. Pressure recovery
D. Vortex shedding
View the Answer
Correct Answer: D. Vortex shedding
The operating principle of a vortex flowmeter is vortex shedding. The frequency of vortices produced behind the bluff body is detected and converted into a flow measurement.
Question 24
What happens to vortex frequency as flow velocity increases?
A. It generally increases
B. It decreases
C. It becomes zero
D. It remains constant
View the Answer
Correct Answer: A. It generally increases
Vortex shedding frequency increases approximately in proportion to flow velocity within the meter’s specified operating range. Therefore, measuring frequency provides an indirect measurement of flow rate.
Question 25
Which ultrasonic method uses frequency shifts?
A. Transit-time method
B. Coriolis method
C. Doppler method
D. Thermal method
View the Answer
Correct Answer: C. Doppler method
The Doppler ultrasonic method determines flow from a frequency shift in ultrasonic signals reflected by particles or bubbles moving with the fluid.
Question 26
Which ultrasonic method suits clean liquids?
A. Doppler method
B. Thermal method
C. Coriolis method
D. Transit-time method
View the Answer
Correct Answer: D. Transit-time method
The transit-time method is commonly used for relatively clean liquids. It compares the travel times of ultrasonic signals moving upstream and downstream through the fluid.
Question 27
What does a Doppler meter require in the fluid?
A. Reflective particles
B. Electrical conductivity
C. High density
D. Magnetic particles
View the Answer
Correct Answer: A. Reflective particles
Doppler ultrasonic flowmeters require sufficient reflective particles, suspended solids, or gas bubbles to scatter the ultrasonic signal. The reflected signal experiences a frequency shift related to fluid velocity.
Question 28
Which flowmeter can measure without process contact?
A. Turbine meter
B. Clamp-on ultrasonic
C. Rotameter
D. Coriolis meter
View the Answer
Correct Answer: B. Clamp-on ultrasonic
Clamp-on ultrasonic flowmeters are mounted externally on the pipe and measure flow through the pipe wall. They do not require penetration into the process, making them useful for temporary measurements and some retrofit applications.
Question 29
Which flowmeter uses a moving float?
A. Magnetic meter
B. Coriolis meter
C. Rotameter
D. Vortex meter
View the Answer
Correct Answer: C. Rotameter
A rotameter is a variable-area flowmeter containing a float inside a tapered tube. The float moves to a position where the upward fluid force balances the effective downward forces acting on it.
Question 30
What principle does a rotameter use?
A. Coriolis force
C. Vortex shedding
D. Variable area
View the Answer
Correct Answer: D. Variable area
A rotameter operates on the variable-area principle. As the float rises, the annular flow area increases until the forces acting on the float reach equilibrium at a position corresponding to the flow rate.
Question 31
What happens to a rotameter float as flow increases?
A. It rises
B. It falls
C. It stays fixed
D. It disappears
View the Answer
Correct Answer: A. It rises
Increasing flow produces greater upward force on the float, causing it to rise. The float position is read against a calibrated scale to determine flow rate.
Question 32
Which flowmeter contains a rotating element?
B. Vortex meter
C. Turbine flowmeter
D. Ultrasonic meter
View the Answer
Correct Answer: C. Turbine flowmeter
A turbine flowmeter contains a rotor that spins as fluid passes through the meter. Rotor speed is related to fluid velocity and therefore flow rate.
Question 33
What is proportional to rotor speed in a turbine meter?
A. Fluid density
B. Mass flow
C. Fluid pressure
D. Flow velocity
View the Answer
Correct Answer: D. Flow velocity
In a turbine flowmeter, the rotor speed is related to the fluid velocity through the meter. The instrument electronics detect rotor rotation and convert it into a flow measurement.
Question 34
Which fluid property can affect turbine meter accuracy?
A. Fluid viscosity
B. Mass flow
C. Fluid pressure
D. Fluid temperature
View the Answer
Correct Answer: A. Fluid viscosity
Fluid viscosity can affect the rotor’s mechanical behavior and calibration, particularly at low flow rates. Turbine meters therefore require suitable fluid and operating conditions for accurate measurement.
Question 35
Which primary element has a converging throat?
A. Orifice
B. Venturi tube
C. Thermal flowmeter
D. Pitot tube
View the Answer
Correct Answer: B. Venturi tube
A Venturi tube consists of a converging section, throat, and diverging section. Fluid velocity increases through the throat, producing a corresponding reduction in static pressure.
Question 36
What happens to velocity at a Venturi throat?
A. It decreases
B. It stays constant
C. It increases
D. It becomes zero
View the Answer
Correct Answer: C. It increases
The throat has a smaller cross-sectional area than the upstream pipe. By continuity, the fluid velocity increases as it passes through the smaller area.
Question 37
Which flow device generally has lower pressure loss?
A. Venturi meter
B. Orifice meter
C. Pitot tube
D. Flow nozzle
View the Answer
Correct Answer: A. Venturi meter
A Venturi meter generally produces lower permanent pressure loss than an orifice plate because its gradual diffuser allows better pressure recovery downstream.
Question 38
Which DP flow element is simple and economical?
A. Coriolis meter
B. Orifice plate
C. Magnetic meter
D. Ultrasonic meter
View the Answer
Correct Answer: B. Orifice plate
Orifice plates are mechanically simple, relatively inexpensive, and easy to replace. Their disadvantages include permanent pressure loss and sensitivity to installation and upstream flow conditions.
Question 39
What is a major disadvantage of an orifice plate?
A. No pressure loss
B. Requires conductivity
C. Permanent pressure loss
D. Requires moving parts
View the Answer
Correct Answer: C. Permanent pressure loss
An orifice plate creates a restriction that causes permanent pressure loss. Some of the fluid’s pressure energy is not recovered downstream of the restriction.
Question 40
What does an orifice beta ratio represent?
A. Pressure ratio
B. Bore-to-pipe diameter
C. Pipe-to-bore diameter
D. Flow ratio
View the Answer
Correct Answer: B. Bore-to-pipe diameter
The beta ratio, β, is generally defined as the orifice bore diameter divided by the internal pipe diameter, β = d/D. It is an important parameter in DP flow calculations.
Question 41
Which flowmeter is commonly used for steam?
B. Rotameter
C. Turbine meter
D. Vortex flowmeter
View the Answer
Correct Answer: D. Vortex flowmeter
Vortex flowmeters are widely used for steam measurement because they can handle gases, liquids, and steam and have no moving mechanical parts.
Question 42
What does Reynolds number characterize?
A. Fluid pressure variation
B. Pipe wall roughness
C. Fluid temperature change
D. Flow regime of fluid
View the Answer
Correct Answer: D. Flow regime of fluid
Reynolds number characterizes the flow regime of a fluid by comparing inertial forces with viscous forces. It is used to determine whether flow is predominantly laminar, transitional, or turbulent. A low Reynolds number indicates that viscous forces dominate and the flow tends to be laminar, while a high Reynolds number indicates that inertial forces dominate and the flow tends to be turbulent. This parameter is widely used in flow measurement and fluid-flow calculations.
Question 43
Which parameter strongly affects Reynolds number?
A. Fluid temperature
B. Fluid pressure
C. Fluid velocity
D. Fluid density
View the Answer
Correct Answer: C. Fluid velocity
Reynolds number depends on parameters including fluid density, velocity, characteristic diameter, and viscosity. Fluid velocity is therefore one of its important variables.
Question 44
What happens to velocity when the same flow enters a smaller pipe?
A. It decreases
B. It remains fixed
C. It increases
D. It becomes zero
View the Answer
For steady incompressible flow, continuity requires Q = Av. If Q remains constant while area decreases, the average velocity must increase.
Question 45
Which fundamental principle represents the conservation of mass in fluid flow?
A. Bernoulli equation
B. Gas law
C. Ohm’s law
D. Continuity equation
View the Answer
Correct Answer: D. Continuity equation
The continuity equation represents conservation of mass in fluid systems. For steady incompressible flow, it gives A₁v₁ = A₂v₂.
Question 46
Which principle relates pressure and velocity?
A. Faraday’s law
B. Bernoulli principle
C. Continuity equation
D. Gas law
View the Answer
Correct Answer: B. Bernoulli principle
The Bernoulli principle relates pressure, velocity, elevation, and fluid energy for idealized steady incompressible flow. It is fundamental to the operation of many differential-pressure flow devices.
Question 47
Which flowmeter is suitable for very low gas flow?
A. Orifice plate
B. Magnetic meter
C. Venturi tube
D. Thermal mass flowmeter
View the Answer
Correct Answer: D. Thermal mass flowmeter
Thermal mass flowmeters can provide sensitive measurement of gas mass flow and are widely used for applications such as compressed air, nitrogen, natural gas, and other gases.
Question 48
What does a thermal mass flowmeter primarily measure?
A. Mass flow
B. Volume only
D. Fluid density only
View the Answer
Correct Answer: A. Mass flow
A thermal mass flowmeter determines mass flow by measuring heat transfer from a heated sensor to the flowing gas. Its output is related to the mass flow rate rather than simply the volumetric flow.
Question 49
Which principle is used in thermal mass meters?
B. Heat transfer
C. Coriolis force
D. Vortex shedding
View the Answer
Correct Answer: B. Heat transfer
Thermal mass meters use heat transfer between a heated sensing element and the flowing fluid. Increasing mass flow generally increases the rate at which heat is carried away from the sensor.
Question 50
Which flowmeter can provide both mass flow and density?
A. Coriolis flowmeter
B. Rotameter
C. Orifice meter
D. Vortex meter
View the Answer
Correct Answer: A. Coriolis flowmeter
Many Coriolis flowmeters can provide mass flow and density from the same measurement principle. Density is derived from the resonant behavior of the vibrating measurement tubes.
Question 51
Why is straight pipe length required before many flowmeters?
A. To increase pressure
B. To stabilize flow profile
C. To reduce pipe diameter
D. Increase flowmeter range
View the Answer
Correct Answer: B. To stabilize flow profile
Upstream fittings such as elbows, valves, reducers, and tees can distort the velocity profile. Adequate straight pipe length allows the flow profile to become more stable and improves measurement accuracy.
Question 52
What can an upstream elbow near a flowmeter cause?
A. Stabilize flow profile
B. Reduced density
C. Flow-profile distortion
D. Zero flow
View the Answer
Correct Answer: C. Flow-profile distortion
An upstream elbow can create swirl and an asymmetric velocity profile. If the flowmeter is sensitive to the velocity profile, this distortion can introduce significant measurement error.
Question 53
Why are flow conditioners sometimes installed?
A. To increase flow rate
B. Increase flowmeter range
D. To improve flow profile
View the Answer
Correct Answer: D. To improve flow profile
Flow conditioners reduce swirl and help establish a more suitable velocity profile before the flow reaches the meter. They can be useful when available straight-run piping is limited.
Question 54
What is a major advantage of ultrasonic flowmeters?
A. Requires mechanical rotor
B. No moving parts
C. Requires conductive fluid
D. Limited to gases only
View the Answer
Correct Answer: B. No moving parts
Ultrasonic flowmeters have no moving mechanical parts, reducing mechanical wear. Many designs can also be installed without cutting into the pipe, especially clamp-on versions.
Question 55
What does a positive displacement meter measure?
A. Fluid density
D. Trapped fluid volume
View the Answer
Correct Answer: D. Trapped fluid volume
Positive displacement flowmeters repeatedly trap and pass known volumes of fluid. The number of displacement cycles per unit time is therefore related directly to volumetric flow.
Question 56
What is a key characteristic of positive displacement meters?
A. Require conductivity
B. Have moving parts
C. Use magnetic fields
D. Use ultrasonic signals
View the Answer
Correct Answer: B. Have moving parts
Positive displacement meters contain mechanical elements that repeatedly isolate and transport known quantities of fluid. Their moving parts require consideration of wear, maintenance, and fluid cleanliness.
Question 57
What does flowmeter turndown represent?
A. Pressure difference range
B. Pipe diameter ratio
C. Minimum-to-maximum flow
D. Maximum-to-minimum flow
View the Answer
Correct Answer: D. Maximum-to-minimum flow
Flowmeter turndown is the ratio between the maximum specified measurable flow and the minimum specified measurable flow while maintaining the required performance. A larger turndown provides greater usable measurement range.
Question 58
What is zero-flow verification used to check?
A. Meter output at no flow
B. Meter output at full flow
C. Maximum flow capacity
D. Pipe pressure at flow
View the Answer
Correct Answer: A. Meter output at no flow
Zero-flow verification checks the meter’s output when the actual flow is zero. It is useful for detecting zero offsets, installation problems, trapped flow, or other conditions that can cause measurement errors.
Question 59
What generally happens to DP when orifice restriction increases?
A. It decreases
C. It increases
D. It becomes zero
View the Answer
A greater restriction produces a larger pressure difference for a given flow condition. Therefore, increasing the restriction generally increases the DP generated by the primary element.
Question 60
Which physical effect is used by Coriolis meters?
A. Hall effect
B. Seebeck effect
C. Coriolis force
D. Doppler effect
View the Answer
Correct Answer: C. Coriolis force
Coriolis flowmeters use the Coriolis effect. When fluid flows through vibrating tubes, the resulting Coriolis forces create measurable tube deformation or phase differences that are proportional to mass flow.
Question 61
Which flow variable is directly measured by a Coriolis meter?
A. Pressure
B. Level
C. Temperature
D. Mass flow
View the Answer
Correct Answer: D. Mass flow
A major advantage of a Coriolis meter is its ability to directly measure mass flow rate. The transmitter detects the effect of fluid mass moving through the vibrating tubes.
Question 62
Which flowmeter provides highly accurate mass flow measurement?
A. Orifice meter
B. Coriolis meter
C. Rotameter
D. Vortex meter
View the Answer
Coriolis flowmeters are widely recognized for high-accuracy direct mass-flow measurement. They are commonly selected where accurate mass flow, density measurement, or both are important.
Question 63
Which flowmeter uses vortex shedding?
A. Magnetic meter
B. Coriolis meter
C. Vortex flowmeter
D. Turbine meter
View the Answer
Correct Answer: C. Vortex flowmeter
A vortex flowmeter places a bluff body in the flow. As fluid passes the body, alternating vortices are shed downstream. The vortex shedding frequency is related to flow velocity.
Question 64
What is the primary purpose of a flow nozzle?
A. Measure temperature
B. Measure density
C. Measure level
D. Measure flow using DP
View the Answer
Correct Answer: D. Measure flow using DP
A flow nozzle is a differential-pressure primary element. It creates a controlled restriction, and the resulting pressure difference is used to determine flow rate.
Question 65
Which flow element suits high-velocity service?
A. Flow nozzle
B. Pitot tube
C. Rotameter
D. Magnetic meter
View the Answer
Correct Answer: A. Flow nozzle
Flow nozzles are mechanically robust and are commonly used in applications involving high-velocity fluids, including steam and other industrial services.
Question 66
Which flow regime has orderly fluid motion?
A. Laminar flow
B. Turbulent flow
C. Choked flow
D. Pulsating flow
View the Answer
Correct Answer: A. Laminar flow
In laminar flow, fluid particles generally move in relatively smooth, orderly layers with limited mixing between adjacent layers. Viscous forces dominate the flow behavior.
Question 67
Which flow regime has strong mixing?
A. Laminar flow
B. Turbulent flow
C. Static flow
D. Zero flow
View the Answer
Correct Answer: B. Turbulent flow
Turbulent flow is characterized by irregular fluctuations, eddies, and strong mixing. Industrial flowmeters often have specified Reynolds-number requirements because flow regime affects their performance.
Question 68
What is cavitation in liquid flow?
A. Vapor bubble formation
B. Increase in density
C. Gas dissolution
D. Constant pressure
View the Answer
Correct Answer: A. Vapor bubble formation
Cavitation occurs when local liquid pressure falls below the liquid’s vapor pressure, causing vapor bubbles to form. When the bubbles enter higher-pressure regions and collapse, they can cause noise, vibration, erosion, and equipment damage.
Question 69
What can cavitation cause in a flowmeter?
A. Improved accuracy
B. Error and equipment damage
C. Lower vibration
D. Stable flow
View the Answer
Correct Answer: B. Error and equipment damage
Cavitation can produce strong vibration and unstable flow conditions. It may also damage internal components and cause inaccurate or erratic flow measurement.
Question 70
What is flashing in liquid flow?
A. Liquid becomes denser
B. Flow stops completely
C. Vapor remains after pressure drop
D. Gas dissolves
View the Answer
Correct Answer: C. Vapor remains after pressure drop
Flashing occurs when liquid pressure falls below vapor pressure and vapor forms, but the vapor remains present because downstream pressure does not recover sufficiently to collapse the bubbles.
Question 71
What is a major advantage of direct mass flow measurement?
A. Requires no calibration
B. Requires no power
C. Density conversion needed
D. No density conversion needed
View the Answer
Correct Answer: D. No density conversion needed
Direct mass-flow measurement eliminates the need to calculate mass flow from volumetric flow and separately measured density. This can simplify measurement where density varies with pressure or temperature.
Question 72
What is permanent pressure loss?
A. Maximum fluid pressure
B. Pressure not recovered upstream
C. Pressure not recovered downstream
D. Atmospheric pressure
View the Answer
Correct Answer: C. Pressure not recovered downstream
Permanent pressure loss is the portion of pressure loss that remains after the flow passes through a restriction and downstream pressure recovery has occurred. It represents lost pressure energy in the system.
Question 73
Why is steam flow often pressure compensated?
A. Flow changes with density
B. Conductivity changes
C. Magnetic field changes
D. Density changes with pressure
View the Answer
Correct Answer: D. Density changes with pressure
Steam density changes significantly with pressure and temperature. If a volumetric flow measurement is used, pressure and temperature compensation may be necessary to calculate accurate mass flow.
good one
